Over a year ago I deleted the driver door tumbler/lock mechanism. Later I deleted all door lock pulls, removed the mechanism from all four doors. Also if you do that you don't need jimi jammers.
I placed a domed plug where the keyhole was and painted it with touch up paint, being small was not really noticeable.
But I finally decided to do it properly, so I purchased the passenger door handle mechanism. You don't need the entire mechanism to do this, but Ford does not sell just the handle. With the entire mechanism in hand the handle itself
View attachment 124371View attachment 124372View attachment 124373View attachment 124374View attachment 124376was removed. Much easier install this way as you don't have to make ANY modifications to reinstall on the drivers door. You remove 2 silver pins, then reinstall by flipping the pins so they point down rather than up. See yellow arrows. It's an expensive modification, but if you want your handle to look proper it's the way it has to be done. The paint was kinda high as star white is a 3 step process. $120.00, handle mechanism $238.00. I provided the fuel door to the painter to color match. Came out perfect.
