Best lighting options for replacement fogs...
I have had the Diode Dynamics Pro somethingorothers for 4 years on my Tremor as foglight replacements. Yellow. They work great in fog, rain, and snow.
Has anyone converted LED fogs to Halogen brackets/bezels with the BD squadron lights? I have looked at the combo setup for my 22, but I’m not in love with the mounts and how they look on a non-black truck
I converted my factory LED fogs by installing factory Halogen brackets & bezels and using a Diode Dynamics mount.
Reused a pair of DD SS3 Pro white fog lights from another project.
Wire them to the factory harness with the DD adapter plugs so I could retain the factory switch.
Factory Halogen mounts & bezels -
Diode Dynamics brackets and harness adapter -
Not impressed with this kit. Ford Squadron SAE/Squadron Pro Dual Fog Pocket Light Kit. The 3-light rigid kit on my Raptor was better than this and significantly cheaper. I'll be looking at light bar now.
What aren't you impressed by and what lenses do you have on the Pros? IMHO if you have fogs, you should be running the Pros as spots. If you are running the Pros with driving lenses you are just throwing half the output in areas that are already well covered.
That Rigid kit also has over 40% more watts per side. You can only do so much with so much power. You aren't comparing apples to apples. That said, the BD lights are significantly better built than anything Rigid makes.
Something else I want to relay about Baja Designs. Customer service is pretty out of this world for people that bought lights new. My fog kit is actually a pieced together kit of lights that I purchased for a fog kit for a 2014 Ram back in like 2016 or 2017. I ordered the brackets and wiring directly from BD for the F350. My Pro lights had a little bit of corrosion on the powdercoating from almost 8 years mounted up on various trucks. When I reached out to them I was told to send them in and see what they could do. I sent the Pros in and they rehabbed them 100% with new housings. It looks like they just sent me brand new lights honestly. During my email correspondence the BD rep told me to send in the sports to get rehabbed so they would match when he noticed these were originally purchased all together. There was nothing wrong with the sports he just said they should all match so send them in. I sent them in and got another set of lights back that look brand new. Since I had bought that original set they have changed the powder coating process and these should hold up better.
That kind of customer service for life is why I buy BD. Here I am almost 10 years in on this light purchase and I got them rehabbed for the cost of shipping them back and essentially have brand new lights.
Hey Federalist,
Thank you for your feedback. Are you referring to Quality? or Output? With the creation of our kits, we are eliminating the stock fogs allowing customers to add a better output fog light with our SAE squadron plus adding a Squadron pro light for off-roading. For all four lights, you are looking at a total of 13,030 lumens. Our product also comes with a lifetime warranty and the ability to swap lenses or patterns on all non-SAE lights. We also have a variety of solutions if you wish to add more lighting to your setup to pair up with your fogs.
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
Hey Federalist,
Best,
And to mention, you can mount them from the top, bottom, or sideways for that matter, because the lenses will flip over or rotate to maintain the proper illumination pattern. I love my Squadrons! So many options. And ability to swap to all Yellow/amber lighting for fog and dust conditions.
Hey Federalist,
Best,
Quality is amazing as well as the instructions and ease of install. I'm running the SAE fog (amber) and a Squadron pro. So dual setup with additional Spot/Driving. The output of the Amber fog isn't what my expectation is.
That's why I have stayed with the wide cornering all of these years. I would reach out to BD and see if they can fix you up. They will make it right. Have them throw a spot lens in the box for the Pros when they return your lights.
You are in Idaho so like here in Montana, you can get away with not having an SAE light. LOL.
What's the mount setup for those backup lights. That's clean.
View attachment 184023View attachment 184024
That license plate is illegal, sir!
As long as you realize that these will be for off-road use only and not street legal, it's 100% doable. I'm personally running Squadron Pros off my fog light harness and have been since 2019 without issue. So if you'd like to do those brackets with Squadron Pros we can make it happen.
Baja Designs does not offer the Pros for this kit as they never tested it with the OEM fog wiring. But here at Apollo Optics, I've personally confirmed that it works.
For wiring, we can do the adapters that go directly to your OEM fog lights or run them to an upfitter switch.
Now, if you're wanting to put them on a high beam trigger, that's doable, but a little more involved. You'll need to use an external relay harness (which we can get for you) and then run the main power to the upfitter to power the lights and then use the high beam trigger (hidden in the bumper for snow plow use) to then activate the lights by the high beam switch.
Personally, I'm not a fan of doing this and would say to just put them on your stock fogs or to an upfitter.
If you run them to your stock fogs, you can also go into Forscan and turn on "Bambi" mode so that your fog lights will NOT turn off when your high beams are engaged.
Are you just running the single Squadron Pros per side on the fog circuit?
I have the BD Squadron pro and unlimited squadron racer in my fog pockets. The racer is a four emitter spot, while the pro is two spot emitters for mid range, and two fluted close range emitters.
Do you have any pics of the output?
How did you wire these?
If you like the idea of backlights, it's not a bad option. Personally, I just don't care for the aesthetic of the DD stuff. We carry it and the output is good, but aesthetically, it's not my favorite.
I think the Factory Aftermarket bar with LP6 or LP9 lights looks better than this setup and has way more output. SS5 Pro CrossLink 5-light kit emits 48,000 lumens. LP6 Pro would be 56,125 lumens and LP9 Pro would be 62,735.
Factory Aftermarket Bar w/ LP6 Lights
Factory Aftermarket Bar w/ LP9 Lights
More pictures here: Factory Aftermarket Light Bar "The Classic" with 5 Tabs for Ford F-250/F-350 Super Duty
Another option would be the Baja Designs XL-Linkable kit which features 7 XL pods vs 5 shown above. I just think the XL-Linkable kits look sharp on these trucks. Less output vs the SS5, but we have had custom units built for guys that are all XL80 lights vs XL Sport lights.
Baja Designs XL-Linkable Kit for 2023+ Ford F-250/F-350 Super Duty
Let me know if you have any other questions. Happy to help.
How does the linkable kit with XL80s wire up?
Thanks! Homemade. I used two pieces of 2-inch aluminum angle overlapped and fastened together to "clamp" over the trailer hitch bar. Used two stainless screws in the rear (thread tapped) for tension and 3M tape on top to hold it secure. Also used flat head stainless screws in beveled holes to maintain a flat contact area on top and where it mounts to the light bracket. No holes drilled into the hitch metal, is solid, been there for at least two years. They sit in a spot perfect for the light to be rotated and angled out (or any direction desired). They are tied into an upfitter switch but could easily be tied into the actual backup lights with a relay. (Or both with a couple of diodes.)
The only reason I didn't use 2.5 or 3" angle is to maintain enough clearance to mount over the hitch bar. Clearance is around 2 inches when assembled as one unit. There are probably ways to do that, but this worked.
Aren't you glad you asked @Canyon Trekker about his set-up? Be careful! He will give you every detail, right down to the nut, errrr bolt, yes, right down to the bolt! 🤪
Nacho Off-road Lighting is wrapping up packaging to ship out fog kits.
Yes. I was running the ADD Stealth Fighter front bumper and was running a single pair of Squadron Pros on the OEM fogs.
When I do them, we run them on 3 relays: 3 center lights, 2 lights flanking, 2 outer lights. All on separate relay harnesses and then using the upfitters to connect to the switch wires of the relay. The issue here is not the truck's upfitter capacity, but the capacity of the Baja Designs wiring harnesses. We had a customer running 4 XL80s on his XL-Linkable and had issues with the Baja Designs relays. So we now only run triple relay kits for safety.
That said, you can still trigger all 7 lights off 1 switch, if desired. We've also had guys run 5 white lights flanked with 2 amber lights and run them on 2 separate switches.
The Squadron SAE is very restricted because it must meet all the fog light requirements. We can always convert them to Sports if you are interested shoot me an email at [email protected]. Even though they are not legal they will be brighter.
Best,
Hey Nick, my 2020 F350 Tremor has the OEM halogen fogs (and I’ll soon be replacing the halogen headlights with OEM LEDs). I’m torn on replacing the fogs with some Diode Elites or going all out for the Baja Squadrons. I’m a little confused by the Squadrons though… are those a plug and play replacement for my OEM halogens? What connection options do I have? I don’t have any upfitter switches. I’d be okay if both lights turned on by simply flipping on the fog light switch, is that possible? I guess I’m just curious about my options and if I’d need anything else depending on what I’d want to do? Thanks
