Best lighting options for replacement fogs...
Hey Nick, my 2020 F350 Tremor has the OEM halogen fogs (and I’ll soon be replacing the halogen headlights with OEM LEDs). I’m torn on replacing the fogs with some Diode Elites or going all out for the Baja Squadrons. I’m a little confused by the Squadrons though… are those a plug and play replacement for my OEM halogens? What connection options do I have? I don’t have any upfitter switches. I’d be okay if both lights turned on by simply flipping on the fog light switch, is that possible? I guess I’m just curious about my options and if I’d need anything else depending on what I’d want to do? Thanks
We do have the Squadron kits that re completely plug and play.
You have two options, since you have the single halogen fog lights. We can run the single Baja Designs Squadron so it's direct plug and play to your factory fog light connection.
We can do this setup in Squadron Sport, Squadron SAE, or Squadron Pro.
And then of course, we have the dual fog light version.
Full list of options here: https://apollooffroad.com/products/...n-fog-light-kit-for-2020-2022-ford-super-duty
In this kit, the outside light is SAE fog and will be powered by your OEM fog light switch. The inside light will run off of an upfitter or we also offer the kit with a toggle switch that you'll mount in cab.
A great spot to mount the toggle switch is on the driver's side kick panel on the left side of the steering wheel just to the right of the AC vent.
Alternatively, we could also set you up with a Switch-Pros SP9100 system to give you effectively retrofitted upfitter switches, with more functionality than traditional upfitters.
We also offer clean installation options like this, just on the driver's side of the center console.
