That's right. Those are slick too. Similar idea w the swap to the non LED layout for some big LED output.
Hi Nick,
Thanks for the detailed info. I'd like to get them set up so I can turn them on independently from an upfitter switch and also have them set to automatically come on with the high beams. I can wire all of that. Will pry just start with having them run on the existing fog circuit.
Whats the cost for this setup?
Do you think the Pro's are worth it over the Sports?
Thanks!
Ended up with Squadron Pros in the halogen fog pockets. Wired it up two ways. Upfitter #2 is lights on. Upfitter #3 is triggered by the high beams. I quite like having this level of control. Driving at night with limited traffic and straighter roads, it works quite well to let the auto high beam trigger control things. It senses oncoming traffic long before the rick of blinding them.
The lights do a great job of filling in the blank spots that the OE lights miss. Very happy with things. Even with just this one mod over and above the OEM quad beams I'd say this truck has the best headlight setup of any other vehicle I've been in.
Now it's just a matter of trying to not watch these other threads on lighting that pop up and get more 'ideas.' Thanks again boys!
I see you are running clear and amber SAE Squadrons in the pocket - are you running both off of the OEM fog light switch? How do you like that? I am running amber SAE and clear pro same spot - SAE on OEM fog light switch and pro off of upfitter.We know a thing or two about lighting when it comes to Superduties....
When you're ready, we'll take care of you!
If you purchased the full kit from Baja Designs, they have an anti-back feed splitter that's included. The setup will work as follows:I see you are running clear and amber SAE Squadrons in the pocket - are you running both off of the OEM fog light switch? How do you like that? I am running amber SAE and clear pro same spot - SAE on OEM fog light switch and pro off of upfitter.
Nick, you have to change your username!If you purchased the full kit from Baja Designs, they have an anti-back feed splitter that's included. The setup will work as follows:
No lights on - hit Fog switch, only SAE fogs turn on. Hit upfitter switch, then inside Squadron lights turn on.
No lights on - fog switch is off - hit upfitter switch, all 4 lights turn on.
This wiring diagram helps explain how it works.
Should be done this week! Thanks man! hahaNick, you have to change your username!![]()
Haven't received my truck yet but this is what i ordered. Good to hear some real feedback. Buy once, cry once is my motto.Ended up with Squadron Pros in the halogen fog pockets. Wired it up two ways. Upfitter #2 is lights on. Upfitter #3 is triggered by the high beams. I quite like having this level of control. Driving at night with limited traffic and straighter roads, it works quite well to let the auto high beam trigger control things. It senses oncoming traffic long before the risk of blinding them.
Any chance Baja Designs would sell this harness separately? I’m currently running their single SAE fog pocket kit and wanting to add a Squadron Pro to the mix. I have an old KD fabworks bracket (the one for the 2017-2019 trucks) that I finally confirmed can fit on my truck with minimal modification so just need to get the Squadron Pro, but the wiring harness would be nice so that it’s run just like the kit from BD.If you purchased the full kit from Baja Designs, they have an anti-back feed splitter that's included. The setup will work as follows:
Absolutely. I can make that happen for you. Feel free to send me a PM and we can dial it in to make sure you get exactly what you're after to make it all work with your existing gear.Any chance Baja Designs would sell this harness separately? I’m currently running their single SAE fog pocket kit and wanting to add a Squadron Pro to the mix. I have an old KD fabworks bracket (the one for the 2017-2019 trucks) that I finally confirmed can fit on my truck with minimal modification so just need to get the Squadron Pro, but the wiring harness would be nice so that it’s run just like the kit from BD.
There's nothing wrong with getting flashed. It happens to me all the timeWith them focused at the road, drivers still flash me.
Thanks Nick! Sent you a PMAbsolutely. I can make that happen for you. Feel free to send me a PM and we can dial it in to make sure you get exactly what you're after to make it all work with your existing gear.
If you like the idea of backlights, it's not a bad option. Personally, I just don't care for the aesthetic of the DD stuff. We carry it and the output is good, but aesthetically, it's not my favorite.I just stumbled on this diode dynamics ss5 linkable light bar for the f250.
What are your opinion on this vs 5 LP6?
I think they look pretty cool I initaly saw it on an ad for BMC with a 23/24 they were upfitting lights on. [/MEDIA]
