Thank you for the tags and mentions,
@TRAMPER and
@Canyon Trekker!
@cs0430 - Going with a dual fog setup is going to be a great start based upon your needs that mentioned above. If you're looking for more distance than factory high beams and more coverage to the sides, a dual fog light kit will fit that perfectly.
One thing I do want to ask is what year is your truck? We have quite a few different options whether you have a 20-22 model or a 2023+ truck.
If you've got a 20-22, we can do a kit from Baja Designs that will allow you to fit 2 Squadrons. I'd recommend the Squadron Pro in a Driving/Combo pattern when you want to project further and wider than your headlights and then we can also go with a Squadron SAE for a street legal fog light that is brighter than stock.
Something like this:
If you have a 20-22 with factory LEDs and you wish to keep your OEM LED fog light, then the BMC kit would be perfect for you and we carry BMC as well. You'd retain your factory LED fog strip lights and then you can add a Squadron Pro and an S2 Pro to maximize visibility while still having the factory street legal fog lights.
If you have a 2023+ truck, then we have a few more options as well.
First, you have the Baja Designs kits which will feature dual Squadrons, similar to their 20-22 kit to fit the new 2023 bumper design:
If you prefer the look of the BMC design, you can do a Squadron and S2 light:
And if you want to go for absolute, all-out brightness and don't mind no longer having a truly street legal fog light, you can run the BMC kit with an XL80 and an S1. The XL80s would run off your upfitter and the S1 will tie into the factory fog light wiring. The S1 is not street legal, but if you run a wide cornering lens and aim it down a bit so it's below your factory headlights, it could be considered "street friendly."
Let me know your thoughts on any of the above options and I'd be happy to go over what's available to fit your needs and your budget and we can find the right solution. Feel free to send me a PM as well if you'd like to chat.
-Nick
