- Jul 29, 2023
- 4,081
- 11,926
- 2023 F350 XLT Premium Tremor, SAP, 7.3L
- 2027 Toyota Landcruiser 1958.
That 50Ten needs to make way more appearances on this forum.
...proceeds to leave a 1/2 page long responseso Ill be short
This is why I went with the 4banger pods in my OEM location. I removed the OEM LED foglights on my truck, "downgraded" to the OEM Halogens as I needed the buckets and brackets, then installed the 4bangers. It's also why I run the same ones in yellow, in my lower grille pitched at the same angle....proceeds to leave a 1/2 page long response
Thanks for the input. I do want a SAE fog light. I've driven through some torrential downpours on the lost coast in heavy fog and wouldn't want to take away legal lighting options for that situation. So that leaves either keep the OE fogs and go A-Pillar, or a bumper kit that can integrate an SAE light.
Also want to add some Fox 2.5's imminently, hence the trying to get this right the first time. Down the road a lot will come before more lights. We've only had our FWC for a few months and my wife already has her eyes set on a Norweld tray/Flatbed FWC.
How do the Triple-R's compare to the BD Squadron Pro?Looks like there has been plenty of great into in this thread so I dont want to beat it to death anymore so Ill be short.
You can achieve a lot with fog lights, though few stick with just that. Having used Baja Designs stuff for almost 15 years on multiple vehicles -- generally always used in a very similar use case to yours, I personally would skip over their SAE line unless you really need streel legal fog lights. That also extends to the sport line. For a little more money, you can get some serious output from a Squadron Pro. The output to size ratio on a Squadron Pro makes it possible my favorite light from BD. I will say for backup lights or side illumination, the sports are absolutely adequate.
I would start with a foglight kit with a Squadron pro in driving combo to get you started. If you get bit by the light bug, and add more lights to the bumper or A pillars, I would then migrate from a driving combo lens to a wide cornering lens. Keep in mind, if you call or email in, we can custom spec your foglight kit with whatever lights from Baja you want.. You dont have to just settle with their off the shelf option.
We have been experimenting with Triple R (aka Lazer lamps_ lights extensively on this truck. While they are not (yet) applicable for the OEM bumpers, I would definitely put them in the running for A pillar lighting or an LP6 or LP9 replacement. If you consider an aftermarket bumper later on (we recommend & sell Buckstop / TrailReady) it really opens up the door for light locations. With a 5000k color temperature, they match perfectly with Baja's.
We sell both Baja Designs and Triple R so we can easily talk through pros and cons of both brands and product lines. While we send batches of lights from Baja weekly, Triple R is starting to get some traction in the states.
You can view Baja & Triple R's entire product lines on our website.
Lighting spec on truck below:
On bumper:
Sentinel Elite 9" (pair)
Linear 24 Elite
In Bumper:
Sentinel Elite 7" (Pair) -
RacePod Spot (Pair) -
View attachment 170107View attachment 170108
Every time I see your TR I regret not getting the headlight guardsLooks like there has been plenty of great into in this thread so I dont want to beat it to death anymore so Ill be short.
On bumper:
Linear 24 Elite
In Bumper:
I can't recommend the Baja Designs kit enough. I got mine from Nick at Apollo optics.
The amber fogs are exactly what they are supposed to be. The Pro's effectively turn night into day.
Here is a link to my post with pictures showing the various light configurations. I also have 70% tint on the windshield which makes everything darker.
Gunslinging Patriot's Build Thread
I finally got her back from the detailer last night! :D I snapped a few pictures before it got dark out. I'll upload better ones once the sun comes out next week (we're supped to get 3" of rain Friday through Sunday). Here's a list of everything that was done a lot of which is to finish Ford's...www.fordtremor.com
Squad pros are going to be really versatile because the lens can be changed. I think the outout on the Triple R Utility 25 Max is really great, but its a "one lens pony." The RPs in my bumper (which competes with Baja's Squad XLs) are monsters. They are between a squadron XL pro and XL80s from an output standpoint, but with better exterior finishing and better pricepoint.How do the Triple-R's compare to the BD Squadron Pro?
I also just noticed how much wider your full guard tubes are than mine. Is that something you had them do custom?
A head on shot of mine for reference.
Yes it really is. After over 3 years with it now my favorite part is that the finish on it is still flawless!Isnt it such a great bumper
Must be, maybe the truck color has something to do with it tooPerhaps its the image
If you are even thinking about keeping the OE fogs, look at the Diode Dynamics SS6 kit. I highly recommend them. They're WAY better than the OEM lights and they have a road legal fog lens in amber and clear, as well as driving and flood lenses....proceeds to leave a 1/2 page long response
I second this, ditch lights are a good option and relatively easy to install. Plenty of options to consider re size, pattern, output etc.Look at ditch lights, takes care of all your needs you described.
Non they have covers for the Inside LED's@TRAMPER I go back and forth on the look of ditch lights. One day I don't mind them, and the next it's the opposite. How much glare on your hood are you getting from those?
I will expound on this, my Rigid cube ditch lights create no glare, also for those that do, if aimed properly that will minimize and in most instancesNon they have covers for the Inside LED's
It's the bear necessities that matter!I will expound on this, my Rigid cube ditch lights create no glare, also for those that do, if aimed properly that will minimize and in most instances View attachment 170567View attachment 170568eliminate any glare. For me it's not about the look, it's about function. I live in a rural area, nighttime driving is a challenge with hogs, deer and recently a 300 pound bear was hit and killed causing injury to the driver of a Chevrolet 2500!!
Awesome, man! Glad you're still enjoying the setup! Thanks for sharing those pictures as well.I can't recommend the Baja Designs kit enough. I got mine from Nick at Apollo optics.
