8" B&O sub replacement
My '24 sounds worlds better than my '08. When I want better, I drive, or ride in my Wife's Aviator, with the 28 speaker, 1250 watt Revel system. šŸ˜†
I had this in my '67 LandCruiser, in the early '90's. The kid I bought the box from, had to sell it as he had many noise tickets in California. šŸ˜†
Well, I guess I have to upgrade the '25 now.... Brings back some ol memories for sure. Started of with an ol Sony 502 back in the day with 2- Pioneer 10s, then to an Orion HCCA amps and 2- 10s MBquart components, then the alpine phase with the MRV amps and JLs, then the JL slash amps and subs and components, then most recently1 JL 12 w3 and Pioneer amp, Alpine components in my old Ram.. My fave was this setup in my old Tacoma. Hence my username across many forums, Boomtacoma LOL.
All JL in the early 2000's....highschool/college me could only dream of that.
With three JL subs, @Boom! 's username seems accurate. I recall having one 10" JL audio sub in my first truck (nearly 30 years ago :cry:) and that was great. A buddy of mine had two 10" in the trunk of his 67 Mustang Fastback and I could hear him from 2 - 3 blocks away. I can only imagine what three subs would do.
Back in my high school days in the late 2000s, I built a ported box out of 3/4" MDF for two Diamond D6 12" subs powered by a 2000w class D amp. The principal tracked me down one day and said if any of the pictures in his office fell off the wall, I was going to be in deep shit šŸ˜‚
I'm pretty happy with the stock sub in my '25 but if someone finds an easy drop-in upgrade like the last gen trucks, I'd probably do it. Honestly if there was a way to reduce the low pass filter a little on the stock sub, that might be enough.
Here's the porting on that box I built. There was a faceplate that sealed the smaller gaps next to the port openings.
Now the ringing never stops...
Well I have this garbage in my truck
I could have sworn I saw similar in this thread but I just scrolled the whole thing and didn't find anything. What is it, a 6x9 in there? Any upgrade options?
That was in his Tacoma. He has one 12W3 now. I've had two 10's in the backseat before 🤪.
It also depends on the series. If they were W7's, those would be destructive. W3's are a start and just enough for most people. W6's are a step up and the W7 is killer.
W6s and the gain cranked on the 500/1.. It used to knock the rear view mirror off, the JL components were kiiler too. I was in deep at one time.
Even had on of the First alpines athat folded back into the dash.. Good memories for sure
Yeah. A 6x9 ā€œsubā€. Got that turd here. I have not found any reasonable replacement options. I’m not spending that kind of dough on a sub.
One thing I have not found yet is the stand alone price of the ā€œKicker Subā€ option they had for 23-26. That is literally the only thing I am kicking myself for not adding to my build.
There are a couple powered sub options. Don’t know if they’ll fit behind the seat, or how they sound. It’s got to be better than the stock one.
"Kicking" myself - Kicker sub. I see what you did there. Brilliant!
Link -> Ford Kicker Sub It looks like a tidy clean kit, but Ford’s site says this sub isn’t compatible if you have the ā€œupgradedā€ B&O system. Apparently upgraded is doing a lot of work there. I’m curious if someone has successfully swapped, and if there is a kit.
I was hoping for the classic ā€œ90% good enoughā€ sub swap. I’ve officially aged out of the big-box, rattle-the-neighborhood phase. Unfortunately, I also have the infamous 6Ɨ9 waffle sub.
Did some digging and came across a pretty interesting video. If you don’t want to suffer through the whole thing, skip to 5:41–6:15. Turns out that waffle turd actually vents outside the truck.
Very curious to see how that design choice holds up to Houston humidity over time. 🌧
Ahhhh thanks, I was hoping for a cheap easy drop in replacement.
You don’t want a 6x9 sub. The only way to improve it is to replace with an 8 at least to get the sound of the previous years.
I like the idea of a factory Kicker / Ford sub but not for $800++. That is insanity compared with what you could get other brands for.
Damn! I never found the Ford version price. That’s nuts.
If I can confirm one of the powered subs from Kicker/ RF fit behind the seat that’ll be the way I go for >$500
