8" B&O sub replacement
Would be nice to find a decent single 10" box that would fit back there. I wonder if in theory I could just get this: https://soundsgoodstereo.com/produc...s-all-factory-systems-including-b-o-unleashed
And provide more power to the kicker 8" sub replacement and be happy. This is technically all that is needed, correct, and then you can run the factory sub replaced with more power or do a drop in 8-12" (whatever fits).
If I were spending $1k on that, the factory sub would join my firearms in that crazy boating accident 😂
I haven't seen much talk of people using block off plates for the doors. Both sounds good and MTI make them. I ended up doing Infinity reference in the doors, kicker sub in the original box and a Kicker key door/subwoofer amps. I am really happy with the set up. I initially placed the new door speakers with sound deadening and the block off plates and was really impressed with just that upgrade. It really tightened up the bass, and the amps with the DSP were the icing on the cake. For folks on a budget or are doing incremental upgrades absolutely do the sound deadening and block off plates
I should do this. I did my door speakers with infinity references a few years ago but did not do any plates (not avail at that time) or sound deadening. Makes me want to pull the panels again and get after it.
Its a cheap and easy option. It essentially makes the entire door a baffle. You can find decent sound deadening on amazon. Let us know what you think!
im really interested in the amps, did you do the PAC setup, i hear it's honestly pretty plug and play.
Bumpin... an old thread. Guess I'm going to go ahead and upgrade the tunes in my 25.
Going the under seat route. Ordered a Fox Acoustics box for dual 10's and picked up 2- JL 10TW3s, JL RD1000/1, Stinger 4ga amp OFC install kit today..
Still debating the door speakers and amp.
More than likely some Kicker CS or Alpine Type S in the doors on a JL RD 400/4.
Do you know which Type S you will be using. Based on crutchfield the 2 way coaxial speakers don't fit the rear doors. Also are you running an amp for them or just the factory head unit?
Not quite sure yet. My local guy says they will work. I’m looking at the kenwood excelons. Or some kickers. I may run them unamplified. If not I’ll get a JL RD 400/1 to run them.
Yeah. A 6x9 “sub”. Got that turd here. I have not found any reasonable replacement options. I’m not spending that kind of dough on a sub.
One thing I have not found yet is the stand alone price of the “Kicker Sub” option they had for 23-26. That is literally the only thing I am kicking myself for not adding to my build.
There are a couple powered sub options. Don’t know if they’ll fit behind the seat, or how they sound. It’s got to be better than the stock one.
I know this is a few months old, but I can confirm that the RF Punch P300-10T fits perfectly under the passenger side rear seat of my '24. I didn't love the idea of giving up that space, but the sub has quick connects for everything so removing it is a breeze if I ever need to. I tied the hi input into the signal going to the 6x9 "sub" and tied the remote line to an upfitter. This way I can disable it and the factory sub is still there. Useful when my wife takes the truck or I'm listening to podcast, audible, etc.
Thanks for the follow up! Did you have to remove the factory storage box, or does the RF fit inside?
No worries. My truck didn't come with the factory storage box, but I do not think it would fit inside. The front of the box sits pretty much exactly at the front edge of the seat. I'll try to get some photos later for you.
Here you go. The angle of the box matches the angle of the seat almost exactly and probably chokes off airflow some which may be a problem depending how hard you push it. But I have it turned down really low, just enough to fill in what the factory sub can’t manage.
Oh yeah, that won’t fit in the bin 😔
I’d really like to find something similar that will sit behind the seat. It’s down on the priority list with honey do list stuff in front. Maybe one day I’ll actually do some measuring back there.
MTI Acoustics and Sounds Good Stereo both have behind the seat options and will ship to you.
Thank you. I think I saw another member here that actually installed one. Their price tag is way too steep for me though. I’m just looking to get the Bang & Zero to sound as good as my 10 year old Lariat did (stock). I was planning on going the powered sub box from JL or Kicker.
i’m leaning towards one of the behind the seats options to keep the under the seat storage open. Disappointing since my Ram just had an ok 8” sub in a box stock with a the base Alpine system.
I have the behind the seat MTI, you have to manually relocate a module on the back wall to get it to seat properly. Not a huge deal at all but you need to pull the rear carpeted panel down/ off to do so. It took me a bit to find an install video as I was scratching my head for a while trying to figure out why the box wasn't fitting properly. After going aftermarket, I'm not sure why I waited so long with the B&O, it's night and day improvement.
I have a bass knob installed on my dash to turn it down with family riding along.
How much wiring was needed? Is everything you need back there, or do wires have to get to the front? (If I didn’t do volume) I am pulling headliner and installing Upfitter switches and new roof clearance markers. I would like to run whatever wire/cable I need now.
Here's the start of my installation information, a few more posts after this with more detail. I replaced the factory amp with aftermarket, so wire run to box was about 2ft but i gave myself a few feet of extra wire to lift box out without issue while still plugged in. I think the amp wiring kit came with 25ft of wire which was plenty.
Post in thread '8" B&O sub replacement' https://www.fordtremor.com/threads/8-b-o-sub-replacement.14822/post-526824
Thank you for the help
