8" B&O sub replacement
This one caught my eye. They make a 10” version too. Sounds like it’s basically plug and play for our trucks with the B&O unleashed system.
Anyone have this woofer? I will be adding something in the next few months but not sure which direction to go. Will be replacing the door speakers too and don’t plan on running an extra amp if I don’t have to
If you search the Ford part number VML3Z-18808-A you can find the Kicker kit a bit cheaper -> Varsity Ford
That said, it’s still high dollar and there is limited information on what components they are using.
This looks great. I've been browsing the MTI Acoustics offerings, they have what appears to be a good selection of options.
Box fits well once I found the install video online. I didn't relocate a module and was having issues with fitment which was clearly my fault. Got that sorted this morning.
I would be genuinely curious what the B&O amp, door speakers, sub and sub enclosure costs Ford. Between Black Friday and random sales through out the year, you can piece together a very high quality system for not much money.
I'm super happy with my upgrades, stereo is what I was hoping from the factory now.
I replaced the door speakers as well about 2 months ago. Adding an after market amp is night and day different now; I put in my 4 channel yesterday. The factory amp really limits the range to the door speakers.
Would you just tap into the OEM sub speaker wires? Seems like fairly low gauge wiring harness, I had a Infinity 200 watt RMS in my old Dodge and it was six gauge.
It's fused at 15 amps, so it won't be a big power wire.
Looking at the installation instructions for it, you can use the existing sub speaker wire for the input. The Kicker HS8 has a switch to adapt to either High or Low level input (RCA or speaker)
Damn what's those details.
Picked up most of this during Black Friday deals
JL Audio
  • JD 400/4 powering doors
  • JD 500/1 powering sub @2ohm
  • C2 series 6x9 in front doors
  • C2 series 6.5 in rear doors
  • 10TW3 shallow sub
MTI acoustics
  • Behind rear seat box
  • Half amp rack
KnuKonceptz
  • 2 amp wiring kit 1/0 power, 4 gauge ground
  • RCAs
  • Speaker wire
  • Battery terminals which allow to hook up 1/0 cable directly and expand a post to hook up factory terminals
Pac Audio
  • AmpPRO4 AP4-FD31 interface
Notes:
  • Cutting the drivers side grommet nipple wasn't easy using a utility knife, maybe recommend just holding a razor blade
  • When running wire through firewall, use a 3ft zip tie instead of coat hangar like lots of videos recommend
  • I used the factory ground on drivers side rear of cab for both amp grounds. I removed the factory ground and used a wire wheel to sand down the paint to make the spot a little larger.
  • Used the 1/0 ground cable in the kit to hook my passenger side battery to the factor ground spot to make it more robust, wire wheel again to ensure large connection spot
  • Updated the chimes in PAC to 25 volume as the initial chimes were very loud
  • Installed bass knob to left of steering wheel, very much needed to lower when kids are in back seat
  • Watch MTI sub install video to ensure you relocate the module on rear wall so sub enclosure fits correctly.
  • There is a small module on drivers rear seat, back of it. Perhaps a heated seat controller. I relocated it slightly as it was bumping into one of the amps, used self tapping metal screw to move it about an inch in same spot.
  • Remember to remove some of the factory studs where original amp was, this ensures sub enclosure sits properly.
  • Drink a few libations to stay hydrated
While I understand the need to save money and/or space, a second amp makes a night and day difference. I've always had two amps and highly recommend it. You will thank me later 😁.
Yeah I know. It’s just that 80% of the time I’m listening to podcast and books or something. 20% is music so I just don’t see the “need” for MORE POWER although I 100% agree a amp for new speakers would be ideal
In that case, I agree too!
I'm opposite of this, when I listen to music in the truck by myself, it's my "quiet time" and I listen to a lot of different styles of music with a lot of range. I'm impressed by what the subtle difference of an amp and decent speakers can make in the overall scheme.
High frequency hearing impairment is a fact of life for me so having a better low-end response is essential in my case, the amp flattens out the low end roll off of the stock amplifiers so I can enjoy what I can hear, even better.
Seems like might be overselling. The 10”
also has a 15 amp fuse and advertising 180 watts RMS which by my math is exactly 15 amps.
Probably closer to 13..4 amps, but I get your point. That’s also at max volume.
You are correct. Fun with numbers.
180 watts RMS in speaker land is just an average power of the amplifier output or speaker input at which a speaker can operate within a specified distortion/efficiency at a continuous input/output. (The ideal sweet spot) An amp output level capabilities are based on an internal power supply which develops the current necessary to achieve an output but does not produce a flat continuous level greater than the power supplies capability. This is why a peak power level can exceed the standard output for short periods. The signals developed draw from that internal power supply. The power supply is limited by the max draw based on the voltage and current of the 12V source and the current demand to produce the signals. In some cases, an external added capacitor at the end of a long power cable can be added to supply instantaneous impulses, which is why a capacitor improves the lower end response considerably.
Typically, a manufacturer will tout their spec for comparison purposes and not disclose their own special formula, which includes a power factor calculation for efficiency, frequency response, or heat dissipation, etc. Most reputable companies will usually base the number on some standard frequency such as 1 KHz at a specified impedance (or perhaps 100Hz for a sub) or distance to a microphone for a speaker. But some may use a different frequency "more applicable" to the particular component" tested.
This is why an amplifier can say it will produce 180 watts RMS and be fused for less current than seems normal based on just Ohms law.
If something is fused at 15A, the average system draw will typically be in the neighborhood of 7-10A max and possibly peak higher. The rest of the "spec" is the manufacturers calculations which can vary from one manufacturer to another.
Total power is the root of the sum of the squares for all frequencies present, not just an RMS value which is based on a pure sinusoidal waveform.
This is the AVERAGE power which can be measured as a heat measurement using a thermistor or calculated with a complex diode sensor. Other waveforms that are not sinusoidal can also be measured in this manner.
Some speaker manufacturers may actually be using the average power as a spec, not RMS, which is actually closer to actual power.
It's fun with numbers. Probably best to go on reputation rather than an advertised spec.
Awesome Thanks Canyon Trekker. Always good to learn something new!
Yeah. A 6x9 “sub”. Got that turd here. I have not found any reasonable replacement options. I’m not spending that kind of dough on a sub.
One thing I have not found yet is the stand alone price of the “Kicker Sub” option they had for 23-26. That is literally the only thing I am kicking myself for not adding to my build.
There are a couple powered sub options. Don’t know if they’ll fit behind the seat, or how they sound. It’s got to be better than the stock one.
Well dang-it, got the same in my truck. Well, if anyone finds a solution that fits behind the seat, either in lieu of the factory sub or in conjunction with, please post up.
I believe one of those Kicker powered subs would fit. Have not measured the space back there yet. Too many other projects in front of me at the moment.
With all the penny pinching Ford did in the current gen truck, why not just ditch a sub completely and say it’s an option. Putting a rat turd size and shape speaker back there is BS.
Would be nice to find a decent single 10" box that would fit back there. I wonder if in theory I could just get this: https://soundsgoodstereo.com/produc...s-all-factory-systems-including-b-o-unleashed
And provide more power to the kicker 8" sub replacement and be happy. This is technically all that is needed, correct??, and then you can run the factory sub replaced with more power or do a drop in 8-12" (whatever fits)??
