I originally went the same route with a 8" Fosgate P3SD4-8, 4 ohm DVC sub and JL C1-690x 6x9's in the front doors. I sealed the factory sub box port, lined the exterior with sound deadener and filled the box with poly-fil. The results were definitely better sound from the door speakers, but the sub made the factory bass roll off even more prevalent to me.
So I decided to go with a Sounds Good Stereo harness that will fix the bass roll off and a dedicated Fosgate R2-250X1 sub amp and a 8" Fosgate P3SD2-8, 2 ohm DVC sub that I could wire into a 4 ohm load to better match the amp. The harness is supposed to be ready by tomorrow, and I found out that Sounds Good Stereo is located about 15 miles from me, so I'll be driving over to pick it up.
I threw the jack in the underseat storage and removed the bracket. Welded up an amp rack that reused the jack bracket mounting bolts. Ran a 4 AWG positive from a spare stud on the battery bus, installed a 50A inline fuse and used the factory chassis ground on the back of the cab to power the amp. The new harness will provide the remote on power. I ran the new 4 AWG through the fire wall boot by cutting an "X" in the little nipple part and ran a plastic fish tape from the outside in. The power wire runs down the passenger side to the back of the cab. Routing the wire was surprisingly really quick and easy.
I also added push terminals to the factory box for the speaker wire to connect to. Mounted the amp remote level control in the center console.
I still have to fabricate a couple of shields made from 1/8" ABS plastic to put under the amp to serve as a wire guards in case a power wire ever comes loose.
I'll report back on how this set up sounds. I'm not looking for some competition sound here, just a decent low end to complete the sound. If I can get this POS B&O to at least sound as good as the factory Fender system that was in my previous Titan XD I'll be happy. Ford's idea of a "premium" stereo is an absolute joke......our '23 Bronco B&O system sounds equally like complete trash.....
