8" B&O sub replacement
Did you do rear door speakers yet?
No, I haven't done them yet. I was trying to decide if I should do them it but it is really just my kids and their friends that sit in the back so I decided to wait for now. Another reason I like the bass adjustment knob so I can turn it down when needed.
Just to update you guys, I got the aforementioned sub with 180-watt amp, door speakers, and tweeters replaced and really enjoy the sound. It is hard to quantify the bass but I would say it is definitely much much better than stock. Maybe 8-10X better than stock bass and the clarity of adding the new front speakers makes a huge difference. Obviously this setup is not going to win any bass contests or rattle your mirrors (it does come with a remote adjustment knob though) but it is a huge improvement. I now really enjoy the music in the truck. After looking at the removed speakers, the quality is very poor. Polymer housings and cheap cardboard cones. Ford really did skimp on the sound components. Here is a pic of the stock components that were removed and new sub in place.View attachment 119735View attachment 119736
How did you mount the sub? Assuming it came with brackets or did you have to make your own? This might be a new product opportunity for #builtrightindustries to make for attaching these types of subs to.
I did infinity references a year or two back with harness from Crutchfield and it makes a decent upgrade. The system as a whole is more efficient it seems like
It has these little brackets that we just screwed into the cab liner, nothing fancy, it would be nice to have a more secure mounting option from Builtright for sure
Nice! I am sure I will end up doing it later on. I always tend to rationalize why I don't need to do something and then weeks to months later, I end up doing it anyway. This will most likely follow suit.
I went this route first myself with a Kicker subwoofer. I wasn't happy with the outcome. I ended up doing the JL Audio single 10 stealth box and it really sounds amazing. Worth the extra $600 bucks to have true base in the truck. Deep, hard hitting and still plenty of space. I used the Kicker 47KEY500.1 which will adjust to your stock system so you wont lose bass as you bring the volume up. Either way I am very happy I spent the extra few bucks on quality sound.
Does the stealth box fit in the same place as the OEM one on the back wall? I don't want to lose storage under the seats. If so, do you have a link for the box part number?
I am interested to hear more about this as well!
So to get back somewhat on track.
1. The poly fill helps.
2. The fill with the sub helps more.
3. A whole new box helps even more.
4. If you use an adaptor along with #3 to take the lows off the door speakers it helps the most.
Does this sound about right?
Jl goes under the seat.
I have this from my old 2004 SD. I wonder if I could wedge it in between the front and back seats in the center and still have access to the rear seat controls?
I looked at the JL under seat box, but looking to keep my under seat storage. Still on the hunt for the right solution for me.
Well, looks like this is going to be added to the list now for the shop truck. Good work, guys.
Well, thanks to this thread, I am now the new owner of the RF Punch speaker.... Question is, how do I need to wire it up? I've done basic audio upgrades before, like door speakers. But when it comes to subwoofers, I've always left that to the audio techs. I know that this is a 4ohm DVC, but there are multiple ways to wire it. This photo is from the instruction manual. I just want to make sure I do the correct thing, so I don't ruin the sub or amp.
Snip the two factory connectors with positive and negative for each plug. White and black are negatives. Red and green are positive. Just strip a little bit of wire, push in the terminals on the sub, and place the wires in each terminal. Once you see it is real simple. I'd say the most difficult part for me was trying to find the screw holes to align. They didn't so I just made new ones.
Snip the factory connector with 4 wires. White and black are negatives. Red and green are positive. Just strip a little bit of wire, push in the terminals on the sub, and place the wires in each terminal. Once you see it is real simple. I'd say the most difficult part for me was trying to find the screw holes to align. They didn't so I just made new ones.
You were right. Once I removed the sub and saw the wiring, I knew what to do. Seriously only takes a few minutes. I used one of my wife’s spatulas to push polyfill into some of the smaller valleys. If anyone is wondering about the wiring, here is a pic of what the OEM sub wiring looks like.
My memory must be be bad. Il change my post to two connectors with two wires each. The install was so quick I remembered only cutting one connector.
Does anyone know if Crutchfield offers the wiring harness for this sub so you don't have to cut off the factory connectors?
not sure about that, but you don't HAVE to cut em off. i used a small finishing nail to lift plastic latch and remove the pins from the plastic plug. i just plugged those pins into speaker, the lugs are spring loaded and they held the pins just fine. actually probably better than bare wire cuz the pins have notches and whatnot for the lug to grip onto.
