8" B&O sub replacement
Ha! Same... I was MECP certified back in the 90's and used to build systems for myself and friends all the time. Won a local single-woofer IASCA competition with my Firebird (that I had actually built for Sound-Q!), and in the winter rolled around in big body early eighties sedans (Crown Vic, New Yorker, etc) that would make the ground shake. No wonder I can't hear shit these days...
I think my best was 153 dB... Used to build my own boxes.
I used to LOVE building boxes, and playing on the computer designing theoretically "perfect" response boxes using less than top-flight woofers. I had some saved that had dimensions that would have taken up half the space in my bedroom, and may have only barely fit in a van. LOL
UPDATE.. So I added these up front, took about 15 mins a side and added some sound deadening to inside of doors. Very nice upgrade, so much more clarity.
If you order from crutchfield they give you the speaker rings and wire harness to plug into factory for free.
View attachment 118951View attachment 118950
Looks like a sub, sub amp and door speakers will be added to my to do list.
😲 That's insane! Anything over 140 is considered dangerous, a fighter jet takeoff is 150dB. (I was there...)
Must admit, I too used to build boxes and calculated the box size and dimensions. Only I did them for house stereos on a smaller scale. My favorite style was the older Infinity speaker towers. Still have a pair I built 40 years ago and still sound great. Though, I have blown a couple tweeters. No wonder I can't hear anymore. :ROFLMAO:
:LOL: Now look what you've done... I have to spend more money on this truck. Great find!
I'm paying for it now in my 40s unfortunately, I have some hearing loss and developing tinnitus
You are killing me - I was looking for a simple drop in solution to clean up the audio a bit and give it more punch without spending a ton or adding extra amps. Sigh...another thing to add to the list!
There is a setting in the system. Your max volume may be set at halfway. Mine was from the factory and so was my buddies.
I am interested in this setting as well. If you don't mind me asking, where did you find it @DwnSth?
I forgot what it’s called, but I thought we needed that module to connect to the B&O system in-between the aftermarket amp. Unless that’s only if you use the OEM amp without an aftermarket.
I was curious about this too. When pricing out systems with MTI in College Station, they said I would need the AudioControl LC2i line out converter when I was thinking about putting 2 10's behind the seat.
What kind of sound deadening did you use?
For this single Sub its just adding an unnecessary item. Not to mention more noise with that additional component. You would need it if your amp didnt have a High Level input or you wanted to go to Dual amps..?
It seems too often when guys ask "Can i replace the B&O sub" they get this long diatribe from very smart audiophiles about ohms and how to spend $8000 on a new system. I am NOT here to say that the previously mentioned info isn't helpful and also appreciated, I am here to give you guys the simple answer. Yes, you can take out the B & O sub, put in the Rockford P3SD4-8 and it simply works.
My opinion, it is BETTER than the stock sub on the stock amp.
On some songs it sounds the same, on some songs (frequencies, i guess) it sounds 50-75% better than stock and is quite noticeable.
Thats all, it was very straigtforward, white wire and black wire are negatives, cut off the small alignment knob with a razor knife, drop the new sub in and let it roll.
PS. I did, on the advice of another member seal the small port in the bottom to make the enclosure "Sealed"
I can second all that, swapping out sub makes a BIG difference. Still doing some tuning because the enclosure is somewhat flimsy.
add poly fill, seal off the port (might try porting on top), run some bolts front to back to stiffen up... maybe just design a box that fits now that I have the proper speaker.
This ZEN is specific to Ford B&O setup. They also have stuff for the other guys.
I would be hella happier if the damned stereo would just play louder. I think there has to be some nanny oversight reducing the maximum volume. It is literally the worst of any of the 9 vehicles I own.
Yes, I like it loud. Yes, my ears already ring. I grew up in the '80's going to metal shows. No, I don't want Ford protecting me from myself.
The ringing started for me after Monsters of Rock 91 at Finthen Airfield. I don’t regret a damn minute.
Welp, hate you guys, I ordered the sub, sound deadening, polyfill, and the SoundGoodStereo sub to speakerwire connections. Mainly bc I think this is a temp solution and will probably need these anyway.
