8" B&O sub replacement
I tried using the Kicker 48CWRT84 which is a shallow mount 8 inch with dual 4 ohm voice coils. It had decent sound, but it felt like it was touching the back of the enclosing and causing a rattle. That was just holding it in place. Almost seemed like the outer ring was too small to be able to screw it into the enclosure, so I put factory one back in for now. Anyone else use the Kicker and it worked okay?
Add another one, ordered from Crutchfield, the Rockford sub and JL 6x9 for the front doors. Got em in the ''scratch and dent'' section. 298$ plus tax shipped. I'll use these pts plus what I already have and get something for the rear doors, maybe 100-150$.
It's been a while, and no complaints. Sounds great, no rattles. I manufactured a spacer out of a piece of 1/2 inch plywood. I also added external terminals to hook the Kicker amp up so I could remove the sub box if necessary.
I should have my Poly fill arrive any day now and that was my thought to try first. I will advise if some else does not first.
Did you try this? Results?
Just installed the 8" Kicker with the Key amp. I cut the leads off of the factory subwoofer and wired them up to rca via a Kicker kisl. For some reason, when I plug in both RCA cables to the amp, there is no output from the sub. One RCA cable provides sound though. When I try to do the key setup, the sub cuts out and doesn't come back on. Does anyone have any pictures of how they wired the input to the key amp? I'm guessing I messed up somewhere.
Here's some pictures of my install, I pulled the wires out to photograph them. The wires from the sub are Red, Black, Green, and White. The red and black are a pair, black is negative; The green and white are a pair, white negative. These will connect to the Key amp: gray wires to red and black, White wires to the Green and White. The stripes on the Key wires are negative.
I soldered an RCA receptacle on the sub wires to make it more convenient to plug in and remove if necessary. I also added an RCA cable to extend the reach so I can tuck the wires behind panels. (It was the shortest one I had at the time) You may not need all the extra wire depending on your install.
As always, hope this helps.
After watching this thread, I talked to my local stereo guy and have an appt for this Friday to have a Kicker Hideaway HS10 sub/amp (low profile behind the seat) along with Alpine 6x9 front door speakers and tweeters to be installed. 869.00 out the door, I will report back on how it sounds. Like nearly all of us, I want better sound but don't want to give up storage.
Well… how did it come out?
I have really been happy with the sound. Here are the links to the update and build thread. It was perfect for what I was looking for! Hope this helps
Thanks for the pictures. I had mine wired up almost the same. Went ahead yesterday and ordered a harness from Sounds good to pull from the high side so I would have more range.
It seems too often when guys ask "Can i replace the B&O sub" they get this long diatribe from very smart audiophiles about ohms and how to spend $8000 on a new system. I am NOT here to say that the previously mentioned info isn't helpful and also appreciated, I am here to give you guys the simple answer. Yes, you can take out the B & O sub, put in the Rockford P3SD4-8 and it simply works.
My opinion, it is BETTER than the stock sub on the stock amp.
On some songs it sounds the same, on some songs (frequencies, i guess) it sounds 50-75% better than stock and is quite noticeable.
Thats all, it was very straigtforward, white wire and black wire are negatives, cut off the small alignment knob with a razor knife, drop the new sub in and let it roll.
PS. I did, on the advice of another member seal the small port in the bottom to make the enclosure "Sealed"
What did you do to seal the port on the bottom?
Added fill and the Rockford sub. Must be getting old I don't hear a difference or maybe a little less bass.
Just did this 8" Rockford Fosgate sub install. Wrapped the exterior of the OEM box in some Dynamat, filled the interior with a bag of polyfill and covered the open port to seal the box. Honestly, pretty darn impressed with the results for under $200 and maybe 30ish minutes it took to complete. Will for sure be adding dynamat to the doors and back wall. Likely throwing in some upgraded speakers too while the door panels are off. For the time and minimal amount of money, this is a pretty good upgrade over the stock subwoofer.
What did you do the cover and seal the port in the box?
I changed out my door speakers last night with the JLs. The first door took about 30 mins and the second like 10. With the right plastic trim tools, it was about the easiest speaker install I have ever done. I was pleasantly surprised at how easy the electronic clips for the windows, lock/unlock etc came out too. They are usually the worst. I want to replace the sub next, but I would really like to put a 10" in there. Does anyone know if the RF 10" will fit in the OEM box?
The 8" RF sub barely fits. The 10" will likely need a larger box with more airspace. A few companies due make 10" boxes that fit behind the seat, but you'd likely also need an amp to power it. The OEM amp powers the 8" RF, but only so well. They really do crave a bump in power.
Yeah, im probably gonna just stop by an audio store today and see what options they have for behind the seat. I can see myself liking the 8" for about 2 weeks and then wanting more
Went by an audio store today and they suggested one of these down firing loaded enclosures from kicker. The dude literally jumped on top of it to show how sturdy they are. I have 1, soon to be 2, carseats my backseat and this will work perfect on the floor beneath them because the carseats aren't going anywhere for a while. They are super easy to unhook too in case I need to pull it out.
Do you know if my poverty lariat has the 8" sub? Id do this mod if I do! Inused to do SPL competitions
Just to update you guys, I got the aforementioned sub with 180-watt amp, door speakers, and tweeters replaced and really enjoy the sound. It is hard to quantify the bass but I would say it is definitely much much better than stock. Maybe 8-10X better than stock bass and the clarity of adding the new front speakers makes a huge difference. Obviously this setup is not going to win any bass contests or rattle your mirrors (it does come with a remote adjustment knob though) but it is a huge improvement. I now really enjoy the music in the truck. After looking at the removed speakers, the quality is very poor. Polymer housings and cheap cardboard cones. Ford really did skimp on the sound components. Here is a pic of the stock components that were removed and new sub in place.View attachment 119735View attachment 119736
Hello Rodd Was there any engaging else you needed to get to connect that 10” to the system like the advertised ? I’m thinking about getting this sub now it is on sale at critchfiled for under 300$ today
Kicker 46KISL
Remove
Save
Kicker 46KISL​
2-channel speaker wire adapter (bare-wire connector to RCAs 19.99
