7.3L spark plug/coil wire failure
What would be a good code reader to leave in the truck for just this purpose?
Thinking I should keep a couple wires and a code reader on hand just in case.
Yep. That's what I do and it's paid off.
A B or C? Can anyone identify my wires?
Edit: researching some more and the final letter “B” seems to be my answer. The pictures seem to match what is sold online as the “B” revision. Wondering how this is possible if @torino420 got his in September of ‘21 and mine was a December ‘21. Didn’t have any big delays in build or transport. Not like it sat at the racetrack for 6 months. Interested to see what feedback you guys have.
Right. So have they started putting these wires in the newer 7.3’s? If so, trying to figure out when.
i'm not sure. but here is a pic of the new ones from an rv forum.
the new one is the one with the bigger heat shield (bottom)
And mine don’t match either of those. I see the “LB” part on that picture you posted and mine are “MB”. My metal insulators also have a raised tab at the top of the 90 degree bend. Maybe there were multiple “B” versions created before the “C” versions arrived. Or possibly just a different part for the motor homes vs our trucks.
interesting.
i was under the impression that the motorhome and truck engines used the same wires 🤷🏻‍♂️
the dealer parts department should be able to tell you which wires your truck was built with
Went ahead and ordered a set of the "C" wires today as backups. I haven't noticed any issues with the originals but you don't want to get stranded out on a trip.
Rock Auto has them under the Motorcraft part #WR6167 for $12.18 each.
i'm not suren, but here is a pic of the new ones from an rv forum.
Dam
Damn, my 2022 that was delivered in april has both types. just checked and i have been experercing "the smell" and stubbling from redlights. stop signs, ect. on occasion .
I have the OBD MX+. Bluetooth is fine for this but I also have the wired EX which I use for Forscan:
"LB" and "MB" are suffixes from engineering part numbers. They can both exist in production at the same time. The first letter of the suffix indicates usage with a different function, design, application. The second letter always supercedes the previous. An MB superceding an MA, for instance. MB doesn't necessarily supercede LB, though... Note that the service part numbers and engineering part numbers don't always match. Service part numbers only have one digit, start with "A" and increment any time a new release is required. So "C" just designates it is on the second revision for service.
My truck also has MBs and was built last August...
Always good info @Modman. Thanks for the explanation!
