Still waiting on your Firecore plug wire report sirBecause I had an early truck and the idle was rough. If you're not having issues, run stock.
Bump. Would like to know if the firecore wires are a better alternative to factoryStill waiting on your Firecore plug wire report sir![]()
I had installed my new aftermarket wires back when I first got the truck back from the dealership. Their warranty work concluded that there were multiple misfires and they stated they found no issue with wires, cleared codes and suggested that there was still a “slight” (LOL) misfire occurring they could see on their analyzer but that it was not tripping the check engine code…Bump. Would like to know if the firecore wires are a better alternative to factory
I had heard of it but did not get it at all! No issue whatsoever with them to date, I’ve gotten about 4,500 miles on them and no issue.Have you gotten the burning plastic smell from the Massive wires yet?
Well, if anyone wants a set of never used Massive wires, PM me. I don’t think I will need them on the 6.7LI had installed my new aftermarket wires back when I first got the truck back from the dealership. Their warranty work concluded that there were multiple misfires and they stated they found no issue with wires, cleared codes and suggested that there was still a “slight” (LOL) misfire occurring they could see on their analyzer but that it was not tripping the check engine code…
I’ve subsequently got the truck back and frankly could just hear what seemed to be a slight misfire /roughness while idling… at that point I just replaced with my new after market “Massive” wires and instantly the idle sounded better. No codes since and truck running perfectly.
I tinkered with the idea of putting the factory wires back in and letting them fail again but frankly I hate the notion of waiting for FORD to correct this issue with a permanent fix.
Seems obvious the wires were the problem in my case as this all started with about 800~ miles…
Now over 5K and no problems since.
Towed a large piece of EQ recently and truck handled that perfectly.
Very happy with the Godzilla overall, and care less that it’s averaging 12MPG…
Love the response and feel of the engine, I’m a diesel guy but just wanted one more gasser in my corral…
I don’t think the heat shield is going to help much. My experience was that the high rpm when towing up grades created higher ignition voltage (+40kv) which generates excessive heat from inside the plug boots. My Massive wires literally melted from the inside out. Failure was always at the wire connection to the plug. Hopefully the new C type stock wires are more robust than original or aftermarket wires. I could not wait around for Ford to fix it so I went to the diesel.Wasn't there more post or maybe another thread for the wire problems? Can't find it.
Also can't believe people pumping those massive wires that are complete garbage.
Burnt smell within 100 miles and constant random misfires one weekly basis after about 1-2k miles on them whenever wot pushes heat through the exhaust manifold.
Anyhow. Just put in the C type wires and hoping they resolve the problem.
May look into the lavawrap/heatshield one day if I get bored or have time.
I swear I posted all about the problems somewhere around here. Another thread that was over 10 pages??? Seems to be gone?I don’t think the heat shield is going to help much. My experience was that the high rpm when towing up grades created higher ignition voltage (+40kv) which generates excessive heat from inside the plug boots. My Massive wires literally melted from the inside out. Failure was always at the wire connection to the plug. Hopefully the new C type stock wires are more robust than original or aftermarket wires. I could not wait around for Ford to fix it so I went to the diesel.
www.heatshieldproducts.com
RnR 3x+ times. 1st was just the "bad" wire on cylinder #2 after going into limp mode on side of cliff towing my TH. 2nd was for massive wires. 3rd was back to stock "a" wires to return the massive and eliminate the constant random misfires and cel resets. Lastly was to "c" type wires. Never went through wheel well as I ordered it with plastic liners and such. 1st RnR was a pita. Last one yesterday I could practically do with eyes closed as I use feel to find the plug and guide wire boot at same time. Was done in less than 20 minutes. Just have to double check they are fully snapped on and locked good, both to coil and plug. GLSo I installed a set of the Massive wires because I was having issues with random hard start after a very hard cross country drive pulling my camper (2200 miles in 2.5 days) and rough idle since purchasing in 2021. It was a pain installing the passenger side wires, like sticking your hands down a piranhas throat. Didn’t really help with either and after pulling a uhaul up through Virginia Dale, CO noticed a rubber burning smell, no faults so I guess it’s just a lot of heat from the manifold on the wires. Ford Dealership in Laramie found not codes and no melted wires. I have 22k miles with a 01/20 build date. Thoughts?
After replacing plugs 5 times on various CO mountain passes, it did get pretty easy though cylinder 4 always gnawed my hands. When the battery boiled over 50 miles from a cell tower in the desert north of SLC (+100F), I was just done with Godzilla. Got 22k on the 6.7L since end of July, 17k towing, no complaints with King Kong.RnR 3x+ times. 1st was just the "bad" wire on cylinder #2 after going into limp mode on side of cliff towing my TH. 2nd was for massive wires. 3rd was back to stock "a" wires to return the massive and eliminate the constant random misfires and cel resets. Lastly was to "c" type wires. Never went through wheel well as I ordered it with plastic liners and such. 1st RnR was a pita. Last one yesterday I could practically do with eyes closed as I use feel to find the plug and guide wire boot at same time. Was done in less than 20 minutes. Just have to double check they are fully snapped on and locked good, both to coil and plug. GL
I can deal with a few issues and work out the kinks. With all the maintenance cost (trade off) of the diesel I could buy a new crate 7.3 and such when that time comes. Or maybe just do a bulletproof rebuild???After replacing plugs 5 times on various CO mountain passes, it did get pretty easy though cylinder 4 always gnawed my hands. When the battery boiled over 50 miles from a cell tower in the desert north of SLC (+100F), I was just done with Godzilla. Got 22k on the 6.7L since end of July, 17k towing, no complaints with King Kong.
