7.3 to lose 40 LB FT of TQ and 10 HP for 2027
Since E.T.'s valid query... I done Go0gle'd it but scaled up the issue:
It's reply:
Cooling a fully loaded 80,000-pound 18-wheeler climbing a steep highway grade in high ambient temperatures demands an incredible amount of energy. [1]
  • Horsepower demand: A massive semi-truck cooling fan can require anywhere from 20 to upwards of 40 horsepower just to spin at full lockup and pull enough air through the restrictive radiator, air conditioning condenser, and charge air cooler. [1, 2]
  • The electrical bottleneck: Generating 30 horsepower electrically translates to roughly 22,000 watts (22 kW) of electrical power. On a standard 12-volt truck electrical system, a fan of this size would draw an impossible 1,800+ amps. Even on modern commercial 24-volt systems, it would require nearly 1,000 amps. [1]
  • Alternator limits: Standard commercial truck alternators are typically rated between 150 to 300 amps. To power an electric fan of that scale, a truck would need an alternator the size of a small generator, massive heavy-gauge copper wiring, and highly complex cooling systems just for the electronics. [1]
Not sure how much concern I'd put into Fords numbers, only way to know for certain will be for the 27+ guys to get dyno'd. Seems like the 23-25s regularly put down 400ish lb/ft peak torque.
I cant seem to find it, but I do recall seeing one of the tuning companies post that the 6.8 minizilla actually out did the 7.3 stock and tuned when they dyno'd it. Maybe the power change accompanies them dropping the 6.8 and were just getting a more honest answer now. The numbers for the 27s are essentially the same torque rating as the outgoing 6.8. If those were the numbers they listed for prior years, where the 7.3 option was 1-1.5k more, the lower trims would have sold a lot more 6.8s I imagine.
"Maybe the basement gremlins are furiously figuring out how to put electric fans on the HD trucks before they go live for orders.
Truth be told, it’s 2026. Almost 2027. Is there really a need for an engine driven fan?"
This would be an interesting change since the load would now be on the alternator vs. the drive train. Still requires energy, but the question would be which would be more efficient; electrical or mechanical. It would still require the same energy to turn the fan which would convert from mechanical energy of the alternator. Drive train mechanical is clutch driven direct, electrical is a conversion. (Guaranteed loss of energy.) But could afford a difference in the "stated" HP/torque. A definite play on words.
The air flow volume for cooling should remain the same in either case. If they make this a future change, it will be interesting to watch. Perhaps a more efficient fan?
I think I figured it out. If the numbers are right. A commonly reported (but not verified) volume for the stock fan is around 10,000 cfm at full speed. In order to get close to that, I’ve found fans that would need 60 amps to do it. It would take four 16” ECM fans. There just isn’t enough room!
My buddy has a good point he said “remember when the 2026 F-150 page was launched and it showed the 3.5 EcoBoost at 380 HP for a few months” and he’s right. They had that figure displayed and then quietly reverted back to the J134 standard with premium fuel (400 HP/500 LB FT) once trucks started shipping. It’s likely Ford will return to the premium fuel rating shortly at 430/485 and just add the little * keynotes like they did with the EcoBoost. It might be a nothing burger.
The 3.5 EB is 380 HP on 87 octane, and only does 400 HP on 91 or higher. It seems the 7.3 was also tested on 91 per the footnote on the 2026 specs. The footnote on 2027 says 87 octane. They just need to revert back to the premium figure.
I think I figured it out. If the numbers are right...
Well, lemme know mkay.
I've got a box of old semiboloid stator bearings left over from my time spent testing various marzelvanes' design.
Ahh... n/m they could be contaminated with some potent dust from decaying translateral duractance.
We could add maglev bearings. Our compressors spin at 40000 rpm on them.
But then people would complain about the price of the truck. And the $3000 fan bearing replacement 🤣
Or just take a trip to the dragstrip and compare 1/4 mile trap speed to a '26. :p
My brother had a 383 TBI with a Taurus two speed fan, and my buddy had a 454 TBI with a Taurus two speed. Both did fine for crawling but I wouldn’t recommend them for towing or hauling. My 8.1 and 6.4s had huge mechanical fans that had electronic lockup that was very evident in power loss and noise and cooling when towing very heavy uphill. I just don’t see an electric fan cutting it on trucks that are marketed to gross over 25klb. Not to mention, a mechanical fan is pretty simple even with a clutch.
https://pickuptrucktalk.com/2026/08/2027-ford-super-duty-drops-6-8l-v8-cuts-7-3l-torque/
Supposedly this guy reached out to ford and this what a super duty marketing manager had to say.:
“We’ve updated the 7.3L engine to ensure the Super Duty remains compliant with the latest environmental standards. While this resulted in a minor adjustment to peak output figures, the 7.3L remains a leading gasoline engine in terms of displacement and real-world work capacity. It continues to deliver the performance that Super Duty customers expect including best-in-class payload.”
That’s interesting. And also curious as to how the BGE 6.4 Ram and Gen 6 SBC 6.6 GMs with the same 14k lb GVWR won’t have the same or better payload. I would assume it’s a very specific configuration. (When I was shopping the loaded GM 2500 had a much better payload no matter which engine but I think Ford beat on some configurations.)
Thanks, I had just watched this video and was going to post it as well. Seems to confirm that a change was made to "update" the engine.
Aluminum body work - everything but the block, axles, frame and firewall on the Ferd.
Did GM start doing this? I wasn't paying attention! :unsure:
As thin as the steel is on the Ram/GMs I doubt there’s much weight savings. Rams also have aluminum hoods and other components. Not sure about GMs. It can’t hurt and maybe makes a possible technical win by a few pounds but I bet the Godzilla is heavier than the other two engines. It is really good from a corrosion perspective but I bet dry weight is still pretty darn heavy. Hummer H1s had aluminum bodys and fiberglass hoods. So do Kenworths, neither are light.
I would guess any gas payload in a specific class is similar and any diesel is similar. There may be winners but ultimately on lighter classes it really depends on factory GVWR ratings. Base F-250s even diesel gets a lousy 10klb rating. GM 2500 diesel ATX4s are almost F-350 Tremor GVWRs, and Rams are in between F-250s and F-350s at 11,100 lb. The only common ground is duallies at 14klb. (Where the F-450 is the clear loser which sucks they didn’t do the Cab and Chassis GVWRs)
We have literally had to send F-250s back to our leasing company at work due to low payloads (non 10k GVWR packages which we do request for our gassers.) We didn’t have that issue with GMs. Our policy now is only F-350 for diesels.
Oh. Well, that would be an issue, yes. I see.
My gasoline Godzilla Tremor F350 has a GVWR of 11,499. It also has a "payload"/Combined Weight of Occupants and Cargo should never exceed" of 4,445 lbs which is amazing to me.
My truck may be "apples" to your scenario's "oranges" but thought I'd share, anyway. Thanks for the other details on how RAMs are built. That's interesting. Cheers!
I do agree that’s a great payload (much better than my 3400 lb F-350 diesel) and likely better than specific GMs and Rams. I just think payload is one where they can put their thumb on the scale, if you will, by adjusting GVWR (they all do it so it’s nothing negative against Ford.)
The high capacity axle (standard on Tremors) makes a huge difference on F-250s. Obviously not common on off the lot XLs.
My Ram Power Wagon had a ridiculous 8510 lb GVWR despite being the same as the 11klb GVWR 2500. If you look at the new Power Wagons, it’s still the same, the diesel has 2,500 lb more capacity despite the same frame/axles. They blame the tires and and “soft” suspension. The suspension basically had Bilstein 4600s instead of no name OEM. The tires had well over 3k lb weight ratings.
