7.3 to lose 40 LB FT of TQ and 10 HP for 2027
While i like the idea too, isn't the 7.3 also marketed as being super simplistic cavemanish motor, i mean that's why it's pushrod and everything no?
One of the huge reasons I bought it to begin with.
With the new figures im in agreement, ditch the big block. You are getting sub small block torque now out of a big block package with big block fuel consumption. Bring back the 6.2 Boss and drill baby drill. Give it some bore.
The Boss family is well equipped to pick this up and offer better emissions with the dual spark plugs. Same bore spacing as the 7.3. Switch to a Siamesed bore, up the compression, enlarge the intake valves. Make a 7.0 Boss Cammer!
That would be cool, but the sohc is the drawback.
It can not do what the Coyote does, which is change the valve overlap. It can narrow it to almost nothing for maximum compression and torque, and then open it up for high rpm screaming.
Nothing else made in these here untied states is comparable.
Germany and Japan have some exotic v8s that can do it. but nothing made here can. Coyite brought that awesome tech to the "every man". In keeping with Ford tradition.
That's the difference.
Germany has some exotic v8s that can do it. but nothing made here can.
Some of us consider that huge complexity a downside.
i'd argue they do it for many reasons, but the 5.0l is more of a revving motor even in the F150s and that's just not good for heavy loads and "chronic" abuse that the motor is intended to endure.
  • Compact Block: The 7.3L uses a traditional pushrod design, keeping the physical outside dimensions smaller while packing a much larger displacement inside.
  • Simplicity: Fewer moving parts at the top of the engine mean less complexity and easier fixes for commercial use.
  • bigger displacement is meant to low rev with bigger grunt, i bet if it would hold together and you truly revved that thing out it would make big power it's just making power lower in the rpm band and meant to just be abused.
And others like myself have lived with them for years and had ZERO issues.
I've owned 2 of them. Sold the 2011 gen one at 290,000 flawless miles.
Traded the 2023 gen 4 for my super duty. only because i need a bigger truck than a half ton
i mean with the return of the 5.0 in the higher trims, kinda want to consider a KR 5.0l maybe in 6.5' bed configuration (ordered a 2013 F150 ecoboost that way years ago), do a suprecharger and just let her eat!
Yes they Rev. but they can also chug pretty damn amazingly for their size and stroke length.
Remember, you're comparing an oversquare 5.0 to an undersquare 6.2.
Scale up the Coyote, and nothing else will come close.
You would NOT be disappointed.
Brother, even with 1,200ft/lbs currently under my right foot, i still miss my gen 4 5.0.
The Coyote family can’t support the bore needed in this application. The Boss is a much better bet as it has the real estate on the heads for the two spark plugs and the big bores. Remember, if you drill the 6.2 you are getting bigger intake valves. Power is not going to be an issue, about 465 HP/515 LB FT of torque out of a 7.0 version of the Boss engine which demolishes the new 7.3 Dirty Gecko’s 445 LB FT.
The Coyote family can’t support the bore needed in this application. The Boss is a much better bet as it has the real estate on the heads for the two spark plugs and the big bores. Remember, if you drill the 6.2 you are getting bigger intake valves. Power is not going to be an issue, about 465 HP/515 LB FT of torque out of a 7.0 version of the Boss engine.
God dammit the 5.0 already makes over 500 hp in a mustang.
It''s DETUNED in the f150.
And real estate IS what I'm talking about.
JUST MAKE THE SAME ENGINE, BUT LARGER. there's your real estate.
IDK what your fascination is with 16 spark plugs, but its hard enough keeping the shitty coils and wires fresh on 8 of them. I world NOT want that nightmare my neighbor went through with his chasing misfires all the time once he got some age on it.
I'm telling you brother, the coyote architecture is special. Nothing else compares
IDK what your fascination is with 16 spark plugs, but it’s hard enough keeping the shitty coils and wires fresh on 8 of them.
2 plugs helps with combustion efficiency on a large bore diameter. If the 7.3 issue is emissions driven, 2 plugs helps solve this.
We don’t know what it is yet, but it’s going to need to be changed ASAP as these power levels are unacceptable in 2026 out of a 7.3 liter engine. This is less torque than GM’s new small block 5.7 going in the 1500 series out of an engine 2 liters larger. It’s not going to fly.
And my wolf is the answer.
I get the complete combustion thing... but i don't think it's worth the maintenance when there is a better way already. Adjustable valve lap is the way forward.
JMO.
I’ve read through this as well as some facebook posts and what I’m seeing is primarily hype based on very limited information, with mostly speculation mixed with lots of emotional reactions. And nobody’s actually talking to Ford engineering. Yawn.
Either keep your old trucks, or roll with it. They’re still better than the gas engines of old, will do anything we need of them, and until they get compared side by side on a dyno, we actually know nothing worth getting in bunch over. ;)
Looks like the 7.3 is getting a big haircut on power to try and get you into the diesel. Glad I bought the 26 model. New power is 420 HP/445 LB FT down from 430 HP/ 485 LB FT. Peak torque is also at a higher RPM (4,250). This means the GM 6.6 L8T is now the class leading HD gasoline engine with 464 LB FT! Ford has removed all claims of best in class gas engine from the super duty page as well.
Surely this will cause the ford stock to finally zoom past $14.00.....
:cool: :cool: 🇺🇲 🇺🇲 🇺🇲 🇺🇲
Other poster is correct, 2026 says “tested on premium fuel” and 2027 says “tested with mechanical fan losses and regular fuel”
Oh yes, it will, my snobby ass will keep owning diesels for as long as I can purchase or make the fuel! So, the way things are going for purchase, what does that amount to... maybe 4 years? :P Then I'll have to resort to pulling the CP4.2 and going with the DCR as well as robbing fast-food joints of their used fryer grease.
I will say I was a little disappointed with the numbers on the 7.3L Godzilla. To be sure, that engine makes very good power. I had expected the torque to be in the 510 lbs/ft range and 450 hp range.
This has been a fascinating discussion. I’m pretty sure I know less now than when I started it.
It’s too bad there is, potentially, a reduction in power in the motor. I really enjoy my 7.3. It performs perfectly for all of my needs but I am not pushing it to the limits.
Also, I believe the 2020 tremors should be referred to as “Classic Tremors “ henceforth, going forward, and from now on.
No. This guy objects and wants to speak with you about it.
Not a bad idea. Or "OBS Tremor" so we can have a spirited discussion on the meaning of OBS.
First and the only thing you need to remember : You wouldn't be able to tell the difference between 10-20 HP loss with a 40-80TQ loss.
You MIGHT be able to tell if both values were at the max loss at the same time on the same truck. Truck to truck those results will vary....SO......you will NEVER REALLY tell the difference.
