Just wait, there is nothing wrong with your 2020.I was contemplating a 28 to maybe replace my 20, but may just have to go look at the 26 H.O. that is on a lot near me![]()
That is why it is so hard. Nothing wrong and paid forJust wait, there is nothing wrong with your 2020.
We're still talking about trucks, right?That is why it is so hard. Nothing wrong and paid for![]()
Yes trucks, plus, that $40k I would shell out for a 26 would pay for a lot of gas and, more importantly, a lot of bourbonWe're still talking about trucks, right?
My hunch is that this the primary reason for the de-rate. A big mechanical fan would easily sap 10hp from an engine.2026MY - 430 Horsepower*485 lb.-ft. of Torque
**Horsepower and torque ratings based on premium fuel per SAE J1349® standard. Your results may vary. Horsepower and torque are independent attributes and may not be achieved simultaneously.
2027MY - 420 Horsepower*445 lb.-ft. of Torque
**Horsepower and torque ratings include mechanical fan losses with minimum cooling load and regular fuel per SAE J1349® standard. Your results may vary.
Just my 2 cents - I noticed the **note change, so wondering if the numbers change could be, in part, the result of Ford now being forced to implement in the first available full model year, the newest SAE J1349_202511 revision (released Nov 25) regarding application of variable load cooling parasitic drag to >8500 lb. GVWR trucks under test? Technically, testing is performed under different parameters/fuel. IF TRUE - How would the 2026 7.3L fare under the same testing requirements?
I'd like to think this was the case, but I do see Ford also lowered the tow ratings for the 2027 F350 with the 7.3L/3.73 gears (no change for 4.3).
I am in agreement, 100% no difference. I do not believe they detuned it, just changed the goal posts.My hunch is that this the primary reason for the de-rate. A big mechanical fan would easily sap 10hp from an engine.
Testing parameters can have a huge impact on measured power. Brian Wolfe dynoed a bone stock 7.3 back in 2020 and got to 500+ hp by removing front end accessory drive and running an open intake, he explains the adjustments/correcting factors that line up his test vs SAE J-1349 here.
2020 Ford 7.3L Dyno Results - Stage 1
This development is for those wanting relatively minor upgrades. Later testing will provide results for a CNC porting of the cylinder heads for both intake and exhaust ports which also qualifies...www.willisengines.com
I’d put money on the 2027 having zero actual difference at the wheels vs a 2026.
Mine is paid off also, don’t be like the rest, drive it and get your money out of it. Nothing wrong with your truck at all! Personally I think it looks better than the new ones anyway.That is why it is so hard. Nothing wrong and paid for![]()
Thanks for the clarification, I have to wonder what the heck those idiots at Ford are thinking... Glad I ended up with a 26!The previous J134 standard included minimum lockup fan losses and all parasitic accessories. This is 100% a detune. Ford knows the GM engine is more powerful going forward and has removed all claims of best in class gas power. So it’s not the reporting standards since GM is immune.
People who work at the factory are saying more restrictive exhaust manifolds and a smaller intake manifold is being put on 2027 engines along with a new wiring harness and front cover. Looks like a restricted exhaust and intake is the cause according to guys who put the engines together.
I would also hazard a GUESS that nothing changes in the hardware and that this is a software deal. That means it can easily be undone.I think the diesel program managers were getting angry gas sales have been increasingly creeping into their territory and asked big brother to do something about it. It’s not going to have the effect they think, it will just increase GM and Ram gas sales. It’s not going to help Powerstroke sales.
I make a lot of money, and I’m not parting with $12,500 for the PS. Most buyers are going to think the same. You can’t manipulate supply and demand. This just backfired on them when they tried to take the 5.0 out of king ranch and platinum F-150’s. The only effect was a huge influx of Lariat 502A buyers and a constant 2-year bottleneck on the trim forcing them to reverse the decision. This will certainly backfire and put heavy smoke in their faces.
The gen 4, 5.0 Coyote is the greatest gasoline v8 engine ever produced by an American manufacturer.We haven’t seen how bad the 3.5 EcoBoost is getting hit yet on power, but we know it’s so bad they had to bring the 5.0 back to the King Ranch and Platinum. The 5.0 utilizes a newer generation PI/DI system at 206 bar with better flame front and makes the latest regulation without a GPF, the EcoBoosts do not. Is the 3.5 going to be a 300 HP slug too? Crazy sh*t!
If you want a Gas Ford truck with any balls in 2027 I guess the 5.0 Coyote is your only bet. Note: the 5.0 V8 is now listed as an optional upgrade over the 3.5 EB on a Platinum in the 2027 order guide first time ever![]()
With the new figures im in agreement, ditch the big block. You are getting sub small block torque now out of a big block package with big block fuel consumption. Bring back the 6.2 Boss and drill baby drill. Give it some bore.The gen 4, 5.0 Coyote is the greatest gasoline v8 engine ever produced by an American manufacturer.
If they would scale it up to 7L, there would be no competition for it.
Period .
I'm not here to knock you guys that wanted a big block, but the so called Godzilla was a real disappointment to me.
They have the answer already. It could not be more obvious.
While i like the idea too, isn't the 7.3 also marketed as being super simplistic cavemanish motor, i mean that's why it's pushrod and everything no?The gen 4, 5.0 Coyote is the greatest gasoline v8 engine ever produced by an American manufacturer.
Period .
