7.3 to lose 40 LB FT of TQ and 10 HP for 2027
^ ^ ^ It'd be nice to have some sort of locker MPH-off override.
Once I put that gear-type limited slip Eaton Detroit Truetrac and 4.10s in my F150's 8.8 Super... holy smokes thing's a bigger, heavier Mustang now. Talk about a ticket magnet. I can't drive my 7500 lb Super Duty like that, but, boy, howdy, I could for a trip or ten down the thirteen-twenty!
:geek:
There really is a simple solution to the drop in torque/HP and MPH. Anodized gas cap! Works every time.
I have a 27 on order and due to deliver in a few weeks and just learned of the derated power figures so came hete to research. I reached out to my dealer yesterday and they are telling me the Tremor is unaffected by this and they sent me a screen shot where is states the 27 has the same HP/TQ as the 26 but I've not been able to verify. The change in SAE testing makes sense but its hard to believe Ford didn't better clarify this as they had to have anticipated the fallout from the substantial decrease in power ratings. This got me questioning my 2027 purchase and I found a 26 local that is fully loaded and substantially discounted (over $8300 off MSRP) but still $3500 more then what my 27 is at however without Black Appearance or Ultimate packages (in addition to $1200 in other options that I didn't care for). Im negotiating with that dealer now to get it for even less, which if I can, will only make my decision to purchase that one easier..
I cant find the social media post where they discussed it in the comments section, but I did find the dyno results that they asked about. Essentially 6.8 producing slightly more peak power than the 7.3 based off 5Stars dynos. Disclaimer of course is that each truck produces slightly different power, but still, there's enough of an overall delta in power (~10hp and torque) stock to stock to see that Ford is probably not reporting numbers accurately.
View attachment 266900View attachment 266901
False. Dynojets etc are not accurate tools for comparison of different vehicles. It is only to compare improvements on the same engine like a CAI or tune. They are wildly inaccurate on finding true power level or comparing one chassis to another. No, a 6.8 with 0.5 liters less displacement and less crank throw is not making more power or torque than the 7.3. Physically impossible based on the laws of volumetric efficiency (both being the same % VE and differing displacements)
Sure, the 6.8 runs through a sissy F-150 transmission with small wheels so the transmission and drivetrain may sap up less power. The torque converter on a 6.8 is half the size of a 7.3…..throw them on an engine Dyno and it’s not close. Nobody wants to try and tow 15k LbS with an F-150 transmission.
JM, your argument has strength to it and some of that for very obvious reasons ("ain't no substitue for cubic inches")... (y)
I believe this to be true, and it certainly wouldn't be the first time!
(and always to our benefit, btw!) 🏁
What screenshot did they send? Interesting
Ford has confirmed the power cut is very real and not just an adjustment to SAE readings. Probably a good idea to get the 26 and not the 27. Statement from Ford below:
“We’ve updated the 7.3L engine to ensure the Super Duty remains compliant with the latest environmental standards. While this resulted in a minor adjustment to peak output figures, the 7.3L remains a leading gasoline engine in terms of displacement and real-world work capacity. It continues to deliver the performance that Super Duty customers expect including best-in-class payload.”
Pickup Truck + SUV talk have a video on this and is where I learned of it.. Still trying to confirm if the Tremor is still affected (which my dealer notes it's not) however I can't see how it couldn't be if it's an environmental compliance requirement as noted. Not sure how Ford can call an almost 10% drop in Torque a "minor adjustment to peak output."
Always interesting to see what AI reports.
I stand corrected. Thank you!
GM says there will be no change to the L8T for 2027, so for those looking for a gasser that in a Trail Boss is probably a better combo. The L8T is going to have a lot more low end torque in the Trail Boss than the gas Tremors. The Ford is going to be pretty lethargic with this new 4,300 RPM torque peak.
I think the environment is being used as a guise. All things point to Ford sticking the middle finger at you, the customer. Both diesel and gas buyers.
First they eliminated the 6.7 SO, only gave you 1,000 back (kept 2500) and demand you buy the HO. And they also purposely sandbagged the 7.3 to get you to buy the diesel (to which they purposely deleted the entry diesel option and DIDNT give you a dollar of help). Greedy bastards that need to be taught a lesson with less open wallets!
Why let them play games when the Duramax and L8T are solid units and often discount out better anyway. When I trade up in 2028 if Ford still has this BS going on I will not be returning. GMC 3500 Duramax might be calling my name.
I am never interested in what the glorified search engine they call "AI" says.
They are very often incorrect, and i despise their existance.
There is not one single point in that summary that has not been discussed in this thread already.
Yes, I'm an asshole and i hate "AI".
Sorry. 🤷‍♂️
I would not own a Mary Barra era Chevrolet if it was given to me.
I disagree with your theory.
The SO 6.7 is obsolete. I suspect they only kept it around just in case the new turbo cooling system didn't pan out on the HO.
Now that it's proven GTG, there's no reason to keep the inferior cast manifold and non water jacket having turbo.
The 6.8 was a joke from the start with its cast iron crank. I'm glad it got the axe.
I think Ford wanted to repeat their past 385 series glory... (460 and 429) but these new big blocks are just not good enough to become as legendary. I'm sorry, but that's the truth. Both the 6.2 and 5.0 have better archtecture, and AT LEAST an equal level of reliability. It fucking KILLS ME that they won't scale the Coyote up to a 429. Nothing else would come close to the 7 liter quad cam dual injected monster that would be. It would push 600hp/600tq without even breaking a sweat.
Finally,
If $2,500 makes the final decision for you on a $90k+ truck, you're doing it wrong.
I don't think either model year will hit 105 in a 1/4mi. 95 maybe?
Challenge accepted.
By the way. .. 37" tires increase the top speed by 7%.
I will not be fixing it in forscan, and i like that it shifts 7% earlier now relative to actual speed. Less overrev...
The HO don't care about tire size. I believe my truck accelerates quicker as well. It sure feels Iike it, at least. 🤷‍♂️
The highest actual speed i got at the 100mph governor with the stock tires was 98. So. .. 7% increase.
That'll do for now, until Banks get off their asses and release the derringer for the '23 and up...
They have one for the latest duramax and Cummins.... IDK what's taking so long for them to release it for the new Fords.
