Thanks!! Reqest submitted.
I think that's just your alternator whining a little bit.My 7.3 doesn't seem like it is down on power at all, my power steering pump seems really loud though
So after almost a week, I just received confirmation from my Sales rep (through Ford management) that all 2027s delivering with the 7.3L are derated due to emissions. What a gut punch, especially for those who've already taken delivery of their 2027. So glad I pulled the trigger on my 2026..So after 4 days my dealer couldn't provide any solid proof the Tremor wasn't impacted by the power decrease (as they stated) so I pulled the trigger on the well equipped (and deeply discounted) 2026 that I was looking at. And I can honestly say that I couldn't be happier!! With that said, I have a feeling once word gets out to the masses left over 2026s with the 7.3 will likely fetch a premium..
The diesels will sell regardless.It is not kosher or OK to accept money and deposits on orders and not disclose a reduction in power on a known piece of equipment. I would get sued if I accepted a deposit for a walk-in freezer box and then derated the refrigeration by 10% after accepting the funds.
New tier emissions were delayed from 27 to 29, emissions is a cover for “7.3 buyers are no longer paying a premium PT fee so we reduced output to encourage diesel sales”
Will be interesting to see actual testing and dyno results by 3rd parties. Could be only derated on paper similar to our F250 Tremors having a lower GVWR than identical F350 Tremors. Also didn't read every comment in this thread so something contradictory could have already been posted to say otherwise.
If you compare the towing stats between the 26 and the 27 on the Ford website, the values have gone down slightly. That points to less power, not a correction or recalibration of how they now rate the power of the motor.
I honestly wish I would not have read this, but now I know. I bet I won't notice, but I am not in a rush.Personally, if I was in the market today, I wouldn't hesitate to order a 2027. You will, most likely, feel little difference with the derated motor and the Chevy / RAM are not an option. I wonder if no one said anything if anyone would really notice it anyway![]()
I would not think the engine would be a limiting factor as far as tow ratings go.Below are screenshots of Ford’s published “MAX LOADED TRAILER WEIGHT” figures for 2026 and 2027.
(For ease of reading, I highlighted certain figures, and also added the year in green. I’ve not otherwise changed anything.)
*If* I am reading correctly:
--the figures are identical for a 7.3L with 4.30 axle.
--the figures are very nearly identical for the 7.3L with 3.73 axle, with a few cases of the rating being 100lb lower for 2026 vs 2027. Note that removing 100lb from 16,400lb rating Is a reduction of 0.6%.
--the 2027 figures with the locking 3.73 are notably lower for the 2027. Perhaps someone smarter than me can weigh in on why, and what this might imply.
Sources:
https://www.ford.com/content/dam/br...26-Ford-Super-Duty-Pickup-Towing-Guide_v3.pdf
https://www.ford.com/content/dam/br.../2027-Ford-Super-Duty-Pickup-Towing-Guide.pdf
Looks like this was posted in the wrong thread.
I've read that the intake track size has been reduced.What will be interesting to see is, if this does end up being more than a paper derate, how easy it is to revert to '26 and earlier calibration/strategy (more likely) and/or hard parts (less likely). Guys could be getting all worked up over nothing.
My thoughts exactly, also more restrictive exhaust manifolds (smaller dia tubes) per those assembling the engine. Supposedly they have downgraded it to the 6.8 exhaust manifold or something. If you’ve reduced intake track width and reduced exhaust exit diameter you effectively have a smaller air pump across the entire band, meaning power losses will be across the entire rev range.I've read that the intake track size has been reduced.
Also, the change in oak output rpm points to a cam change IMO
