7.3 Gas Auxiliary Bed Tank Install
This is such a great idea and write up. Still deciding what I want to do. Have you guys had any codes thrown from the fuel system?
I've had a few but normally when both tanks are very low. I think it is due to the larger volume and a few have cleared on their own. I did recently retighten everything and haven't had it as often. I know Modman has had far less than myself, I believe only 2 or 3 but he can confirm.
Yep had a CEL twice.
First time was due to the cap I put over the vent, which isn't required for our application. It had rubbed through and created an EVAP leak. I pulled that out and replaced it with a pipe plug.
Second occurrence happened after the first really cold night we had a a month or so ago. Code popped up and I reset it but it came back 3-4 days later. I checked all the joints and there were a couple that I snugged up. Issue hasn't returned.
Nope, all good on my end.
Being new, I'm glad this thread resurfaced. I have been wanting to do this tank and add a top siphon line so I can use it to fill the toys and truck on the move. I was going to gravity feed it until I read this thread.
You probably discovered that you can't gravity feed gasoline. I thought about going with something like this (tank from your link) but my primary purpose is refilling of the main tank as a range extender. I use a jiggle siphon hose to pull fuel out of I need it for other purposes. I've thought about installing a switchable diverter so I can fill things using the installed pump but haven't decided if I'll get enough use out of it to make it worthwhile. I think @MiTremor906 suggested a portable electric submersible pump for this purpose which is probably a better way to go.
Yes, I have one that is powered by a few D batteries and works great for transferring fuel to a small gas can for the generator or lawn mower when needed.
Great work and write-up guys! I've often explored the idea of an auxiliary tank for my truck, but I honestly don't do enough long range driving for me to justify it. I only do a couple 800+ mile trips a year, and my bladder is usually the limiting factor anyways.
I always had my eye on the RDS 45 gallon tanks, as they only take up 9.5" of bed space. Their height means they probably won't work under most bed covers like yours, but I don't run a bed cover.
Here's another option I was exploring when I had my 2018 SD. A 33gal tank that takes the place of your spare tire (in my situation, I would just throw the spare in the bed on long trips). This one is "for offroad only"....not DOT approved.
How is the auxiliary tank working out? Do you have the 3D program for gas gauge or do you sell that part?
The tank has been working out great. Love the extra capacity, even when not towing.
If this is what your asking about, I could definitely sell you one. If you are interested shoot me a DM and we can work out the details.
I'd like to thank @Modman and @MiTremor906 for the help getting my tank setup. Your type up was super helpful and you guys were willing to help in anyway which I feel is hard to come by these days. Thanks a lot! I went through a few iterations of finding a way to mount the gauge and button but finally settled on something.
IMG_5283.webpIMG_5284.webpIMG_5285.webpIMG_5287.webpIMG_5288.webpIMG_5334.webpIMG_5358.webp
View attachment 207846View attachment 207847View attachment 207848View attachment 207849View attachment 207850View attachment 207851View attachment 207852
Welcome to the club! Good luck paying for those fill ups now. Good thing they happen less often.
Yeah, the thing that bummed me out the most is that Kroger gas stations limit the fill ups to 35gal or something like that. I had visions of rolling in with my $1 discount and getting 75ish gallons. 🤷‍♂️ :ROFLMAO:
7.3-L F250 KR Aux Tank — Need help / advice
— I just installed the ATI 2-port filler neck adaptor and the dreaded check engine light came on after about 25-miles.
The error text shows an emission issue, and suggests checking the filler cap to make sure it is tight. I’m guessing the connections from the fill-neck hoses are venting back into my now-empty aux-tank.
So, I’m guessing I need to install a solenoid valve on the out-put side of my pump, or a check-valve. Not sure about the over-flow tube but could install a solenoid / check-valve there also if it is needed.
Input / guidance on this would be appreciated.
J_Man
The ATI tank has a check valve on the feed line already (part of the tank fitting). I didn't use their filler adapter, but soon after install had several occasions where I needed to go around to all my connections and snug them up. No codes since then.
I'm still either chasing a leak somewhere or stuck with a different stack up than Modman but mine comes and goes a couple times a year. No impacts, and its been cold so haven't looked into it lately.
I am planning on doing this on my F150 Tremor. When you drilled and tapped the filler neck were you able to get a couple of good threads, I cannot find a thickness on the filler neck, is it steel or Aluminum?? What bulk head fitting did you use to get thru the bed of the truck. and lastly, the two lines was the fill line above or below the vent return to the aux tank?
Thanks, Modman... I"ve checked my fittings and clamps, and everything is good as far as I can tell.
My fill-neck adaptor is from ATI, the tank is an RDS. The tank came equipped with a roll-over valve but no pick-up tube, so I had to add the p/u tube. (My original approach was to use a transfer pump and a standard gas-station filler and hose to transfer fuel - but I recently decided I wanted to direct feed and eliminate storing the pump-nozzle-hose assy).
I've ordered 2 solenoid valves (which I hope I don't have to use - since it requires tapping into my 12-VDC harness) and I've ordered two check valves.
I also ordered a low-cost OBD2 Code-reader... I have a forscan module and software on my laptop but had frequent errors using it on an earlier F150, so I went ahead and ordered a reader scanner to (hopefully) be able to clear error codes.
I appreciate all the detail you (and MiTremmor906) provided, and the quick response to my current dilemma.
J_Man
ATI did confirm you can remove and cap the roll over valve port. That is not needed for the gas version.
My 2024 7.3L KR fill neck is steel - it is very thin, only 0.040-thick, so (for me) not enough wall-thickness to drill and tap. A 1/4-NPT thread has 18-threads / inch, which is a thread pitch of 0.055-inches... meaning, you won't have even 1 full thread.
The outside diameter goes down from the nozzle-end to 0.877-in diameter and then expands up to 1.07-in where the hose connects to the steel tube to the top of the OEM tank.
That is very interesting, and very tempting - that vent is "stinky".
I believe (???) RDS installs ROV's on all of their tanks... I assumed is was a DOT safety requirement for diesel and gasoline, but I"m certainly no expert on the subject.
