Featured
- #81
I am curious about the vent line, is the tank vented? If so how do you not get a check engine light? Is this not the same essentially as having the fuel filler flap cracked open?
The tank has a feed and return line connected to the main tank so it essentially remains closed loop with the OEM system.I am curious about the vent line, is the tank vented? If so how do you not get a check engine light? Is this not the same essentially as having the fuel filler flap cracked open?
Correct, although not directly to atmosphere. The ATI system retains that OEM aspect which is why it maintains legality.OEM Tanks also must be vented
UPDATE - error code issue is resolved (or appears to be resolved).7.3-L F250 KR Aux Tank — Need help / advice
— I just installed the ATI 2-port filler neck adaptor and the dreaded check engine light came on after about 25-miles.
The error text shows an emission issue, and suggests checking the filler cap to make sure it is tight.
J_Man
Glad that you were able to resolve it!UPDATE - error code issue is resolved (or appears to be resolved).
I installed an Evil Energy check valve (the expensive version compatible with methanol fuel additives) just after the output port on the Carter fuel pump and have had ZERO error codes in over 500-miles, towing, not-towing, local and longer-distance runs.
I think the only condition I have not tested is having the aux tank totally empty, which I don’t expect to happen in use.
My aux tank is rated at 48-gallons but max fill is ~35 gal so my total on-board fuel is ~70-gallons - enough for my needs.
I have a few photos snd cost details if anyone needs them, drop me a message.
J_Man
No CEL on a '22 SD. The only issue is that it doesn't register on the gauge and DTE for some time constant. Seems to be about 30min., possibly tied to the fuel economy history cycle?Is anyone having any issues with CEL while driving and transferring fuel, (AI thinks I may get errors from the truck seeing the fuel level rise while in motion)? I have the Carter pump and fittings and about to start on my F150. thx to all for the thread and input, looking forward to an additional 22 gallons in my truck.
