7.3 Gas Auxiliary Bed Tank Install
This was such a cool project and appreciate y'all both looping me in to be a part of it and help get those ATI tanks dialed in for y'all. I'm glad it all turned out as intended! Enjoy it, fellas!
As usual Nick, you were great to work with and had them delivered very quickly. My go-to vendor for anything truck related.
I'm not being a Karen here, by any means, but my understanding was that the direct flow of gasoline (not diesel), from an aux tank into the OEM fuel tank is not DOT-approved? I had a gasser that I specifically traded because of that reason to the 6.7. Am in wrong? I believe that is the reason why there are not any gas options for secondary and aux. tanks like there are for diesel.
Outstanding setup, nonetheless!
The gasoline auxiliary tank connects into the factory fuel system through the filler neck hose (optional 1 inch filler neck adapter available). The gasoline auxiliary tanks install very similar to the diesel ones, however it is not legal to gravity feed out of the bottom of the auxiliary tank with gasoline. By law, the fuel must be pulled from a fitting on TOP of the auxiliary tank. We add a pickup tube to the gas auxiliary tanks with a hose barb on the top of the tank. You must use an inline fuel pump (We recommend the Carter Universal Rotary Vane Electric Fuel Pump P4070) with a switch in cab to pull the fuel from the top of the aux tank and pump it into the factory tank via the fill neck hose.
I was curious so I looked into it and thus am sharing what i found. Im just quoting one place that is not a lawyer - fwiw. I have no clue but this aligns with what i've read/been told.
@OmahaBravo - Yep that's it exactly. We did quite a bit of research and it's the gravity feed vs. pump/top feed that is the requirement for gas.
@ajos0512 - Along with this the system has to remain closed loop to satisfy gasoline evaporative emissions regulations. For instance, you could not employ a breather instead of the return line to simplify the plumbing...
There are others that are sold as a "transfer tank" for gas. They still require a pump, but then use a traditional fuel nozzle instead of being direct connected to the filler. I considered that path as well but am glad I went this route.
Looks like you guys knocked it out of the park! Nicely done.
Cool idea but 43 gallons seems like overkill. Someone should make a 20 gallon version with the top half as a toolbox and pump enclosure. Also wondering if sloshing is a factor. Are there baffles or sponges inside?
ATI makes various sizes and I believe some with tool boxes as well. 43 gallons doesn't seem overkill at all when towing across the country. Previously had to stop ever 200 miles for gas. Now we can stop when we want.
Had the S&B tank in my LMM. 62 gal. Made it from Moab UT to OKC in one tank.
Until you've experienced it... :cool:
First trip in the books and this tank is everything I wanted.
484 total miles
384 miles towing ~8k lbs​
100 miles unloaded​
117 miles to empty @ 9 mpg (just shy of 1/2 tank)
0 gas station stops
Help a dummy out!
I think I understand the 2 barbs on the tank as a pulls from one loops to the other. What’s the third one in the center for?
Seems like doing it this way in addition with my s and b 60 gallon shouldn’t void the warranty as it can’t overfill?
Help a dummy out!
It's a vent, used for the diesel setup. That isn't needed for the gas setup, so it just gets plugged.
Help a dummy out!
It's a vent that isn't required for closed loop gasoline application so we have it capped.
The other two are as follows:
  • The fitting closest to the driver's side is attached to the pickup which goes down to the bottom of the tank. This is required to be approved from a Federal standpoint (for gasoline). There is also a check valve attached to the outside of this fitting.
  • The fitting next to it is the return. This closes the loop between tanks to equalize pressure as the volume changes.
You slipped that in while I was typing! :ROFLMAO:
Winner winner chicken dinner. 🤣
Edit:
At least we agreed. That would have been awkward.
We are headed up North next week and will give the tank it's first real usage. Can't wait!
Made the trip earlier today and it was about 260mi. It was really nice out, little traffic so I kept a bit higher speed and got 8mpg. The factory tank would provide 272mi at this burn rate which is cutting it too close for my comfort. With 120mi on the DTE gauge I hit the fill button on the dash and let the aux tank and pump do it's thing. I have my relay set to ~6min which provides 5gal give or take. My DTE went down progressively to 106 and then added a mile. It stayed at 107 for the next 50mi or so and then started going down. I arrived with 60mi to empty. The factory gauge and subsequent DTE calc definitely wig out when you add fuel when driving. @MiTremor906 referenced this as well in his initial post. Funny thing is that it doesn't have this type of delay when you are parked in your driveway and fill from the aux tank...
You and @MiTremor906 need the in-flight refueling crew badge!
