HOT! ‘17-22 OEM-esque S2 Pro ditch light mounts are now shipping!
Some of us are on our own @Optimus🤖, right @legmar?
Haha, so true! Happy to report a successfully completed install from the day. I’m pretty stoked about the extra light!
Well being I have a true pheasant edition superduty (STX). I am having to run wires. YEA!!!!!! Good news is I got the driver side wires ran in to the cab. Luckily there was a 1/8 hole in the gray connector for the door harness to cab connector (in the door jamb) I enlarged the hole to .25 and both wires for the S2 slid right through. If I ever have to replace the harness or door. I will pull the wires of going to the S2 wires at the mirrior. This wasn't as bad as I thought it would be. Now on to the other side. Then routing to my sPOD.
Went to order these today and see they're out of stock. @BroncOh any idea when they might be available again?
I read somewhere on here he was dealing with some health stuff, not sure he's back in the saddle or what's going on. Could be the issue
Yes, though I thought that was a while back and he was doing better these days. I had heard it mentioned that perhaps that isn’t the case sadly.
I hope for his sake things are looking up.
Bronco has been MIA for quite some time - this would explain. True bummer.
Is there something like this for the 23+ trucks?
Agreed. I know he was battling some form of cancer. Hate to see anyone going through that. His last DM to me back in February stated he planned on retiring from the forum soon and focusing on his health. He said it had become too much to deal with on here.
Hope he is doing well.
My understanding is that there is not an easy way to force the mirror spots to activate on the newer trucks. On the previous it was a simple jumper harness that installed in a couple minutes. Only solution I have seen thus far is a kind of wonky hardware solution from Boost LEDs that drops a module into the door and then uses the window switches to activate them. I have no idea if the factory wiring would support the additional amp draw if you went this route.
Can anyone who has done this mod provide any details on the cable grommet used or where to source them? I have a 2025 and am strongly considering trying to roll my own solution using Click-Bond studs. The hole through the mirror and keeping it watertight is my major concern.
I believe its a 3d-printed TPU grommet but I could be wrong. I'd need to go look at it again.
However, if you mic the cable and get an appropriately sized grommet, you should be just fine. You'll just want to make sure to drill the appropriate size hole and in the correct spot.
The difficulty would be determining the thickness of the grommet so that it matches the outside plastic of the mirror.
Hate to hear that. I was hoping he was doing better.
I sent a text to him last night it is still unanswered, never had it as a delivered or read status when I was texting him little over a year ago.
That being said if anyone has a mount set not installed they are willing to dept with DM me.
Reaches out as well, but don’t want to keep pestering him knowing he’s dealing with more important health matters.
I would also be interested in finding an uninstalled set if anyone is selling.
Alternatively, just one to borrow and inspect up close so I can fabricate a similar one for myself and then return the loaner set to owner.
@BroncOh awesome design here! Any update on the 23+ version? If you need some sunshine and waves you're welcome visit CA to try prototypes on my '24 :ROFLMAO:. I hope the development is continuing, such a great product. I hope your experience at Ford is a great one. Sounds like a fun job.
I'd be totally open to running a power wire to bypass the door module(?) if there were some directions (from any forum member) to allow this to work on my '24.
Thanks!
Thanks!
He's no longer an active member on the forum.
After all that work, that's disappointing. :cry: Thanks @Optimus🤖 for letting me know so i wasn't just wondering why he never responded.
Has anyone figured out the workaround for the 23+ that was vaguely discussed earlier in this thread?
