HOT! ‘17-22 OEM-esque S2 Pro ditch light mounts are now shipping!
After all that work, that's disappointing. :cry: Thanks @Optimus🤖 for letting me know so i wasn't just wondering why he never responded.
Has anyone figured out the workaround for the 23+ that was vaguely discussed earlier in this thread?
You're welcome my friend! Hopefully there's a workaround for the 23+ in the near future.
Has anyone heard from him outside of this forum? I know he was battling some health issues. I hope he is doing ok.
My driver's side light stopped working. Nothing is illuminating - not the BD light, the OEM light on the mirror, or the ON in the center of the switch. The passenger side is working normally. This leads me to believe it's possibly a fuse since nothing is working. I haven't taken the interior panel off to investigate over fears I lose another clip that holds it in.
Has anybody else had any trouble with this? Anybody know which fuse it is that powers the driver's side light?
The fuse is definitely something I would check but it might not be the culprit.
The mirror spotlights are powered by the Spot Light Control Module, which runs on Fuse 3 (10A) in the passenger compartment fuse box. If this fuse were blown, the spotlights on both the driver and passenger sides would be dead.
For the OEM Puddle/Turn Lights, these are controlled by the Driver Door Module (DDM). The DDM runs on Fuse 25 (30A). If this fuse blew, your driver's side power window and power mirror adjustments would also stop working entirely.
Because the passenger side works perfectly and the driver's side window presumably still rolls down, the fuses are intact. The fact that the amber "ON" indicator in the center of the dash switch is also dead for the left side is a massive clue. The switch gets its illumination status directly from the module—if the module detects a fault, it cuts the power and the switch LED stays dark.
Did the truck get any water or some kind of condensation (change of weather in your area perhaps)? If water/condensation got into the mirror housing, or if you recently swapped any of those mirror lights for aftermarket LEDs (which often have different voltage draws than the factory halogens), the truck's Body Control Module (BCM) likely detected an irregular power draw or a momentary short. To protect the truck's wiring, the BCM will throw a hidden Diagnostic Trouble Code (DTC) and permanently cut power to that specific circuit until the code is cleared.
Run FORScan or have a dealer use their scan tool to reset the BCM modules. Once the code is cleared, the module restores power, and the lights usually pop right back on.
Another culprit could be a loose wire or faulty ground. Because the spotlight and the OEM puddle/turn signals are commanded by two completely different modules, the fact that both independent lighting systems are dead on the same mirror points to a physical hardware failure at the source. The main harness plug inside the door panel may have vibrated loose, or the main ground wire has been pinched and severed inside the mirror's folding pivot mechanism.
Good luck and keep us posted my Nevadan friend!
That's an incredibly helpful reply. Thank you so much. One of these days it's gonna stop snowing and I'll get out there and investigate.
You're welcome! Snow!? Did you say snow!? I gotta see pics of this. Get to Vegas my friend!
I live at 6500 feet of elevation. Heavenly (ski resort) is a mile from my house. I could barely see across the street it was snowing so hard yesterday. I've lived here for 6 years and have seen snow that sticks on the ground in every month of the year. No weather event can surprise me anymore.
