Not that I’m opposed to dropping almost $1000 on batteries but if you don’t have a ton of aftermarket lights and such do you “really” need batteries like X2 or oddssey? Besides being hot (many 100* days in the summer) I don’t consider myself in an extreme weather area. I do spend time in the sierras on the winter and a week in UT during January or February which can see negative degree temps. I usually stick to the interstate batteries at Costco because of price when replacing 2 batteries.
What do you guys think? Spend the coin on fancy batteries or Costco and buy a few bottles of bourbon while I’m at it??
so here's my take and take it for less than a bottle of bourbon. I have also thought the Odyssey batteries were cool and with a lot of other trucks, I put mods off for later and then end up selling the truck and never trying something out with a bit of regret. For this truck I have tried not to follow that status quo.
So I used the napa for 20% off coupon that came up a few times and went with the baddest bitches there are and went OdXtremes. Now a little back history, I have had 3 powerstroke 6.0s and those are imperative to have a new high output alternator, big three wiring harness, and good batteries to keep the FICM happy and healthy. For years,
YEARS, I ran some advance auto DieHard AGM platinums and they've been flawless and lasting 6+ years without any issues ever. When my wife's jeep battery died this year, i did not go with an Odyssey, i threw one of the DieHard AGMs in there.
Will I go back to OdXtremes? Probably not, I'll use that money for something else but I can say I finally did it, maybe if these last 10+ years. My factory leadacid batteries were starting to die, leak, and i was getting the truck is asleep alert frequently in the fordpass app. Knowing our trucks can also be finicky with voltage I jumped on the ship, the red batteries look fucking badass. Is the truck starting faster, maybe over the dying batteries but not any faster than good batteries regardless of makeup, starter is only going to take what it needs you can't really FORCE more amps down its throat. Voltage though and voltage dieoff from load is a thing, these should stay and hold very close to 12.8-13v no matter what, so if you old bats were dipping to 10v that's when you'll here that dying tired starter trying sound.
I have a few lights and adding some more, I would argue it's nothing that the factory battery (lead acid), fords AGMs, or any other reputable AGMs, could not manage without issue as voltage loss should be easily replaced by alternator(s). I will say that i left the truck for the holidays and it was parked silent for 2wks and SOC was only down to about 80%, so the capacity is there and the truck never went into hibernation.
I would say if you are adding a ton of lights, plan to use them truck off, have a winch (actually using it religiously), and hammering the batteries with an inverter of size. You could probably just buy some extra bourbon from Costco with a similar warranty, and not notice anything different from the truck other then feeling good if you decide to pop a bourbon as a roady.
If you have the itch to always have wanted to try them, you can't go wrong with them either.
