I think your almost there with the capstan idea. The amount of rope coming out of the capstan would be equal to the load movement if the capstan didn't move itself while it was working. Want the load to move 1ft then 1ft of rope will come out the back. It will do that through a fixed pulley or on a straight pulley the same.
Now just think to pick that capstan up and move it towards the pulley while its hauling. In order to keep the line tight it needs to move the same distance of line through itself as the machine itself is moved in addition to the length of line used to move the load. So yes the capstan is closer but only because if it didn't move more line through the line would be slack.
You can't give credit for work done if the machine doing work only moved the rope to compensate for its change in location.
Can we agree on this simple idea?
Does this picture display a 1 to 1?
I move the left rope from the red dot to the green dot and the right rope will move the same distance from its red dot to green dot. Correct?
Does it change anything if the left rope instead of moving straight down was instead wraped around a drum with a circumference of 12 inches and the center line of that drum was at the location of the red dot?
Now with out anything else moving. Take the drum towards the pulley 1 ft, Would the line be slack? How would we deal with that slack? If we weraped the slack around the drum would it move the load?
Have done a bunch of mulling over this, and I agree there's an inconsistency in my calculations. The inconsistency, as you called out, revolves around the distances I used and what they were measured against. Between the two equations, I changed my frame of reference.
When looking at the Work done to the rope, my frame of reference was that of the winch. The amount of rope moved through the winch is what I used for
d.
When looking at work done to the vehicle, my frame of reference was now the surface the whole system is on (i.e. the Earth). The amount the vehicle moved over the Earth was what I used for
d.
Like you say, if I maintain a consistent frame of reference - in this case the only one that applies to both is the Earth - then the rope moves the same distance as the winch, in the opposite direction. Once the distances are the same, so are the forces, and thus a 1:1 mechanical advantage is shown.
(Worth noting that because Work is a scalar value, it doesn't matter for the math that the movement was in opposite directions.)
Now, I haven't personally observed this configuration in action yet; however, I'm more than willing to take the experiences of others (see the many sources I've cited) and use those as a proxy for my observation, and thus consider the 2:1 mechanical advantage as observed. I'm trying to use physics to explain
why the observed 2:1 mechanical advantage exists.
So I want to walk through to my current logical conclusions of the physics based on those observations. First, let's setup the equations again, but with a bit more detail.
W_r = F_r * d_r
W_v = F_v * d_v
Where the _r suffix indicates a value for the rope, and _v suffix indicates a value for the vehicle.
Now for my assumptions:
- Energy, and thus W, is conserved, as a result of conservation of energy.
- The force applied onto the vehicle is exactly twice the force applied to the rope by the winch, as a result of observed behavior.
By the first assumption, W_r = W_v. Following from that, we can set the equations equal to each other:
F_r * d_r = F_v * d_v
With the second assumption, we know the following:
F_v = 2 * F_r
Substituting into our equation:
F_r * d_r = (2 * F_r) * d_v
Now we can solve for one of the distances (doesn't really matter which one, but let's solve for d_r to avoid fractions):
d_r = (2 * F_r * d_v) / F_r
Simplifying (the F_r's cancel out):
d_r = 2 * d_v
Thus showing that, in order for the math to describe our observations, the distance the rope travels, as measured for the Work equation,
must be twice the distance the vehicle moves. This means one of three things:
- My original approach, involving two different frames of reference, was correct. If this is the case, then I don't understand the application of W = Fd well enough to say why that's correct and need to learn more about it.
- There's some other way to calculate the distances that uses a constant frame of reference, yet results in d_r = 2 * d_v. I have no idea what this other way would or could be, but I can't rule it out.
- The assumption that F_v = 2 * f_r is false, and a 1:1 mechanical advantage is actually what's observed.
My next steps are to:
- Confirm the observations through experiment. If you perform the winch amperage experiment before I do, Mike, then I'll consider that confirmed for me.
- Better understand how W = Fd is applied, distance is measured for it, and how it all relates to frames of reference.
Both next steps are valuable as I still want to understand the physics behind this scenario.
