Winching Brake
More stuff and follow the wikipedia to see the various text books that back it up.
These are different types of pulley systems:
  • Fixed: A fixed pulley has an axle mounted in bearings attached to a supporting structure. A fixed pulley changes the direction of the force on a rope or belt that moves along its circumference. Mechanical advantage is gained by combining a fixed pulley with a movable pulley or another fixed pulley of a different diameter.
  • Movable: A movable pulley has an axle in a movable block. A single movable pulley is supported by two parts of the same rope and has a mechanical advantage of two.
  • Compound: A combination of fixed and movable pulleys forms a block and tackle. A block and tackle can have several pulleys mounted on the fixed and moving axles, further increasing the mechanical advantage."
And yet the Navy says the exact opposite from the source I linked:
A single fixed block does not magnify force or speed. Every input into a fixed pulley will give you an equal output.
But they are referring to the load being on one end of the rope and a separate, independent source of tension being on the other end of the rope. They are not referring to the scenario where the load is the source of tension. As far as I can find in that Navy document they never address that situation.
Think of the line and pulleys like a gear reduction or transmission.
In the scenario of using a snatch block tied to a tree or anchor of some sort and back to the bumper.
If you were 20 feet from the tree you’d need 40 feet of line to run from the winch to the snatch block and back to the bumper.
When you pull 2 feet of line in you get 1 foot closer to the tree. You have to pull in 40 feet to move 20 feet. This is like how a transmission or gear reduction works.
Yes, but this doesn’t have the pulling force attached to the same object as being lifted. The force is split between the lines. If one line goes to a tree, and the other to the vehicle winch, then absolutely, the total force to move the vehicle is on the single winch line, but when the other end is attached back to the winch vehicle, then the force is split between the lines.
Another thing to note about the navy example is that when you pull the rope 1 foot what you are lifting moves 1 foot but with the winch and snatch block it would only move 6 inches.
The difference is that the distance between you and the pulley stays the same but the distance between the winch and snatch block gets shorter.
Yes, exactly, it is a movable pulley setup, but the moving part is opposite the pulley. Still works the same way, except in the actual moving pulley scenario, the earth is like the vehicle. Half the force is on you pulling the line (transferring to the earth through you) and the other half of the force is on the anchor point (tree attached to earth).
Tension on a rope through a fixed pulley doesn't care who is pulling from what side. The second one force is slightly greater than the other it will move that direction through the pulley. Go back to the example of hanging by your wrists from a rope through a pulley in the ceiling. You won't be able to pull yourself up with our a mechanism to creat force.i could hold a min winch in my hand and it would pull me up but wouldn't change the amount of force required to do so.
You have to stop and think about how a winch works. Is the winch pulling the vehicle against it's weight on the horizontal plane?
No it's a spindle rotating on an axis. What keeps the spindle from standing still and the vehicle spinning around the axis instead? The leverage created by the length of the vehicle and it's mass along that lever is what counter acts the force the winch creates. It has very little to do with the mass and travel in the plane of the rope. I honestly think that's where most people are losing this conversation.
A spindle rotating on an axis, eh? That's sounds an awful lot like a pulley.
Also, the length of the winch vehicle has zero influence on this scenario.
There’s a difference between using a pulley to change the direction of pull or routing of the line and multiple parts of line acting as a gear reduction.
Two errors in your setup to start.
The first is the way you are using the work equation. Its not what is being discussed especially with keeping the W as a constant. Using your equation:
F = 120J / d lets run some numbers by that to see if it make sense for our purpose.
F = 120J / (12 inches) answer of 10N of force to move it 12 inches
F = 120J / (24 inches) answer of 5N of force to move it 24 inches!?!
F = 120J / (6 inches) answer of 20N of force to move it 6 inches!?!
This all makes sense if you remember that force is equal to mass times acceleration.
F = m * a or 1N = 1kg * 1m/s2
This equation doesn't work the way you are thinking. The work equation is fine for figuring out the total energy to do something but doesn't put the time scale into perspective. As an example if I applied 10N to go 10m it would require 100 joules of energy. But we could be talking about moving 10kg at 1 m/s or 5kg at 2 m/s or 1kg at 10m/s. Work fails to account for time and direction, its just total effort.
From the wikipedia article "Work is a scalar quantity,[2] so it has only magnitude and no direction."
I agree that Work is scalar and doesn't take time into account; however, F = ma is also somewhat irrelevant in this case. Once the load is moving at a constant speed, a Force is still needed to maintain movement, the mechanical advantage (whether it's 1:1, 2:1, or whatever) still applies, yet we have no acceleration. Because it's moving at a steady speed.
So despite having no acceleration, we still have force and, assuming the vehicle moves, we still have distance. Thus we still perform work.
As for your examples of applying the equation I established, I do think they make sense for our purposes. The Force generated by the "winch" inside the tape measure is constant, the distance the tape moved is constant, thus the energy put into the system is constant. This is represented by the fact that the current consumed (assuming the internals of this tape measure are electrically powered) would be constant.
Now, if that constant energy - applied over any length of time! - is only able to move an object a very short distance, that means the force must have been very high. Picture an object with lots of resistance to movement (inertia, friction, etc). An example is I burn 100 calories pushing on my truck. I might be able to move it with 100 calories, but it won't move very far and I will have applied a large amount of force, proportional to the energy exerted.
On the other hand if that constant energy is able to move an object a very far distance, that means the force required to move the object must have been very small. Let's say I burn 100 calories pushing a model truck. I would likely be able to move it a very long ways before I burn 100 calories because of how light it is! But the force I apply would be very small to get it to move.
There's many ways the force could be applied with regards to time, but the total energy remains constant.
The second error in your equation is that you are not accounting for negative displacement or the that the winch has to move in the opposite direction that it is applying force (when it is attached to the load) thus changing the displacement formula and then account for total distance traveled. You can get into displacement on wikipedia and see that concept. I don't mind quoting wikipedia as long as the sources are linked for the subject. This stuff is all basic physics but most of us don't understand all of the components of basic physics enough to understand a complex system. The specifics of the physics here are Force, specifically tension force and mechanical advantage. The principals will apply the same for all loads so we can use a constant mass and the pull time can be constant as well. So what we really need to know is the distance a line would need to be pulled through a system to move any given load a certain distance. If we had a 2:1 mechanical advantage then the line would need to be hauled 2ft to move the load 1ft. We would have to go twice as far with half the force to achieve the results.
So lets get some basic common ground established to move the debate along. The winch is a mechanism for creating force. It displaces a mass or moves a weight a given distance in a given time. The amount of force a winch can deliver is a factor of available electricity and the leverage point of the drum among other smaller variables. We can agree that we remove those variables and the winch is always got enough energy and is pulling from the same location internally to equate to the same leverage. Or in more simple terms the winch is pulling the line in towards itself from a point exactly at the face of the winch and that direction of pull is always towards the rear of the vehicle. The winch wont work if it tries to go the opposite direction with the line.
This is necessary because we are evaluating the effects of the rigging system on the work performed and not on the internals of the winch mechanism. So we want to answer how much work is done at the winch not in the winch. We will call positive displacement towards the winch. We can agree that negative displacement, the opposite of the direction drawn, then the winch will not move any load. As the rope goes into the winch instead of moving towards the rear of the vehicle it is instead bent around the drum. We will also assume everything is in the horizontal plane to eliminate the force of gravity on the system.
Agreed with all of these assumptions.
So lets look at the rigging we use to get the load moving. I want to move the load 1ft towards my anchor point. Then the line has to move 1ft towards the pulley. This is 1 to 1 so there is no mechanical advantage (MA). The direction the load is moving is in the positive displacement direction.
Next look at how the line moves through the pulley. 1ft of line into the pulley equals 1ft of line out of the pulley in a new direction. This is 1 to 1 so there is no mechanical advantage (MA). The line is still traveling in the same direction, positive displacement towards our mechanism of force thus the load is moving in the same direction. This establishes that neither the line between the load and pulley or the pulley itself have any sort of MA.
Now lets see the direction that force needs to be applied to create positive displacement of the load. Holding the same location on the haul line we move the load 1ft in the positive direction. The haul line moves 1ft in the positive direction. I moved 1 to 1 so there is no MA in this system. The rope is moving in the same positive direction, from the load to the pulley, around the pulley to the mechanism applying force (haul). However in our spatial plane the ending location of the load (green circle) and the haul (green circle) are 2ft apart each having moved 1ft of positive displacement from their starting location. They are opposing directions in the spatial plane but are the same direction relative to the rope from the load.
Now what happens when the haul is done from the load? In a nut shell the haul point has to move in a negative direction while also moving the load in the positive direction. So to move the load 1ft in the positive direction it has to haul in 1ft of line. While its doing that the winch itself is moving in the negative displacement direction of the load. It will haul 1ft of load and then move itself 1ft back along the line in the negative direction. The total displacement along the line is 2ft but 1ft of that was for hauling the load the other 1ft was repositioning along the line. Sure it hauled in more rope but an equal portion of that was because it shortened the overall length of the rope while it moved the load an equal distance. The line only moved 1ft from its original location to move the load 1ft. Where did that line go? Its wrapped around the drum but it may as well be at a point 1ft directly behind the plane it started at.
In the end the pulley attached to a non moving location never imparts mechanical advantage. If anything when you calculate the true effects of adding that pulley to your winch system you are only creating more friction and drag and the system in question and it would take more force to move a given load than a straight pull.
So I believe you're conflating the load and the rope in this case. I started my Work calculations with calculating the work performed on the tape (or rope, in the winch example). This is entirely independent of the work performed on the winch, vehicle, or anything else. In fact, the winch is a part of the load! Just more mass that work needs to be performed on.
As you state in your diagrams and your words, the rope happened to be wound around the winch, but effectively could have been moved behind the winch. It would be a really funky setup for a vehicle, but this could be replicated with a capstan winch bolted to the vehicle and the tailings from the rope laid out straight backwards as they come off the winch. The additional length of rope laid straight backwards is the rope moved through the system, and that length is the distance I used in my Work equation to work out the energy imparted.
The second calculation looked at how far the tape measure body (or vehicle in this case, including the winch!) moved, which we know from observation. The fact this is in an opposing direction to the rope is irrelevant. All that matters to the equation is that the object we're using the equation on moved a certain distance. A certain amount of energy caused that movement, and a force was imparted by that energy.
Not if you are measuring from the same location on the rope. You are crawling up the rope as you also haul the rope.
In your example the rope has to move 1 ft back for the load to go one foot forward. At no time can a rope pass through a fixed pulley and come out the other side at a different speed or force. Yes If I inched my hands up the rope as I moved it backwards I would stay in the same plan as the load (ie winch) but the sliding my hands forward in location on the rope does not count for any advantage. Its just a change of location. Every movement through the fixed pulley provides an equal and opposite movement on the other side of it. No one has been able to explain how I move a fixed location on the haul side a different distance from its starting point then the distance the load moves.
Doesnt matter the winch is a rotational force which is counter balanced by the leverage of the vehicle frame along the spindle axis. It is a simple machine that doesnt rely on the motion of the vehicle in the horizontal plane. Like I said in my long statement. We are talking about the rigging system right before the rope bens around the winch drum.
If a line goes through a fixed pulley and you grab it at a fixed location on the haul side and move 1 ft the other side of the line will move the same distance. If there is a load attached to that you will need to impart enough force to move that load from rest.
What creates the pulling force in the winch is a rotational motion and that can only be counter balanced by resisting rotational motion in the opposite direction.
No one said the length of the winch. We are talking about the system put in place on the line from the load to right as the line starts to bend around the winch drum, ie as it enters a simple machine that uses rotation and leverage to generate force.
What causes the winch drum to spin?
An electric motor and gear reduction
What holds the winch motor in place?
The vehicle.
Which direction of force is exerted back on the vehicle by holding the winch motor stationary, think Newtons 3rd law?
A direction of force in the opposite direction that uses the vehicles frame as leverage. The winch doesnt care about lateral force to do its work.
What parts of this line and pulley are acting like a gear? Is whats displayed a 1 to 1 system?
Just to start here that most people will assume that the force we are trying to move has a lot to do with the mass of the vehicle. I have a 6500lbs milling machine. I can't move it by pushing on it. I can put it on machine skates and move it by hand by myself. Now if I placed it on an air bearing and removed all friction. I would only need to apply force one time and the object would move at a given speed based on that force and not stop until another force acted on it. The only forces we are dealing with in a winch situation are friction and a bit of gravity sometimes. Absent those the object would continue to move at the imparted speed.
Now we can break the MA down to any amount of time you want and any distance. It will always scale the same. So we can assign constants to time and we can assume that the load will be constant throughout our ideal system. That just leaves us with force that will be inverse to distance. A system that requires us to go twice the distance will require half the force. Force will determine speed since F=ma. A system that requires 10N to move when imparted with 15N will go faster covering the same distance in a shorter amount of time. But always the same distance.
I think your almost there with the capstan idea. The amount of rope coming out of the capstan would be equal to the load movement if the capstan didn't move itself while it was working. Want the load to move 1ft then 1ft of rope will come out the back. It will do that through a fixed pulley or on a straight pulley the same.
Now just think to pick that capstan up and move it towards the pulley while its hauling. In order to keep the line tight it needs to move the same distance of line through itself as the machine itself is moved in addition to the length of line used to move the load. So yes the capstan is closer but only because if it didn't move more line through the line would be slack.
You can't give credit for work done if the machine doing work only moved the rope to compensate for its change in location.
Can we agree on this simple idea?
Does this picture display a 1 to 1?
I move the left rope from the red dot to the green dot and the right rope will move the same distance from its red dot to green dot. Correct?
Does it change anything if the left rope instead of moving straight down was instead wraped around a drum with a circumference of 12 inches and the center line of that drum was at the location of the red dot?
Now with out anything else moving. Take the drum towards the pulley 1 ft, Would the line be slack? How would we deal with that slack? If we weraped the slack around the drum would it move the load?
Ok, so reverse the thought process. What if you mounted the winch to a plate, then ran the cable through a pulley that was attached to a vehicle, then back to the winch plate. Now anchor the plate to a tree. Spool in the winch. You now have a moving pulley setup and the winch would see half the load the vehicle is exhibiting, with the other half going down the other line. The tree sees the full vehicle load.
Now, the winch is on the vehicle and the line goes through a pulley that is mounted to a tree, and back to the vehicle. Still the same, winch sees 1/2 of the load, with the vehicle mount point the line is attached to seeing the other half. The tree sees the whole load.
So you opine above that Force is inverse to distance, but then say an increased force results in always the same distance....you don't add up.
I am hesitant to pose this guess, but I think you are getting tripped up on the differences between your FD rigged hoisting systems and a winching scenario where the source of power is part of the object being moved. These are not the same.
