Featured
- OP 🔹
- #121
Agreed it was surprising! As I was in neutral, 4 high or 4 low wouldn't make a difference. The transfer case gear ratio has no involvement on the power of the brakes.Those are surprising results, standing on the pedle you slipped the brakes?!
Maybe it would snap something in 4low with a double line pulley setup on pavement.
I performed three tests. Two of which were closely related.Not sure what you’re trying to achieve with the above test?…..,
The goal of the first two tests were described by the first post in this thread. I was looking to determine ways to make myself traction limited while winching someone/something else, without me needing to be inside the truck.
The first test tested a method suggested by folks in this thread. It was to set the parking brake in 4x4, so that the resistance of the parking brake applied to all 4 wheels, and that should be enough resistance before escalating to some other means (wheel chocks, rear anchor, etc.). I assumed the service brakes would be more than enough to keep the tires from rolling, and thus was my benchmark.
The second test tested my theory about the service brakes being more than enough to keep the tires from rolling. As it turns out, they were not! This invalidated my assumption, and changed my perspective on my options for holding my truck still when winching.
These first two tests were highly successful in my mind, and solidified my escalation path for holding the truck still when winching, particularly when I'm not in the truck.
The third test was attempting to test the mechanical advantage during a double-line pull (the discussion that the majority of this thread became about, in no small part as a result of myself). As it turns out I didn't have the measuring equipment capable to do that (thought I did when I left home), so that test was null and void.
As described above within this post and above in the post where I described my findings, you can see that my goal was not to break parts. I had clearly articulated goals going into my tests, and my tests were designed to meet those goals.Looks like he's trying to break parts. Of course the truck was going to move, the tree wasn't. That's a lot of strain on the winch line and the truck.
Further, as noted, the whole point of my tests was that the tree was not going to move and the truck would. If the tree moved it would have completely invalidated my tests and proved I chose too small/weak of a tree for the tests.
The point was to see in which way the truck moved. Would it move by the tires rolling or skidding along the ground? Does the way in which the brakes are applied change that result? Those are two questions the first two tests boiled down to. And my tests answered that question perfectly for my needs, and informed my winching practices going forward.
To further emphasize that my goal was not to break parts, I explicitly chose to not validate whether the parking pawl in 4x4 Low would be enough to make the truck traction limited. Winching in Park is something I'm choosing to explicitly avoid because of the risk of breaking parts.
Did my tests pose a risk of something breaking? Of course. Any winching operation does, and in particular any high load winching situation. But I was not trying to break parts.
