Winching Brake
I think the anchor immediately beside you to share the load sounds correct.
Check this out.
I wouldn't trust this guy's breakdown of mechanical advantage. His #2 example is classic example of people getting the MA wrong.
As an example if you were pulling on a rope, through a pulley attached to a sled that was 100lbs it would take 100lbs of force to pull the sled. Same rule applies at a 90 degree angle or 180 degree angle. Now assuming you didn't weigh anything if you pulled while standing on top of a 100lbs sled it would still take....100lbs of force for you to move the sled..
You only gain mechanical advantage when a pulley is moving with the load itself. The winch for argument sake is doing the work by grabbing the rope. In his video he claims that hauling 1ft of rope in only moves the vehicle 6 inches and thus has mechanical advantage. But what he fails to see is that in reality he chocked up 6 inches on the haul line and then pulled it 6 inches at the same time. For argument sake calculating mechanical advantage and distance moved you can't change your position on the rope.
So...your logic makes a ton of sense. But then I go digging and find multiple other sources that confirm his math and contradict yours. I'm very open to more explanation here. I generally "get" pulleys (far from an expert) but for some reason this situation of having a winch redirected back to itself is messing with me.
Here's four sites that all agree with the video's number 2 example:
I tried to go back to basics a bit, but all of the basic physics demonstrations I found demonstrate the source of the pulling force moving a separate load, not itself.
Not terribly concerned with the parking pawl... I mean it holds a 7k lb truck just fine(im guessing its well over designed for some crazy safety factor)... add in some parking brake and 4 low...
Again, throw it in 4 low, set the parking brake, put trans in park...winch away.
I wouldnt try to take the trans out of park while winching and having a load on the parking pawl, thats a good way to break one, but stationary... meh.
Ive winched with plenty of jeeps in park.
Go find a sturdy tree, tie off to it with your winch, and give er a pull...
I mean you are trying to reinvent the wheel here. There are THOUSANDS upon THOUSANDS of people who winch every year with nothing more than 4 low, trans in park, parking brake applied... Nobody uses line locks... nobody uses brake buddies... etc...
Fully respect your experience, but that's just not a risk I'm willing to take. Would far rather apply the basic brake depressor I linked to, or any of the other solutions presented, than risk needing a transmission replacement. I agree it's unlikely it would break...but oof, that would be extremely bad if it did.
Back in college when we were out four wheeling on muddy, slippery, logging roads we applied a different technique to ensure the winch vehicle didn't slide. An anchor behind the vehicle was employed (assuming winch in the front)... Usually just a static tow strap shackled to the hitch and then around a tree. There was never a shortage of trees. There were occasions where a light jeep was the only vehicle with a winch and this approach was useful even as a proactive method just in case...
Agreed! That's a great technique if you're able to, but I want to plan assuming that I won't be able to anchor to something behind me for whatever reason, so I need to capitalize on my available traction.
I'd honestly be surprised if the stock 12,000 lb winch would slip the parking brake in 4x4. Even more surprised if you managed to snap the transmission park paw on a truck designed to park with a 20,000 lbs trailer attached on a hill in 4low where you have the transfer case multiplier.
Could you imagine the lawsuits that somebody goose neck truck plowed a car after parking? or after the parking brake slipped under load?
That's a great point about what the parking brake needs to be able to hold. Hmmm. I really do need to hook up to an anchor in a high traction situation (pavement) and see if traction will brake before the parking brake slips when in 4x4 in neutral.
Just because it is repeated often doesn't make it correct. We have built out complex haul systems around our 107' aerial and used force meters to determine actual haul weights on anchor points and haul lines. Hands down a fixed pulley provides no mechanical advantage.
I attached a book that breaks down block and tackle. Read chapter 2.
In the most simple term the winch has to move with the load since it is attached. So if the load moved 1 inch then the winch would have to take in 1 inch of rope to keep the line taught. So when the winch pulls the load 1 inch it also has to move itself 1 inch forward. Mechanical advantage is about moving the load not moving the object applying the force.
I snapped this rough photo to demonstrate as best I can considering the time it is here.
I have a yard stick measuring 3ft away from my fixed "pulley". A tape measure is my winch line with 6 ft out from the winch and back to the load, the tip.
As I pull the tape measure 12 inch backwards the tip of the tape moves forward 12 inches compared to the yard stick. The fixed pulley thus gives 1 unit of movement out for every unit of movement in. A fixed pulley doesn't provide mechanical advantage. Now however the haul point (body of the tape measure) and the load (tip of the tape measure) are 24 inches apart. If I wanted to keep my haul point and load point the same, the haul point would have to move itself up the rope which is just a change of location or grabbing the rope in a different spot so to speak.
If I move the body of the tape forward 6 inches with out moving the tip of the tape the line would go "slack" so the winch has to take in line just for the sake of it changing locations. This distance it moves doesn't contribute at all to any force to move the load it's basically just to keep the line tight. Now if the winch moved the load 6 inches and itself 6 inches it would need to take in 12 inches of rope.
Another thought is if you were to drive forward while winching someone else would that give you an advantage? No because you would just need to take in more line to account for the movement. The winch needs to pull the line backwards and any forward motion of the winch itself is actually counter productive to the effort to move the load.
id imagine you could install a line lock upstream of the abs pump as the master cylinder is only proportioned front and rear. would be easy to hook this into one of the upfitters. Essentially you would press the brake and flip the switch. it would then hold the applied brake pressure in the system until you flip the switch off.
If i were doing such a thing id tie it into the parking brake warning circuit as well so the truck will chime at you if you try to drive with it on. Could be dangerous as it would also work opposite and essentially disable the front brakes.
Absolutely. Though it does increase burden of proof for contradictions. Here's another source stating it doubles the pulling power of the winch, from none other than Warn:
Possible they're wrong? Of course. Likely they're wrong? No. And even less likely when corroborated by many, many other sources. I also still don't have the knowledge/understanding to claim you're wrong at this point in my post.
I read the chapter and it still didn't address the situation where the load and source of force are the same. What was stated in the book makes complete sense, just doesn't address the situation at hand directly, and I think the situation at hand can present forces that are different than discussed in the book.
I think your example is great, first of all. And it is helping to clarify my understanding...though I think in opposition to you lol. Towards the end I'm going to come at this from an energy standpoint instead of mechanical advantage. First I want to present two thought experiments that don't prove anything, but I think are interesting to consider.
First is imagine you want to vertically lift yourself upwards. If you have a rope attached to the roof, hanging down, it takes a fair bit of effort to lift yourself up. Instead, if you hang a pulley from the roof, run the rope through the pulley and attach it around your waist, then pull on the loose end, I intuitively believe that would require significantly less effort to lift yourself.
Second thought experiment is, in these situations where the winch rope attaches back to the winch, what's the difference between:
  1. The pulley being stationary and the vehicle being pulled towards it.
  2. The vehicle being stationary and the pulley being pulled towards the vehicle.
I feel like those are the same, just different frames of reference. But I believe what you're saying is that because the pulley is fixed in the first scenario, but moving in the second, mechanical advantage only exists in the second one?
Now on to my interpretation of your example, but in terms of energy.
Setting the stage from your example, assume the end of the tape measure is attached to the body of the tape measure and the tape measure is locked (won't auto-retract). Then, picture some outside force moves the body of the tape measure forward 6 inches; you would have slack on both sides of the tape. To take up that slack, the tape measure would then need to retract a total of 12 inches of tape - 6" for each side of the pulley.
Put another way, if, instead of an outside force, the tape measure was moving by retracting itself it would need to consume 12" of tape to move itself forward 6".
I believe I've restated what you said in the first two paragraphs of what I quoted, just in a different way, and we're on the same page so far.
Now, flipping over to energy. First, the definition of Work:
In physics, work is the energy transferred to or from an object via the application of force along a displacement. In its simplest form, it is often represented as the product of force and displacement.
(Yes, I'm quoting Wikipedia. But that's a foundational definition in physics. It's just well written on Wikipedia, but can be cited from many, many, many physics textbooks. :))
So, W = Fd is the formula we're working with. Where W is work, which is energy imparted; F is Force applied to an object; and d is how far the object was displaced.
Let's assume the tape measure retracts with 10N of force (this represents the force our winch can pull with). This force is imparted into the tape first (we'll get to the force ultimately imparted to the body of the tape measure). Using the formula above, if we pull in 12 inches of tape, the work done is: (10 Newtons) * (12 inches) = 120 Joules.
That is the total amount of energy moved in the system (ignoring heat losses, etc, etc), thus we know how much energy was imparted on the body of the tape measure as a result of conservation of energy. Thus, reworking the formula above, we can work out the force applied to the body of the tape measure as such:
W = Fd
W / d = F
F = W / d
F = (120 Joules) / d
We'll pull in that 12 inches of tape in two scenarios, working out the force ultimately applied to the body of the tape measure using the formula we've created for Force:
  1. The end of the tape is attached to the anchor.
  2. The end of the tape passes through a pulley and attaches to the body of the tape measure.
Scenario 1:
This is a straight pull, thus the body of the tape measure moved 12". Applying our formula, this means: (120 Joules) / (12 inches) = 10N of force was applied to the body of the tape measure. As expected, this is the same as the force applied to the tape.
Scenario 2:
This is the double-line pull under contention. As established above (assuming we're in agreement above), the body of the tape measure will only move 6" forward when 12" of tape is retracted. Applying our formula, this means: (120 Joules) / (6 inches) = 20N. Despite applying only 10N of force to the tape, the amount applied to the body of the tape measure is doubled. This logically makes sense as, to have imparted the same amount of energy over a shorter distance, more force had to have been applied.
I can't map this back to fundamental pulley math/equations yet, and that irks me; but I do trust my energy math pretty strongly. I also know that I'm not satisfied with any of the sources I've found for pulley fundamentals as, like I've said, they don't address this exact scenario.
W = Fd
W / d = F
F = W / d
Scenario 1:
Scenario 2:
For those of you following this thread who didn't like physics in school...sorry! 😇
I think it would be easier to plant a tree and watch it grow to use as an anchor than figure out this black magic physics voodoo.
Easier? Perhaps. Faster? Depends if you're wanting to recover your actual Tremor or a 1:1200 scale model of your Tremor. :P
And this is why messing with braking systems terrifies me. :oops:
Following in case I need to use the winch to help remove trees from our road on Friday. We are right in path of Ian. Supposed to hit here as tropical storm Thursday afternoon but expecting lots of wind over next 36+ hours.
W = Fd
W / d = F
F = W / d
Scenario 1:
Scenario 2:
I will reply to the rest of this after I drop off the kids and have a minute. But for now I can say yes warn is wrong. And they are either wrong in the article you linked or the one I linked below. In this article they state the advantage of the double line pull is to have more line out and get less layers on the winch spool thus improving winch pulling power.
The reason it seems easier to pull yourself up by the waist from a pulley is your arms act as a simple lever on the rest of your body. As your arms pull they leverage that force against your body weight. This leverage effectively reduces the weight (notice I said weight and not mass, weight is a product of gravity on mass) being lifted. As your force point (hands) get more out of plain from the load plain (attachment point at your waist) the easier it is to pull as the lever gets longer. Just lean back and haul. Even being slightly out of plane starts to give an exponential advantage. But if you tried to pull yourself up the same way you would climb a rope, hand over hand in line and as close as possible to the load line, you would find it takes the same amount of force to climb up but you would still get a slight leverage advantage from the distance between your hands (force) and your waist (load point).
Now lets get rid of all the awesome levers of the human body. Lets tie the load point around your wrists and only use your hands to pull the rope! My point is saying this is that like a winch the human body is a mechanism that is able to use its internal components to create force. But unlike this example the winch isnt at anytime leveraging off the vehicle in anyway to lesson its workload. But you could always create a winch on some sort of lever coming off the bumper to simulate the action you describe but now we are talking about another machine in the system.
A winch works by pulling line in and around a drum. It can only apply force in one direction into itself and around the drum.
Warn and CounterClockWise are correct in this case.
Because the line is attached back to the same body of the winch, relative to the winch body the snatch block is moving and you have to pull in 2x line to 1x snatch block movement.
This also applies if the snatch block is attached to the tree being fixed, you have 12,000lbs of force on the line at the winch side going around the pully equates to 12,000lbs* of force on the bumper side as well, so you have effectively doubled the pulling force and halving the moving speed.
This would not be the case if instead the other end of the line was attached to a rod, the snatch block to a tree, and the winch to your bumper now you are only directing the 12,000lbs* force and would be where your logic is correct.
also both of those warn articles are correct in addition to doubling you also get the pulling of the line closer to the drum, inverse to using a cheater pipe on a ratchet it just gives you more force by increasing distance from the axis ( but requiring more distance to accomplish the same rotation ) I say invers as this time the axis is providing the torque and we want to pull in a line
This is essentially what you have in a double line pull fixed back to your truck, the top "pulley" is effectively your winch drum. In all such systems, what is important is the number of lines acting on the load. What is important in this case is that there are two lines (2T) acting on the load. As Warn and many others repeat, the double line bumper pull indeed generates a 2:1 mechanical advantage.
Absolutely agree. theoretical physics discussions are fine (I mean I guess they are, but way past me - 🤔), but no need to reinvent the wheel.
Unless you have an anchor immediately beside you to share the load, multiple snatch blocks won't change the final amount of force on the truck, right? It increases the winch's leverage so it doesn't need to work as hard, but if you need 10,000 pounds of force to pull something out, it will only come out once there's a total of 10,000 pounds of force on the vehicle doing the winching and on the vehicle being winched. Regardless of snatch blocks. Right?
And when talking about applying the brakes and such it's all about holding back that 10,000 pounds of force (or whatever the force might be).
Fair. I mean in principle they are a pretty simple idea. And I suppose they should fail safe - open - so shouldn't be much of a safety concern once installed correctly.
I won’t comment on the pulley moving or stationary part but I can comment on the winch and pulley part.
We use pulleys (we call them sheaves) extensively with cranes. The force going back to the drum (winch) from the load block or ball is divided by the number of lines. So if you have 4 tons on the hook and 2 parts of line 2 tons are going back to the drum. The whole 4 tons is still on the crane but each line only hold a part of that load. This is why cranes can lift so much with relatively small lines.
So if you wanted to lessen the load on the truck itself (and also the winch at the same time) you’d have to use an anchor point to tether the snatch blocks to. Using 2 snatch blocks, one on what you want to pull and one at the anchor point you’d take half the load off the winch and truck.
For this to work only 1 line can return to the truck (the 1 going to the winch) or it’ll only reduce the load on the winch and not the truck itself.
MTU?
