Which fumoto drain valve
I ran the F316L, same one @mrmag00 posted above, on my 2012 6.7 for 8+ years. Zero leaks Zero problems. Just turn the 90* sideways after the change and always change the oil Hot. The 90* really helps aim the oil into the pan I use. I remember the first time I changed the oil on that 2012 and the oil shot like 4ft out of the hole and got everywhere. Never again hah. Wonder why Ford didnt just put the drain plug on the bottom.
I bought another F316L for my 2023 and will be doing it when I personally change the oil next. I have to bring it in for that trailer module recall and they still owe me a free oil change anyway. Probably won't have Ford put it on though.
Anyone used the vacuum trick to install the valve with oil still in the truck?
Go on..
I did, was weird removing the drain plug and not a drop came out. Makes a weird gurgling/snorting sound.
Don't tell anyone, but I used my Festool dust extractor with the bluetooth remote to do the job.
That sounds glorious. Technology!
Yessir. Starting back in 2015. Learned about it when finding the best way to change a hydraulic filter on my tractor.
Put a vacuum hose on the oil fill port, and you can install the valve without draining the oil. Use a shop vac.
Just don’t use your moms Electrolux 🤣
I used a tiny 2 gallon shop vac. Doesn’t take much.
First oil change using the Stahlbus on my 22 tremor. Love the cap that stays there and seems to flow faster than Fumoto used on wife’s old Subaru, my old f150, and my old Ram 1500.
Hopefully next will be even easier if lift kit is installed. Lol
If you use a 5 gallon race fuel can, it’s the perfect height 😁
If you use a 5 gallon race fuel can, it’s the perfect height 😁View attachment 263528
Actually not a bad idea to use the 5 gallon buckets from local hardware stores.
Wonder if they make ones with little cap like holes in lids or I could fab one up uses pvc parts…🤔
Nevermind… good found it for me
Now if local I don’t have to buy 5… but for $10 hard to argue.
Scratch prior response….
Amazon to rescue. Be here tomorrow and then I’ll just have to remember for next oil change 🤣
But fitting the hose in the hole with/for lubricants … just makes sense 🤪
I was gonna say the local Lowe’s or Ho’s would sell ya an empty 5 gallon paint bucket with the schnozzel.
Quick, duck! @Optimus🤖 will be here soon with all the talk of hose, lube, schnozzel and the like 😏
Beep boop, Optimus has arrived! You better not be ducking, because I brought the industrial-strength lube and my schnozzel is fully calibrated for maximum pressure! 💦🏗️ Grab that 5-gallon bucket from Ho's, because I'm ready to lay some serious pipe today. 🔧👷‍♂️
For those that have tried to vacuum trick, is an adapter needed, or can I just slap some duct tape around the filler neck and shop vac? I have a skid plate already installed and no Stahlbus yet, so I was hoping I could use the shop vac trick and get the Stahlbus in first and then drain.
I used a mini shop vac and just wrapped a rag around it.
