I love the Stahlbus.
Yes, It's been on for a few months now.Have you installed the pan yet?
Do you know if the 6.7L diesel uses the same Stalbus drain valve as the 7.3. I’m looking for the right Stalbus drain valve for a 2022 Tremor 6.7L diesel…..thanks!!Thank you! Game Changer. even in 2024
ThanksThe 6.7l does not share the same size oil drain plug as the 7.3l.
Thanks
Does anyone know the proper Stalbus drain plug size for a 2022 6.7L diesel uses? Thanks in advance!Thanks
Thanks for this. Was about to purchase Fumoto. I purchased this instead.Sure thing! Here's the link to the Stahlbus for the 7.3 that I bought:
Stahlbus Engine Oil Drain Plug Valve Retainer Cap Thread M12x1.75 Oil Change | eBay
Stahlbus Engine Oil Drain Plug Valve With Retainer Cap Thread M14 x 1.5 M14x1.5. Stahlbus Engine Oil Drain Plug Valve With Retainer Cap Thread M12 x 1.75 M12x1.75. A conventional oil change is always associated with spills and dirty hands.www.ebay.com
Threads are M12x1.75.
And here's the thread where @BroncoHooves and I discussed the Stahlbus and other options:
No Spill Systems
I bought this quick drain system from No Spill Systems if anyone is interested. Kit $87.81 shipped to California. Still waiting for my truck. Description M14x1.5mm LB T10. Item#10-14150-30 Description 1004 Drainer Large Angle. Item# 1004 Drainer Large Anglewww.fordtremor.com
Thank you - got it ordered.M14 x 1.5 is the thread size for the 6.7l.
Nothing at all, except it doesn’t drain quite as fast compared to the Stahlbus or Valvomax types. I drain my oil as hot as possible and just swap the filter while it’s draining. The Fumoto has never slowed me down. One nice thing about the Fumoto is you don’t need a separate proprietary part to open it, unlike the others.See some people are using the Stahlbus instead of Fumoto. Why? What's wrong with the Fumoto?
This is the exact reason I use Fumoto. Especially since I sometimes change the oil when I’m not at home.One nice thing about the Fumoto is you don’t need a separate proprietary part to open it, unlike the others..
I believe all 6.7L from 2011 to current runs the M14 drain bolt.I have a '26 6.7L - I'm about to do the first oil change next week.
The Fumoto web site states: "This Ford model uses two differently sized drain plugs. One is M14-1.5, while the other is 12mm-1.75, we suggest getting your drain bolt measured."
Anyone have any idea how to confirm the size without removing the drain plug? I was hoping to order the valve before this oil change...not after.
M14 is the diesel (HO and SO)I have a '26 6.7L - I'm about to do the first oil change next week.
It should have some sort of paper fiber gasket.I have the 7.3 and just received the fumoto valve and there was not a pan gasket in the bag. Has anyone added a gasket or is it not needed?
Depends on which one you ordered. Some have fiber gaskets. Some have an O ring.I have the 7.3 and just received the fumoto valve and there was not a pan gasket in the bag. Has anyone added a gasket or is it not needed?
