Which fumoto drain valve
That should work perfectly!
It did not.
What a sh!t show. My wife took the kids out to buy some school clothes for the kids. I thought to myself "perfect, some quiet time to get the oil change done." Started the truck up, drove it in a warm up loop to get that oil up to about 130 degrees and pulled onto the drive way.
This is where things took a turn for the worse. removed the bolts on little ports for the skid plate. Got tools ready for oil filter, bag, and also the socket for the factory oil drain plug ready to go. Popped the hood and set the vacuum on top of the engine bay. Got my oil drain bin next to the truck ready for action once I got the Stahlbus kit.
Tied a shop rag between filler neck of shop vac and turned it on. Went under the truck and started to loosen the drain bolt. Right about the time I thought to myself "this vacuum thing really works! There should be oil seeping out by now!" a decent gust of cross wind hits me and I hear it. The little portable shop vac tumbles. The hose pulls out. All hell breaks loose, including the last hint of thread on that drain bolt and it shoots out to around my belt line. I managed to roll over and grab the drain bin and get it under the flood of oil. FML.
Tried the bag over the oil filter. Did not work. I tried to slip the bag on when the filter should have only been a couple more turns. As I turned it the last couple spins, I did not notice that the bag on the back side was pulling downward. About that time, I notice that my crotch was getting warm, and not in a good way. The oil draining from the oil pan had slowed to a small trickle. The wind had been playing a cruel joke while I was working on the filter, it was blowing the warm oil all over my crotch, pissing the drain pan completely.
There's oil dribbling on my nether-regions, there's oil dripping out the back end of the skid plate, there's a mess near my head from the filter. I take a deep breath, roll out, assess the damage. Take a second to laugh at myself. Grab new filter, fill it with some oil, lube o-ring. Thread the new filter on. Thread in the Stahlbus plug and tighten. I start laying out rags to soak up as much oil as I can. Right about the time I am pouring in the new oil, my wife and kids pull back up.
"Daddy, WHAT HAPPENED????????????"
It did not.
It did not.
You don't happen to have a Ring doorbell or any footage of said event?
There's footage from our security system, yes, but there's no chance in hell I'm sharing it. My wife and kids reviewed it and got a kick out of the whole thing.
I will give you kudos for coming out and sharing the hiccups you endured.
  • Winner
Reactions: McE
I bet most of us that work on our own rigs have been there. Thank you for sharing 😂
It did not.
Holy Hell, man! Every single thing that could have gone wrong, DID!!
He could have had the wrong oil filter, or threaded adapter drain plug.
I wasn’t going say anything that might occur in the future. 🤣
Have not laughed so hard since the dude got rhino liner on his hootis.......
I find Tenor has problems with this site more often than not; GIPHY seems to work good for copy and paste most of the time.
