I installed the OCD Gutter system today. My initial thought is that this will probably serve as a temporary solution until someone comes up with a better design that incorporates a drain tube. Looking at you,
FirstFunctionDesign
My first attempt at installing the gutter resulted in a crack running all the way down the left side. I didn’t feel like I was Incredible Hulking it into place, but apparently I was too rough with it. I was still able to get it installed, and I think it’ll be fine as a temporary solution. I do not have a 3D printer nor do I know the type of material that should be used under the hood. I will say the "OCD Plug" does not feel very sturdy and I would not expect it to last the life of the truck.
I do think it will help channel water away from the fuse box cover, but ultimately I’d like something wider that captures more of the runoff coming from above. This one feels like it was designed to be as compact as possible, presumably to minimize the amount of material used.
Here are a few photos:
Watch out for the gutter catching on the circled screw:
The red circled area looks like a crack, but it is just an artifact from 3D printing. Long term, I want something that extends under the highlighted yellow area.
