Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
I used these when running wires to the back of my truck along the passenger side.
Self adhesive zip tie mounts.
Just make sure the spots you stick the pad is clean. Have only had one fall off in two years and that was stuck to the front wheel well liner.
Thanks. They had those at Lowe's. I'll give em a shot
I wanted to say thanks to all of you who chimed in, especially Rooster. Having had a couple of phone calls with him over the weekend. This is the first I have heard of the 7.3 gas motors not having a wire loom running along the passenger frame rails to attach the new wiring harness too.
I have installed a few of these kits personally, however they have all been on the diesel engines.
Going forward all the kits I ship out will have a few of the adhesive zip ties included.
Much appreciated,
Dirt Church Industries
Thanks for all your help kit was great. Outstanding customer support and outstanding support from the forum, thanks for everyone's help you guys are great.
For what it's worth, I had no trouble w regular zipties on my 7.3. I used what was included plus some extras and doubled up on a few for length.
I did something similar for a previous run from the rear of the truck. I used the same attachment points for the compressor wiring too.
I like the adhesive ziptie mounts though and will order those for future use!
We just released the 2017-2020 F-150 / Raptor dual ARB compressor kit is currently available on our website.
Take a look at the Youtube video below, while it is for the F-150 platform the Superduty installation procedure is 95% the same. We have everything on our website in stock.
Please let me know if you have any questions. I appreciate the order that keep rolling in from this forum.
Much appreciated, Troy
Link To 2017-2020 F-150 / Raptor ARB Compressor Kit
Not sure if this is just my truck, but after the install, the seat bottom won’t stay in the up position on its own. I have to hold it up. It helps if I first release the seat back before lifting the seat bottom. This is caused by the seat back pushing up against the compressor as I lift the seat bottom. Anyone else?
Mine interferes w it a bit. I mounted the bracket as far back as I could push it and the seat back still presses on the compressor a tad but it'll stay locked in the up position.
Same here...
Same, however with the compressor slid all the way back the seat should fold up into its locking position with out any real effort. If you reach your hand under the rear seat while folding it to it's locked position the seat should just barely touch the back of the compressor, just enough to flatten the carpet, nothing too major.
Troy
Thanks I’ll see if I can play with the positioning a bit.
Kit and compressor ordered. I think I will set up as designed to start and then decide if I want air at the rear bumper and/or a tank.
You will want the tank and rear air. Might as well order the parts now!🤣 Seriously, they are very inexpensive and it’s easier to plumb it all at one time rather than go back and do it again. Of course, then you’ll need an air horn too…..
So, I am noting that the Dirt Church instructions have changed. Instead of going under the carpet and through the plastic piece in the floor, the directions are now to pull some trim pieces and just drill a home to the side through the floor.
Has anyone used the new instructions/method?
SteveG75, good catch.
I recently developed a very similar compressor mounting kit for the 2017-2020 F150/Raptors. On the vehicle I used for fit it up, it did not have an underseat storage box to hide the wiring that came up from under the carpet. The wire routing procedure used for the F-150's will also work on the Superduty's.
This new wire routing is easier, faster and provides a cleaner install, as you don't need to remove the plastic under seat storage box or cut the carpeting. The wiring harness did change a bit, so you will not be able to use the new instructions listed on the website if you have the older wiring harness.
There are a few people on this forum that have installed the revised wiring installation instructions.
Troy
Troy
Continuous improvement... Love it!!
Troy
So, what is less risky? Removing the storage box and running the harness that way or trying to remove the trim panels for access to the floor to drill?
For me, removing the storage box is easier.
