Twin Arb Compressor Mount Behind The Rear Seat For 2017+ Superdutys
I'm way late with my Tremor purchase a few weeks ago. How did this work out? Anyone willing to share their experience with this setup?
I really like having the compressor in the truck and the quick connects at the rear seat base are pretty slick. I'm also installing an ARB quick connect on the rear bumper below the jack winch access point. Installing the kit was a breeze w the Dirt Church instructions, although they kinda jump around a bit, imo. I started w the brackets, compressor, air lines, and fittings, then got the harness ready to go a couple days later so I could run it as soon as we got a warm day. Hardest part was running the harness into the engine bay the way I wanted.
The only thing I think could be improved in the kit are the 1/4" press to connect fittings used at the quick connects. If they were 45º swivels the hose to fitting interface wouldn't be as stressed and it'd be easier to get it to seal.
The compressor itself is about the best you can get. I haven't had a chance to use it to fill any tires but I ran it a bunch and proudly flipped the switch a million times as I relished in my success. It's a lot quieter than I expected.
Thank you for the orders. We have everything on our website in stock.
Dirt Church Industries
We look forward to your business, Troy
Effective immediately, we will be offering a 10% off discount on the Ford-ARB compressor kits. Offer ends after 14 units are sold or the end of this month 1-31-22, which ever comes first. No discount code required, just order directly off our site. We have everything on our website in stock.
I plan on mounting my compressor behind the seat like this, but won’t even have my 23MY for another couple of months at least. I’m sure others will receive their ‘23 before I get mine but if not, I’m happy to offer my truck to “check fitment” after I get it. 😉
Update: bulkhead passthrough fitting shouldn't be needed. I found a grommet in the back corner of the cab behind the trim that will allow the airline to passthrough. You can see the ARB in the picture, so it's going to be a nice shot to it with a gentle bend radius and won't be pinched behind the trim.
Finally got a warm day to run my air line to the rear bumper. That grommet, its the rear drain on trucks w the sunroof, so no dice on using it. I'm prob just gonna drill a hole in the floor next to the inverter and press in a snug fitting grommet of my own.
Also, I'm probably just going to install one ARB quick coupler now next to the rear license plate instead of two underneath the truck on the hitch receiver sides. Should be easier to access and less overall fittings. I gotta wait for the ARB coupler to come in to see if the threads are long enough to mount through the license plate area. Initial measurements seems like it 'should' work, but I will wait and test fit the ARB coupler through the spare tire key lock before committing to drilling.
Glad to see you are back on the forum hope everything is going well and you are on the rad to recovery! For that grommet you found in the corner did you have to remove that side trim piece or could you push it out of the way? Mine seems like it’s way back there.
Glad to see you are back on the forum hope everything is going well and you are on the rad to recovery! For that grommet you found in the corner did you have to remove that side trim piece or could you push it out of the way? Any pics of your setup going through there?
My condition is still the same.
You don't need to remove it.. just hold it back out of the way long enough to do the job :)
Sorry to hear that. Well thanks for taking the time to answer my questions. You did before I could even edit the pictures part. I found the exact pictures later in the thread. I'll just push harder lol. Hang in there and keep fighting! Thanks again
Yah, it’s way back in there. Find a helper with small hands, that helps. The rubber in the grommet is thick. I cut a x through it and was able to push the air tubing through. But it took some effort to get it to push through. Good luck!
Hacking up - I get it. IF this helps anyone this is the connectors are Delphi Metri-pack connectors ARB uses should you need new pins or connectors. I didn't want a splice on two ends if at all to make the run longer and I wasn't sure how I was going to route it so I knew I would de-pin and I needed new pins for my new run of wire.
Also - on my 2020 there is a rubber grommet UNDER the power inverter as an alternate wire route. You just have to remove the two bolts and push pin that holds the tray and inverter in place and cut a little carpet for access. If you have this, you may not need to cut a hole in your floor. You can see the grommet just inside and above the frame rail and there is enough of a recess/gap under the inverter tray to run the wire loom. It may give you some flexibility in your install. Or a route for an airline for an external tank
I bought all this crap a month prior to finding this kit DC made. I would have been much easier had I found this sooner as I have close to the cost of the kit in the ARB bracket, wires, connectors etc. I STILL may be back for the brackets Dirt Church has made.
We’re you able to route everything under the inverter through that grommet?
Hey guys, I would appreciate any input on my design for my Tremor air system. Airbags are a down the road project but everything else I would like to install in the near future. Thanks.
I’ve had all of this for nearly a year - the ARB compressor and the Dirt Church kit. Finally started the installation yesterday. Compressor is mounted, air lines are all in place. The wire harness is spliced, hole drilled. Ready to run the wiring and get it going! Will complete after work this week. Rain, and other obligations, kept me from completing it today. Stay tuned! (Two weekends from now should be my Ford winch installation..again..finally..). :cool: (despite some of the issues I’ve read about regarding the winch)
Thank you all for the recent orders.
I wanted to let you know that we are a couple of weeks away from releasing this kit for the 2017-2020 and the 2021-2023 F-150/Raptors. After countless prototypes have been created, the production parts are currently at the laser shop.
In addition we have the 2017+ Superduty compressor mounting kits in stock.
Please let us know if you have any questions.
My 22 7.3 doesn’t have that grommet under the inverter if that saves anyone some time
I finished up all of the electrical portion this evening/tonight. Don't underestimate how long it takes.. it was quite the battle.
My wiring harness was a bit extra long, so I did a different route to the chassis ground/breaker connection than what is in the instructions so I could 'eat up' some of the extra length. I think it turned out perfect.
Tested the ARB compressor and she works! :D Will install Milton 'V' couplers tomorrow and be done with this install. All the hard stuff is done and I'm glad it's over with.
Stupid question probably: I see in the instructions and on Bronco’s install they drilled the 4th squar in from the door where it is slightly under the carpet/vinyl where it’s more inconvenient to drill. Is there a reason for this that I am missing I’m about to drill the 3rd square in that is easy to get to. Thanks!
Look at the crossmember underneath the truck to make sure you aren't getting too close to that. I don't recall where the recommended hole is relative to that... That's the only concern I can recall...
All i can see if i do the 4th one it puts it directly above the main frame rail. Guess it would be more protected come out of there but harder to shove stuff through. Instructions just say use the picture as a reference and just shows hole by the edge of the carpet. Overthinking it i’m sure, just didn’t want to drill a hole then find out there was some big reason for that spot
Sorry, don't have any better shots from mine... I'm pretty sure I placed my grommet in the as-described location from the instructions:
