Triggering Driving Light/Light Bar Relay Off LED High Beam
I am very interested in this. It says "must be wired to a relay" which means they don't include a relay? Anyone used this yet?
A lot of your aftermarket lighting solutions have a relay, so you would just run that trigger wire to the pin on the relay or such as the lights from TRS they have a harness that you remove the push button moment switch, attach the bare wire lead harness, then attach that wire to the trigger wire from that harness above.
C1005 is the official name for the snow plow plug per my wiring diagram. Pin 8 gives me 12volts. The OP is talking about pin 10. Both pin 8 and pin 10 are used in halogen trucks to power the lower bulb, high beam.
I encourage people to learn how to depin connectors. OP describes a process where he cuts the wires, adds the trigger wire. Effectively this makes 3 splices, while this works, it's not good practice as harnesses typically have just enough wire for the circuit. Unnecessary stain is added to the connection with this method.
It is better practice to remove the pin you want to spice into. By removing the pin you can remove the sheathing for the wire you want, twist connect the new trigger wire, solder and add heat shrink before putting the pin back in the connector. This method has 2 major benefits. 1.) Continuity is never broken of main wire and thus less strain on connection. 2.) It looks OEM, and when done right someone inspecting the engine bay would be hard pressed to recognize the harness was altered.
Edit: I'm surprised just how many posts in this thread are folks trying to sell products to solve this simple problem. Also the guy that tapped into his CAN network, that's super sketchy. So many modules in these trucks communicate on dedicated networks, I would never add a non OEM device to the network (that's purpose is to interrupt network signals). If that non OEM device falters you could end up in a situation where the whole network goes down, that's dangerous.
That’s true, but to do automotive wiring correctly you should never solder wires together period. I did it the way I did by not cutting any wires, just insulation. The correct way would be to use something like a Deutsche connector. When I wired up an aftermarket ECU, I used those connectors because solder can crack and on rough roads when this happens the wires break away. You need a specific crimping tool for these connector pins and I generally keep a few plugs and connectors around, so if need be I can go this way. Or the way you suggested.
Just curious, instead of splicing, crimping, soldering, etc. why not just buy the snowplow plug with a pigtail? This way you don't ever have to worry about anything if you change/remove accessories. Bonus, it'd be easier to wire up the pigtail instead of trying to do all this under the truck.
Fair enough. I do appreciate the post. Sorry I was on my high horse when I made that post. I was just frustrated that in all the searching (on multiple sites) for which wires to use no one actually just put the pin numbers. Even in the official wiring diagram the details on the snow plow plug are lacking. To further complicate matters my truck came as a halogen and I retrofitted OEM LEDS about 6 months ago. After hours of research I figured out that the wire colors before and after the snow plow plug are flipped around in halogen trucks (it makes no sense, my wiring diagram confirms it). However the circuit/pin is the same between the trucks.
I did use a pigtail (that I made). Plus I put in a waterproof 4 pin plug before the relay.
Extra connectors are nice and user friendly but they are not without their faults. Extra connectors are just one more thing for water to get into and fail. Third party vendors use varying quality plugs and craftsmanship.
was anybody able to find both these connectors online to make our own harness ?
I am in Australia. We don’t have snow ploughs. Well, maybe dedicated snow ploughs owned by the government agencies but I’ve never seen one. So there are no snow plough kits or anyone who’d know about them. Why would there be.
When I did this, I asked here and no one knew of this pigtail. There was apparently something for the F150 but no one knew if it’d work on a super duty and when I looked I couldn’t be sure if it would work so I didn’t want to risk it. No one knew how to do it so I just found a way to do it. Since then, the pigtail has become available, or known about.
I ordered the pre made one stated above, it should be here in a day or two. I will update
I ordered the Custom Auto Works adapter listed above. Integrated really easily into the truck and the lead was plenty long and already had a butt splice terminated. Hardest part was pulling down the wheel liner and really it’s not bad. There are some tiny screws along the edge that require a 7/32, and two bolts with 10mm heads. The harness is tucked up there but the red locking tab makes it easy to find.
Used the wire to trigger a set of Diode Dynamic Fog Pocket lights. Very easy wiring and they they include an adapter to connect to an upfitter switch. I connected the trigger wire instead. Plan to test it out this weekend.
so probably a dumb question, since that is the snow plow harness, do these DDFs automatically trigger when you turn on your highbeams or fogs (not sure which sense you used for trigger). I am thinking about going this route and maybe using the highbeam trigger from the SP harness to turn on/off my hood pods.
If you use any of the trigger wires, don’t forget that they are low current, only to be used in conjunction with a relay. Do NOT try to power lights directly from the trigger wire.
relays are already in place on the hood pod harness, just looking to potentially change from upfitter trigger to maybe highbeam trigger with this harness.
