so probably a dumb question, since that is the snow plow harness, do these DDFs automatically trigger when you turn on your highbeams or fogs (not sure which sense you used for trigger). I am thinking about going this route and maybe using the highbeam trigger from the SP harness to turn on/off my hood pods.
The Diode Dynamics fog pocket kit replaces the factory fogs with two led pods on each side (4 led pods total). One set has a fog light pattern and the other is their combo which is a fog and a long distance pattern.
The Diode Dynamics harness ties into the factory fog signal. So the fog lights come on with the factory fog button on the dash.
I used the snowplow harness to get the high beam trigger which turns on all of the lights. I end up driving in the mountains pretty late sometimes and have a couple close calls with Elk. I was pretty disappointed in the light spread with the stock high beams so this should really help light up the roadside peripherals.
You could easily set up your hood pods to trigger off the high beams using that signal. It wouldn’t be too hard to source connectors or splice into the factory set up, but for me I was time constrained. The $35 for the premade harness saved me a bunch of time and that made it worth it for me.
