Triggering Driving Light/Light Bar Relay Off LED High Beam
What has to be done on super duties for the hi beam trigger on LED’ as that’s on my list of must haves
Read post #1 and #12 of this thread. You wire it up as you do conventionally
I did read that
Trying to see if wiring into a SP9100 system has unique requirements I’m having the SP9100 installed & trying to learn while not being stupid about programming it
This is the switch pros unit & program
Im using a mount from sdhq they call the flow through console mount. Its backordered though and ive been waiting a month on it.
i have the sp9100 on two other vehicles so this will be my third. I like them. No problems and wiring is straightforward, except for hi beam triggers on led equipped super dutie.
ive got everything tied to my upfitters currently but will swap over once my mount comes in. I am running dual baja squadron pro fogs and this will allow me to use one set dimmed as daytime running lights. The dimming feature is great because you dont always want full output on some lights.
What all do you have programmed into your SP9100??
Looking for ideas other than having some lights come on with the hi beams & others with the headlights & then able to manually turn em on
I did read that
G.Damm you TJ, I did not know how cool this shit is and did not know that I have to find money for this.. Thanks.......
Hey guys, I solved this issue on my 22' as the wiring is different with the sync 4 12" display trucks. Check this thread out if your still looking for a high beam trigger wire with factory led head lights:
I'm just here to say thanks for this! I went it and the post from your reply.
Would it be possible to reach this connector by removing the airbox instead of the wheel well liner/s? I have to pull mine anyway for routing other electrical.
Dont have a plow harness but bought the connector and wanna tap it for my halogens headlight system to trigger relay running upfitter power to light bar on bumper.
I had these guys build be a customized version of this harness, which has two outputs - +12 V for running lights and high beams. I can use the high beam trigger energize the relay, then a a diode, to have multiple controls over the forward facing off road light.
So, either the high beam turns on the the led light bar, or the upfitter.
Question for you - does this plug into the snowplow adapter or is like a pigtail between the headlight and the rest of the wiring harness?
Also, what was the process for getting a customized harness?
I don’t know. I can’t remember what access was like from above. I suspect not.
Just remember what it says on the description-not for use for heavy loads. Whatever they classify as heavy loads. A pity they don’t just give a maximum current instead.
Yep getting a relay and a diode to upfitter. Good reminder though!
I picked up a similar adapter to tie into the DRL, and it says max 5A.
I am less concerned with max amperage as this is going to be used to trigger a relay.
Is anyone able to give context on what this harness plugs into? Is this the snowplow upfitter plug? If so, that means that the snowplow upfitter connector is not a a deadend.
The one that I linked plugs inline with the headlamp.
Custom Auto works is in the process of making the plow plug adapter with a high beam triger
I talked to him last night on the phone after sending him the wiring diagram that's been shared on here and the link to Ford's Upfitter website for more info. He told me a few of us had been asking and he was going to get a couple made this week and shipped out. Unfortunately, I still don't have a truck to try it out on for him yet. Really friendly guy and highly recommend checking out his website!
I could try it, I have hood pods wired into my upfitters, real easy to undo and wire into this new harness and test it out with flash to pass
