Triggering Driving Light/Light Bar Relay Off LED High Beam
If you wish to trigger your driving light or light bar relay so that they are switched off your high beam, I have finally got this to work without blowing the BCM. You can also run auxiliary indicators and parking lights if, like me, you have a bullbar.
It is actually quite straightforward, if a somewhat time consuming process. You will need some sidecutters, a soldering iron, heatshrink and a heat gun. To make it tidy, add some electrical tape and cable ties. And a 1/4“ drive socket set. I found I had to use both metric and AF sockets to remove the inner wheel well liner. I also had removed both headlights and grill as I was also installing the bullbar. Note, my truck is RHD so you’ll have to convert this in your head for LHD.
Remove drivers side inner wheel well liners. Once you have both out, you may want to consider removing the drivers side headlight. It lets more light in and also makes it easier to run cable. I also found a convenient earth point hidden by the headlight.
You will see a white connector in the middle of the wheel well, and a bigger connector to your left near the firewall. Ignore them. To your right, toward the front of the truck but tucked up against front guard, is a black 16 pin connector. There are about 15 wires on one side and only 4 or 5 on the other. To undo the connector, you must pull back a red locking tab. On the side with lots of wires, in one corner there is a grey wire. That wire is for the LH indicator. Next to it moving away from the corner is a yellow wire with a blue trace. That is your RH indicator wire. The next wire down is a blue wire with a grey trace. This wire is for your parking lights. Go back up to the grey wire and next to it in the other corner is a grey wire with a brown trace. This is the wire for the LH high beam. It doesn’t matter that it’s for the LH side, it just needs to trigger the relay. Just in case there is a difference in my truck because it’s RHD, check with a multimeter .
I cut away the tape and flexible conduit to expose more of the wires. Although there are no corresponding wires on the other side connector, I cut each wire about 40mm from the connector. Just in case I get it wrong there’s enough wire to fix it! I cut and soldered each wire in turn. then at the end came back at the end with the heat gun for the heatshrink.
The high beam trigger wire went to pin 86 on the driving light, with pin 85 to earth, pin 87 to the driving lights and pin 30 to the upfitter switch.
I will try and post a photo of the connector and where it is in the wheel well. I am still having trouble uploading photos.
I hope this helps, and good luck
Can u email me the steps as you said . Upload photos! To : [email protected]
For those guys with the bumper bars. How are you routing your wire harness, especially those with multiple front off-road lights. That harness is huge.
@JTredway : Since Diode Dynamics has a wide variety of harness and smaller splices it was pretty easy. I have 4 SS5 lights, paired with a short connector, each pair run off one connector from the main harness. Main harness is triggered via SP9100.
If you mean the SnowPlow connector it's a VERY simple connector buy from CustomAutoWorks. I had him add on a few other trigger wires as well. You just need to email/call him.
did that would be cool, i wonder if you have to diode it if you are using something like the upfitters.
The purpose of the Diode Dynamics adaptor connection is to utilize the high beam trigger output from the truck to trigger a relay. Then you run the upfitter output through the relay to another relay that powers the off-road lights. That way you can turn on the upfitter switch for the lights, and they will turn on/off with high beams. Easier for use on roads (of course with DOT approved on-road lights………)
thats genius, i might need to go down this path. My in laws have a farm out in the sticks, talking it's darker than night and full of skinwalkers kinda dark. While it's not a PITA to flip 3+ upfitters, it does get kind of annoying and would be much easier to auto dim out as part of the auto highbeam and vice versa versus constantly reaching up there like I am launching missiles or deploying flares all the time.
I got a no-limit permit for that....PM me. 🔫🔫🔪🔪
C'mon man......You got admit if you saw a few birds launch off the rails ATL would be even MORE fun to drive through. Of course popping flares would just mean you are NOT holding the standard. 🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣:cool::cool:🇺🇲🇺🇲🇺🇲🇺🇲
I'm a little late to the party as usual, but I'm ready to join the club :).
I first had my driving lights controlled from an upfitter switch, but got tired of reaching up trying to find the switch in time to not blind somebody. Then I changed and put them on the factory switch.....which I have to search around for while blinding people.....
Hopefully this will be the answer.
Only planning on using a single relay with the high beam trigger harness since my DOT SS3 Pro's only pull a max combined of 5.4A and any upfitter can easily handle that current draw.
Big thanks to both Custom Auto Works and Open Trail Creations for quality products and quick shipping!
Here's a thought, use the upfitters as the 12v supplies, use the headlight high beam trigger as the trigger, use the upfitters to toggle (leave on if you want) which lights you may want to use. This way you can still use the HB around town (UP FITTERS OFF) and then when you are back country you can select which lights you want. I might try this.
I'm planning on using the high beam trigger wire to power a relay coil, upfitter switch #1 (from factory upfitter switch relay) wired across N.O. relay contacts directly to the lights.
Upfitter switch #1 factory relay is sized for a maximum of 25A current draw, my two lights combined pull 5.4A. I don't see a point of a second relay for powering the lights in my particular case.
The only time I ever use my driving lights is when I have the high beams on.
I agree with the previous posts, removing the air box was quick and simple and gave me easy access to the snow plow plug.
This is what i did, and ended up with quite a bit of relay logic :D
20230220_180527-copy-webp.113267
All finished and works as intended.
I added a 2A inline fuse on the headlight trigger wire and used a relay that has a built-in diode and a fuse holder for the contacts.
There's a little spot on the firewall that will let you hook the relay's metal mounting tab into that worked out nice for me.
Removing the air box was definitely the way to go for accessing the snow plow plug.
Well done!
