Just did an fluid change at 46k miles, and mine was an dark brown color removed. Was surprised at that given the lowish miles, lack of towing, but use off road in the mountains. Low speed crawling & easy highway miles.
However I did come up with an near mess free solution for replacing the original pan
The suctionater! drilled an hole in a 5 gallon pour bucket, stuck an piece of tubing in it, then a smaller piece of fuel tube at the end.
At the spout connected the shop vac to create suction into the 5 gallon reservoir
dropped the pan, still had an little fluid left in it (first picture) so being careful i was able to remove it without spilling a drop on the floor or cross-member!
changed out the filter. Magnet on the stock pan did have some glitter, but not bad at all probably just the initial wear in of the gears
torqued all the bolts in the torque pattern (bought an new OEM Oring for the pan)
new pan looks nice. Drove the truck hard for 20 minutes to get the temp back up to 215F
Pulled back on the rack, left truck in park and running. Topped back up with fluid ~1qt
Want to say it was around 20 quarts added total
