Featured
- #741
Got the same email, had the same laugh… though TBF if you want one saving $136 is better than not saving $136, but I doubt it’s gonna sway someone’s opinion on buying one or not.Just a heads up ... Transfer flow is having a Memorial Day sale. This tank will cost you $136 less with this massive sale. Lol
That was the rub on a group buy for the forum. Not a large enough discount to create momentum for a bunch of people to buy now vs. later. I'm sure they'll eventually get most of those sales anyways because they don't have much competitionGot the same email, had the same laugh… though TBF if you want one saving $136 is better than not saving $136, but I doubt it’s gonna sway someone’s opinion on buying one or not.
They can't keep them in stock....why would they discount them any more than they need to, there are no alternatives on the market...I paid full price for mine and it was worth every penny.Got the same email, had the same laugh… though TBF if you want one saving $136 is better than not saving $136, but I doubt it’s gonna sway someone’s opinion on buying one or not.
I think that’s exactly what I said. In slightly different words.They can't keep them in stock....why would they discount them any more than they need to, there are no alternatives on the market...I paid full price for mine and it was worth every penny.
No problems so far. But I do live in the desert. I also keep mine topped off most of the time too, to try and avoid condensation inside the tank.Hello, everyone. Long time lurker, first time poster here.
I was researching how problematic the rust on the OUTSIDE of these tanks is over time, and came across some discussions on rust forming INSIDE the tank and causing issues. Most notably, these:
TransFer Flow tanks and rust
On another list (Woodalls rv forum) there is a thread about auxillary fuel tanks. One person posted the following-- "Be careful of the transfer flow tanks. They are good tanks and well made buuuuuuut - they are made from aluminized steel which is great but they are welded with regular steel rods...www.dieselplace.com
Rusted Transfer Flow Replacement Tank
Went in for a fuel filter change and found rust in the filters. Dropped the gas tank to see whether it was the tank or bad fuel and found rust around the top. Bought it June 4, 2008 and had it installed by a very reputable shop in Fort Worth, TX.www.powerstroke.org
My question for the kind folks on this thread is have you had any issues with rust forming in your 58g? Is this still a concern? Thanks.
Thanks for posting - the article makes a lot of assumptions on how the competitor plastic tanks are made - lacking in facts - except what they can offer in steel - appears to be nothing more the marketing BS piece for those selling metal products.This article was a few years ago, and from a "pro-steel" trade group, but they had some very good points about how some of the aftermarket ones were made. In additional research on aluminized steel, assuming Transfer Flow's QC is good and you don't have significant moisture on the inside, you shouldn't have any issues. Having owned (2) titan tanks on diesel trucks, they definitely were not constructed as well as the OEM plastic ones were. I have had my 58 gallon transfer tank for almost 1.5yrs and no issues or rust on the external; tank appears to be quality made. Not having to fill up often when towing is great.
Home
MST Steel supplies high-strength, hard-to-find steel with advanced processing and 85,000 tons in Michigan and Kentucky inventory.www.mststeel.com
Did you check all the vent lines/evap system make sure they are not kinked/blocked...sounds like you have extra air/vapor in the tank preventing the last few gallons from entering the tank.I've been having a problem with mine since install over a year ago.
The truck simply won't see more than 49 gallons... We've drained the tank, dropped it and filled from zero to verify there wasn't an issue there. We've check that the resistance is reading the correct ohm value. I've checked Forscan to make sure the tank is set to IPC 220/58 and it is.
But after all of that, all I see is 49 gallons and TransferFlow doesn't really want to deal with it. Sure, John Beaver is reachable but the moment he sends it up to his Technical Services Manager - all communication enters a black hole - never to be seen again.
The tank is great in theory, but I don't want to be counting miles every fill-up when I paid as much as I did.
Anyone else see this before?
The shop that did the install, twice, found no issues. The tank will accept 58 gallons, the truck just cannot see 10 of them.Did you check all the vent lines/evap system make sure they are not kinked/blocked...sounds like you have extra air/vapor in the tank preventing the last few gallons from entering the tank.
Hi,anyone near Oklahoma that has upgraded to a TransferFlow still have their stock tank and willing to part with it?
Gotcha so the tank works as advertised just can't get your MTE guage working?The shop that did the install, twice, found no issues. The tank will accept 58 gallons, the truck just cannot see 10 of them.
Oddly enough I still have the stock Tremor F250 Tank and all the parts and pieces they gave me back after the TF tank install. I am located near Lawton/Fort Sill.anyone near Oklahoma that has upgraded to a TransferFlow still have their stock tank and willing to part with it?
