Tire Pressure Question...
^ ^ ^ That's Jon, dealer principle of Whiteface Ford, named after a cattle breed.
Jon's a good dude, and for a dealer exec he's very knowledgeable on the nuts and bolts; a regular "car" guy/motorhead. He knows his stuff.
He mentioned he set his "placard" pressures to 30 psi using FORScan.
That's good to know! because using FORScan, I set my placard pressures to 35 psi since I want to (and have been for over 9 months now) run a 40 psi Cold Inflation Pressure, but I also want to air down to 20 psi when driving slower, off road.
How is tire wear impacted at 40? I love his videos...very informative!
Tire wear is normal. My only extravagance is slightly increased rolling resistance in an age of expensive motor fuel but the very small increase in ride comfort is just enough to matter.
I do regular, 5000-mile 5-tire tire rotations in a "rearward cross" sequence.
Front tires get crossed to the rear axle, rear tires go straight to the front same side. The left front stops and rests up in the spare tire winch perch for 5000 miles after the spare goes onto the right rear, and so on.
It's good to note, too, that my lightly-optioned Godzilla XLT is roughly 2000 lbs lighter than a diesel Tremor, so my tire pressures setting reflects that.
I'm driving at 50 now all around. May drop to 45 and see if I feel a difference.
2 psi can make a difference.
Remember, too, that 40 psi remains more than enough pressure to support both ends of our trucks when unloaded, plus 1000 lbs, even in the OEM 285/75-18 tire size.
Carli or CJC Off Road have been recommending these cold inflation pressures for their customers who run 37s.
Good to know!
How far below the set threshold does the TPMS light get triggered?
My guess would be somewhere around 2-5% at around 60# threshold. (1-3 lbs.) But that could be subject to sensor accuracy and linearity at different pressures. It may be a cool experiment to set the threshold at a couple different levels and then let the air out to see where it triggers the sensor.
Before I changed them, I set all tires at 60 with no light. One day it got unusually cold overnight (like 40 degrees lower than the day). That morning, my rear tires were “low” at 55ish psi. So that’s like, what, 20 psi below standard?
I do not know how far below the trip point it was. Only that I had to go back to door plate setting to get it to go away.
60 - 55 is 20psi below???
I wasn’t very clear. This was before I changed the settings. IIRC the rear tires are supposed to be 75 from the factory. When they hit 55 they were considered low.
What I don’t know is if they would have tripped the light anywhere between 55 -59 since I had them at 60.
Understood. My fronts are 60 and rears are 65 on the placard.
Interesting. I swear mine were 65/ 75. It’s about 1000 miles away from me now so I can’t check.
For the record, I have not changed my default settings, and the low sensor doesn't trip until around 55. I don't know what the trigger default is when new but there is enough room even though the "label" says 60 front and 75 rear, to allow it to drop to 55ish before tripping. That would leave me to believe the threshold is set somewhere near that 55-psi mark on both rear and front.
I know that they will ride without tripping at 59 all around, which is where I like to run at all times. (truck is pre-loaded with a lot of accessories) But when it gets cold, might trip at 55. (Cold is relative, maybe in the 40s)
Leaving at this threshold has saved me a couple times, I've had two flats (nails) that tripped at around 55. Both times on mountain roads. :(
Hey guys...just trying to see what my best next steps are and your thoughts on what's happened...nothing serious just annoying.
1. Had my Goodyear tires removed and installed a set of Falken Wildpeak AT4W tires
2. Had them set tire pressure to 50 all around
3. They relearned the TPMS sensors
4. Now getting TPMS light with tire pressures at 50 (rear only is in fault)
Before I changed out the tires, I could have 50 psi and no TPMS light. Thinking that when they relearned the sensors at 50, this created this "new" problem. As an engineer, I try to think through the process and what's changed. The only changes were the tires...and that won't create the issue. The TPMS sensor relearn and that's it. I know I can do a Forscan and not looking for this as an answer. Wondering if I have them set at the recommended pressures and have Discount Tire do a new relearn at the factory pressures and then air down to 50 if that may "fix" the issue...just a thought. Interested in your feedback before I even consider going down the Forscan rabbit hole. Thanks!
The rears need to be set at like 65 so the low pressure light doesn't come on. I run 55 front 70 rear. 24/7 149,960 miles
You make a good point for those drivers who chose to have displayed system stats other than TPMS pressure readouts for all four tires on the ground.
I'm weird, and I have to have my tire pressures displayed all. the. time.
I like glancing at the readouts here and there to observe pressure changes from direct sun on one or both tires facing that direction, or when cruising on the interstate on a warm day. Pressures can rise as much as 8 lbs from 40 cold, depending on the weather.
I like when I'm running around town then before heading home drive a 3-mile stretch down to the coast and back and then seeing my four tires at equal pressures of 42 psi, or the four all reading 43... it soothes my OCD. Hahaha.
/blather
Point being I may be able to observe the anomaly, the one tire that's taken a piece of road hazard and bleeding out before I might ruin it, all without getting a TPMS warning. I hope I never have to, though.
Time for bed. *yawn* Catch you fellers on the morrow!
Just lower them to 10 psi. It's like driving on a cloud! 🤪
The biggest factor is going to be the actual tire used. Some 37's are 50PSI max, others are 65PSI max. People should first look to their tire sidewall to determine where to start, then go by their own personal "ride quality" matrix.
I have a 7.3 and not a diesel.
I'm pretty certain the door placard isn't changed between a diesel or gasser for the tire PSI numbers. The Tremor tires are the same regardless of the motor or trim packages. It would be interesting to see how many (if any at all) are different with different motors. :unsure: :unsure:
:cool::cool:☕☕🇺🇲🇺🇲🇺🇲🇺🇲
Indeed.
They (people) should also always refer to the tire maker's Load Inflation Tables to determine if the lower pressures they want to run for greater ride comfort will support 125% the load of each axle at the current curb weight as they have their truck loaded.
I think I have that right... 😝 You know me, "often wrong! but never in doubt."
Had my wife look for me because the curiosity was killing me.
60 front/ 75 rear. On the 350 diesel.
