Tire Pressure Question...
Part should be here today. Still haven't received my Forscan email code yet. The only other thing I'd like to do is disable the seat belt graphic that pops up at start up. Where is that and what's it called. Don't care about the chime...just the graphic elimination. Thx
UPDATE: Forscan code received and activated!
Seat belts and most things you will use are in plain English. 👍
Sweet...thanks! Just waiting on Amazon now to deliver the interface. Software is ready to go. Is there a specific option for the screen notification only versus chime elimination? Didn't see that on the Forscan spreadsheet which is why I'm asking.
Interested.
I believe that the seats diagram box that gets superimposed over our dash readout is a problem to get rid of entirely. I wish it weren't so, or, if it is not then that would be a very recent development (within the last six months).
Good luck, still. Cheers.
So, are you saying that there is not currently a way to get rid of that start-up graphic?
I said in so many awkwardly-phrased words, "as of six months ago, getting rid of the little, superimposed seatbelts' diagram box was still a problem".
But don't quote me. 😝
Perhaps someone else has arrived at a FORScan solution, but, again, six months ago that was still a problem.
I only mention this so that you won't be surprised, rather, won't be alone in your frustration at possibly being unable to do so.
I think when I asked it was no... But to Apples' point, it could have changed or I may not have asked the right questions, searched enough.
they told the truck it didn’t have seatbelts.
I remember seeing that. No one could offer much about how this may affect the airbags software protocols.
IOW, their solution did not sound simple, therefore to my way of thinkin' that would remain a problem.
I wish it weren't! believe me. Also, I haven't done squat to squelch the warnings nanny audio if I don't buckle up just to pull the truck forward in the driveway, etc...
To the original posters question:
If the TPMS value (door sticker) is set at 65 psi, then:
-TPMS light goes on at 70% of set value (65 X .7) = 45.5 psi
-TPMS light goes off at 90% of set value (65 X .9) = 58.5 psi
-All driving modes / ADAS systems fault out at 30% of set value (65 X .3) = 19.5 psi
To turn off your TPMS light, just start the truck or turn the ignition on and air up the tires past the 90% below door sticker value, then when TPMS light goes out, then lower the tire pressure back down to 50 psi.
There are two different seatbelt alerts called Minder and Monitor. I like using the Minder to tell me if passengers are buckled (kids in particular) but I disabled all chimes and the Minder display for the driver.
Change the following from "Present with Minder" to "Not present":
IPC Seat Belt Configuration - Row 1 Col 1
Change all of the following from "Enabled" to "Disabled":
IPC Belt Minder Chime Row 1 Col 1 (this is the Driver position, each passenger position has a column/row)
IPC Belt Minder Chime Operator
IPC Belt Monitor Chime
IPC Belt Monitor Chime Operator
Thanks for the info, but this is as clear as mud to me. I have my drivers seat chime disabled but not passengers. I don't want to eliminate passenger chimes. All I want is to remove the start up graphic, and that which comes on after putting the vehicle in PARK while leaving the engine running. If the above will not do that, then this isn't much help to me, but maybe to others.
I would expect that changing all of the Seat Belt Configuration positions to "Not present" will do this. I have to be honest I'm surprised you like chimes more than graphical displays since they don't tell you which passenger is unbuckled.
As for the Park while running you may be referring to one of these (both in IPC):
Chimes - Vehicle Running with Door Open
Chimes - Key in Ignition Reminder
I only have a front row passenger...no one's ever in the rear. It's a reminder for my wife to get her damn buckle on :) The graphical display stays on for about 1-2 minutes after you put her in drive or you can just hit the OK button. I would like to eliminate that screen entirely if possible. I don't think you understood the second part of my question.
When you put the vehicle in PARK and leave the motor running, the seat belt graphic screen comes up again and you can NOT get rid of it and no OK button to click. Nothing to do with chimes or vehicle running with door open or key in IGN reminder.
Not sure. I got rid of all of the seat related noises and splash screens. When I look at the seats through the menu, only the driver's seat is green with the check. No matter who is in the vehicle and which seat belts are fastened. All I need to do now on forscan is all the rest of the noises it makes when you open the door or whatever else 🤣
Amazon just delivered and the TPMS sensors have been lowered. All good with the world now and no more TPSM light. Going to play with more settings over the weekend to experiment a bit.
Hey guys...just trying to see what my best next steps are and your thoughts on what's happened...nothing serious just annoying.
1. Had my Goodyear tires removed and installed a set of Falken Wildpeak AT4W tires
2. Had them set tire pressure to 50 all around
3. They relearned the TPMS sensors
4. Now getting TPMS light with tire pressures at 50 (rear only is in fault)
Before I changed out the tires, I could have 50 psi and no TPMS light. Thinking that when they relearned the sensors at 50, this created this "new" problem. As an engineer, I try to think through the process and what's changed. The only changes were the tires...and that won't create the issue. The TPMS sensor relearn and that's it. I know I can do a Forscan and not looking for this as an answer. Wondering if I have them set at the recommended pressures and have Discount Tire do a new relearn at the factory pressures and then air down to 50 if that may "fix" the issue...just a thought. Interested in your feedback before I even consider going down the Forscan rabbit hole. Thanks!
Funny you made your post. I was just looking at this same situation. According to this utube vid from a Texas Ford dealer you need to go into the programming and reset the tire pressure to your new pressure.
Yep...exactly what I did and was super easy with Forscan. Best $69 dollars I spent and enjoying all of the changes I made :love:
^ ^ ^ That's Jon, dealer principle of Whiteface Ford, named after a cattle breed.
Jon's a good dude, and for a dealer exec he's very knowledgeable on the nuts and bolts; a regular "car" guy/motorhead. He knows his stuff.
He mentioned he set his "placard" pressures to 30 psi using FORScan.
That's good to know! because using FORScan, I set my placard pressures to 35 psi since I want to (and have been for over 9 months now) run a 40 psi Cold Inflation Pressure, but I also want to air down to 20 psi when driving slower, off road.
