Stock Tremor Wandering Issue
Your caster from the factory is going to be around 2.5-3.5 if you add caster shims and take it closer to the 5 range it will prolly clear it up.. I did this on my last f350 and it made it rock solid but my 22 drives like a dream and haven't messed with it
Do you think adaptive steering has anything to do with it? I didn’t put it on mine and was wondering about that…
I see what you did there… lol
Airing down definitely helped me, felt like I was driving on donuts. I am very interested however in the caster adjustment. Anyone have a link to where they bought offset bushings?
It took about 3,000 miles for my tires to settle in. I run 60 in the front and 70 in the back. I'm at 43,500 miles now the tires are fine. I'm expecting to get a bout 5,000 more out of these if my new truck isn't here by then. I will buy them again now that they are broke in. At first I was hating them.
Look at pmf suspension they sell some that's where I got my last set
It’s TIRES, Tires, and tires. Those are the reasons. Lots of posts about it on this site in the history. I switched out my tires and gone!
Spending 70k+ plus on a truck, then shelling out another 2k for tires right away feels kind of shitty.
What tires did you get?
Fox stabilizer helped. Airing down helped. 3500 miles helped also carrying load as opposed to an empty 1 ton truck helped. But the drift never went away. I now have a thousand miles on method hd rims and toyo 35/12.5/18 mt’s. Way better than at first but still wanders enough to be annoying. Changing caster seems all that’s left to try.
Don't get rid of your stock tires unless you want different ones. Just drive the truck. It takes at least a couple thousand miles to get them to flatten out.
The lugs are pretty tall and the rubber fairly soft. Driving them flattens them out and causes the rubber to firm up. Like I said earlier, it took about 3,000 miles to get mine to break in. now they ride no different than any other tire I have ever run.
I drove 8k miles at 70/80 psi, recently reduced to 60 all the way around. Truck did not wander at high pressure, but now wanders. Since reducing pressure I have bad cupping only on the front passenger tire.
Any ideas?
A few of us have installed centramatic dynamic wheel balancers and have noticed huge improvements in wandering and other things. Inexpensive, effective upgrade.
mine felt loose and unstable at first too. most noticable in wet or slippery conditions. im at about 4000 miles now and absolutely love it. Definitely give the tires a chance to break in. im at 60F/70R for tire pressure, I tow fairly regularly so airing up and down the rear all the time isnt realistic.
Agree. @CypherAZ at least try lowering the pressure slightly first before you decide to jump on the Duratracs suck bandwagon. Note that there have been others that have changed tires and still have the wandering feeling, too. Honestly after driving on these for 3000miles I really like them for my usage thus far. They are quiet, stable, good traction in rain and snow. I have only been in mud once but they were fine in that situation too... Certainly they may not work for some, and that is fine, but the two things you can try that are free are time and pressure before you feel like you need to spend $$.
If you were to increase caster on your unloaded truck, then wouldn't the caster become too high when the truck is loaded and squatting some in the back, making the steering heavy?
-SR-
Mine did that for the first 1000 miles or so. It will go away.
Thanks for the replies everyone, going to try airing down my tires this weekend and see how it goes. Will report back if the issue doesn't go away with some mileage as well.
No one has mentioned this but part of what happens also with driving over a thousand miles is you simply get used to it. I realize that fact when I drive my wife's SUV, which is seldom.
