Now that I've had my truck for a couple weeks and 1300+ miles, I have some first-hand thoughts on the "wandering".
The day I drove my truck home, I felt a little bit of what some my call "wandering", and I just assumed (based on what I've read here) that it was because of the new tires. it actually went away fairly quick for me, within the first 300 miles or so. To me, it actually felt more like a tight steering system that didn't have enough trail/camber to "auto-correct" itself back to center/straight. I say it because I noticed that for every small steering correction I made, I would then have to "un-correct" it right after, rather than the steering just naturally going back to straight. I have to wonder if, more than just breaking in the tires, if a part of it also has to do with breaking in those new, tight steering joints, damper, etc such that the factory camber is enough to auto-correct your steering inputs back to straight.
You know that thing you do where you turn a corner and then just let the steering wheel spin back to center while you use the friction of your hand to control the steering wheels return rate? When my truck was brand new, that didn't work. Now, it does. I would say that's because the steering components have sufficiently loosened up to allow this to happen, as it should.
The thing drives great!
-SR-
