Stock Tremor Wandering Issue
Update on wandering issue. After trying most other described fixes and only incrementally improving with each change ( different tires , stabilizer, air down tires and moving loads) I found a quality alignment shop. Alignment was in spec with caster at 3.4 and 3.5. Shimmed to 4.4 and 4.9. In my experience and opinion this is the ultimate issue with the wandering. Truck now drives as if it’s on rails. Solidly planted . As straight driving as my Toyota.
Agreed. Glad you got it fixed!
With that said, others need to realize that brand new tires are not the problem. No tire like this requires any "break in".
99% of the time it's an alignment issue.
What shims did you use
Sorry if this isn't the right place to post this, but it seemed most relevant.
Stock 7.3L Lariat Tremor, loaded or unloaded the truck seems to wander in the land all the time at variable speeds. Requires the drive to constantly be making steering adjustments. Anyone else experience this or know how to resolve it?
Thanks in advance!
This was happening to me after I lifted it. It was the pitman arm coming undone. I hear it is an occurrence on lifted trucks, but not sure how often it happens if stock, but worth checking.
All the other "fixes" you spoke of are examples of not so knowledgeable people giving subjective advice, others taking that advice, and fixing (or chasing) symptoms and not the root problem. Sadly many take that advice rather than seeking an expert on the real problem which you eventually did. So glad you have got it fixed and are enjoying the truck as it should have been from the factory.
There can be the occasional truck with a bad component from the factory, but I'm betting that is very rare. On the other hand there's obviously many trucks being built with the alignment barely within tolerances or maybe even totally out due to carelessness or lack of training and oversight. Regardless there's way too many examples of Super Duties in use that have no issues with wondering, regardless of the tires installed to say these trucks or tires are the problem. Unfortunately the numbers of truly skilled technicians in this country are unfortunately on the decline, as fewer and fewer people are interested in learning trade and technical skills and sharpening them to the point of perfection. You really have to search to find a good one but as you now know it is worth the trouble. 🍻
I'm sure that's a good fix, but also wonder if it's at the expense of steering while loaded. When you have at or near the payload capacity loaded down on your rear suspension and the it squats, would it change trail distance of your front tires enough to make the steering noticeably heavier? Have you towed anything with your truck since increasing the caster?
-SR-
This truck is my “alumatent “ ( airstream basecamp) tow vehicle. It’s loaded with tools gear etc always. It was aligned loaded as it will always be so I’ve no idea if that made any difference or even maters but I could not be more pleased with how it completely took the wander away. I also took the trailer for a spin and no drifting while towing.
Thanks in advance!
Mine just arrived and I originally felt the same thing. 4-days later and I am apparently getting used to it or the tires are breaking in from new. Who knows, but I found it has improved to be a non-issue. Like I said, maybe I am getting used to it. I do have adaptive steering.
