- OP 🔹
- #61
- Jun 23, 2020
- 2,089
- 8,565
- 2020 6.7 F250 Super Duty Tremor Lariat Ultimate BAP
- 2022 KTM 500 EXC-F Six Days
Back in October, I joined in on the Tremor Forum group buy, and purchased a bunch of stuff from BuiltRight Industries for the bed. I picked up the full bed rack system, some risers and clamps, tech pouches, and some Retrax compatible mounting plates.
I started out by mounting the bed rack system as per the directions from BuiltRight. They are very simple to follow. My only addition would be is if you have the spray in bed liner, make sure to cut around anything you need to remove from the bed (tie downs, plates, etc) before removal or you will most likely remove a large section of bed liner with each piece.
On another side note, I purposely waited to put my Boxlink tie down things on until this point. I knew from my last Ford that they are a real pain in the ass to put in as recommended. I knew that I would be removing the plates they affix to, so I waited until I removed the plate, affixed and locked the tie down deal, and then mounted the whole assembly together at once. Made life WAY EASIER. Here are a few pictures of the system off and from behind so you guys who don’t want to remove the plate can see how it should fit. The key is to put equal upward pressure on both “sides” of the base. The issue with tightness is that it’s easy to put too much pressure on the outside (the handle part, away from the plate) and not easy to put the same force on the part closer to the plate.
I had a hunch that Santa was going to hook me up with some Rotopax Diesel cans so I was basically in a holding pattern until now. Last night I threw in the tech pouches and mounted one of the cans. Super easy. I’ll probably mount my other one on the other side, but they are thin enough that I might get the extended mount and just double the cans on one side. Too many options! ? I’m loving this BuiltRight bed rack system for sure!
