Sludgemonkey44’s Build and Other Things Tremor
Nice! I'm still butt hurt that Ford removed Silver Spruce as a color option. By far one of my favorite factory paint colors. For the iDash, check out block8head. He makes custom gauge pods that are built in to factory interior pieces. Single through triple. He is super backed up but the work looks quality as hell.
I finally got around to putting in my Banks Pedal Monster and Idash combination and a mounting hickey that I purchased from our forum group buy a few months back. It was a little more of an installation than just plug and play, but it wasn’t overly difficult. The directions that come with the Idash are pretty decent and lay out the process step by step. The most difficult thing for me to figure out was how to remove a few of the parts in my truck dash in order to get the wires for the Idash where I wanted them.
The first step was to remove the grab handle piece.
On this step you need to pop the two covers off on both sides of the handle. That will expose two bolts. They are 10mm heads. Take out the bolts and then pull up and out to pop the whole piece off. If you have a Lariat or above, you will also need to unplug the little speaker before you can completely remove the piece.
The next step it’s to pop off the side panel on the dash.
This part probably took me the longest time because I didn’t know how to remove it, and I really didn’t want to break anything. Well, I finally grew a set and started peeling the panel away starting at the bottom and away from the firewall. It is surrounded by quick clips, but if you’re careful, you can peel the panel towards the open drivers door. The leading edge of it tucks up behind the rubber strip on the door jamb. I didn’t need to pull it out of there, I just held it out of the way.
At this point the wires can be run up and around things and then the pieces can be put back in reverse order. Keep following the general directions from Banks and you will be good to go from there.
View attachment 29106View attachment 29107
From there it was setup and testing. The nice thing about this combination is the ability to see tons of engine, transmission, exhaust data, as well as the ability to adjust pedal performance with the touch of an up or down arrow. It also keeps the settings all of the time with no glitches and no need for a separate app to make adjustments. So far I’m very pleased. I wrote up a better review here.
All that was left at this point was to wrap up the extra wires and to make things tidy. The Idash bundle coiled and hung nicely off of another bundle near the parking brake. I ended up putting my Pedal Monster up on the kick plate behind the console and dash. It fit nicely and is out of the way.
View attachment 29110View attachment 29111
Let me know if you have any other questions. ???
I have the insight Cts3 and don’t plan on a banks setup yet, but I can definitely appreciate the time it took for this write up.
I’ve been dropping random pictures of my latest project on here for the last few weeks, but I never put anything here so here we go…This project all started last fall when I was backing my kayak and decoy loaded Tremor down towards one of the lakes I hunt in a heavy snowstorm at about 4 am. Windows up or down, it didn’t matter, I had about 2 feet of lit visibility behind me. It was at that moment that I finally decided that the weak OEM reverse lights just don’t get the job done for me and my hobbies.
Not being one to typically jump to buying the first thing I see, I researched this site and others for lights that looked like they would suit my needs. I knew I wanted bright durable lights, so I was leaning towards a few options between Baja Designs and Rigid. I was still unsure about the mount location. I loved how the flush mounts look and how they wouldn’t hang down and potentially get hit by debris while off road. My biggest concern is that with a flush mount, the bumper needs cut. And that’s a “one shot to get this right” kind of situation.
So I remained on the fence for a while until I finally decided I needed to make a decision. I decided to give @Nick@ApolloOptics a PM to see what he had to offer. He was fairly new here at the time, but he had already answered several questions for members here and a few members had successfully ordered some items from him. Well, next thing you know, Nick and I are on the phone together that evening with each of us sipping a little spirits and me grilling the poor guy about all sorts of things lighting related. He answered all of my questions and then some. With the help of Nick, I finally decided on the flush mount Rigid SRQ-Pro with diffused light and a black housing. I also really wanted the ability to have it come on with reverse or stand alone, so I decided on a dash mounted 3way switch and harness setup.
My only other concern was about the “whiteness” of the fixtures themselves not looking good with my “sport/blackout” package. Well of course Nick had a solution for me as well. He has worked with a tint product from Vvivid that is dry applied and very easy to work with. He sent me a link to buy it and I realize he’s sending me to a product that he doesn’t carry and won’t make a penny from the sale. TALK ABOUT SOMEONE WHO IS LOOKING OUT FOR THE CUSTOMER! Anyway it ran about $20 delivered and will be more than I will ever need.
With everything in hand, it was a matter of finding enough time to complete the work and enough days in a row of not needed it to leave the garage. Well it just so happened that I had a few weeks off of work recently due to having a surgery, so I had plenty of time to accomplish everything.
First up was figuring out where I wanted the lights located in the bumper and how to make sure they both were symmetrical and “looked” right from behind. This took a ton of time to make an extra template, measure, tape off, measure, look, tweak, measure, stand back and look again, measure again, make sure the tape is correct, mark bumper with sharpie, look, etc. I was probably over meticulous, but I’ve never cut a truck bumper let alone the most expensive one I’ve ever owned.
At that point it was time to suck it up and take the plunge. I used an awl and drill to make a hole large enough to get my jigsaw in and started going to town. I purposely cut my hole a little smaller and then switch to a dremel to finish removing material and smoothing edges.
The lights come with gaskets, and the housing flairs out so the holes needed to be good but not perfect.
At this point I looked at the bare metal that I just uncovered and decided that I uncovered was just begging to rust in the future, so I grabbed a $10 black touch up paint kit with clearcoat at the local auto parts store. I put three coats of black and three coats of clear to hopefully mitigate future rust potential.
At this point it was mount and snug up hardware.
Up next came the really interesting part…running and connecting the provided harness. I called in some backup for help, and we had the harness run along the frame and to the tail lights, up through the drivers side floor board, and around and up to the battery on the drivers side. I drilled a small hole in the dash (I know) for my 3 position switch and wired it according to the directions. The last step was to find power when the truck is put in reverse so I could tie in and have the ability for the lights to come on when I’m reverse. Well, Ford actually makes this fairly easy. We ran the extra “reverse” wire in the provided harness and took it to the drivers side rear. If you look up along the square tubing of your receiver assembly that runs parallel with your bumper, you will find several plugs. We used a tester to find one socket that had power when in reverse, and then connected to it on the back side of the plug where the wires come in. Super simple. I think they turned out perfectly for me.
I did a super quick installation of the smoke tint to see if I like the look and if it made much difference in projected light and visibility.
One of the last two pictures is with the tint on and the other is with it peeled off. I can’t see much difference, so my plan is to take my time and put the smoke tint back on this time and leave it. I like the look a little more. Either way, I have enough of the stuff for me to be able to put the tint on and off several times a year for the rest of my life! 👊🏼🥃🍺😎
So I remained on the fence for a while until I finally decided I needed to make a decision. I decided to give @Nick@ApolloOptics a PM to see what he had to offer. He was fairly new here at the time, but he had already answered several questions for members here and a few members had successfully ordered some items from him. Well, next thing you know, Nick and I are on the phone together that evening with each of us sipping a little spirits and me grilling the poor guy about all sorts of things lighting related. He answered all of my questions and then some. With the help of Nick, I finally decided on the flush mount Rigid SRQ-Pro with diffused light and a black housing. I also really wanted the ability to have it come on with reverse or stand alone, so I decided on a dash mounted 3way switch and harness setup.View attachment 32596
View attachment 32599View attachment 32600
View attachment 32602View attachment 32603View attachment 32604
View attachment 32606View attachment 32607
View attachment 32610View attachment 32611View attachment 32612
Your "Sig" receiver cover is tits. :cool: :cool: :cool:
All that write up about the lights and you comment on my hitch cover. LMFAO! I love you man! We are definitely cut from the same cloth! 🥃😎 And thank you very much for the compliment! 🍻
The truck and the work you did was awesome, tons of effort :cool: :cool:
Fantastic thread! This is the kind of information that forums SHOULD contain!
Thanks for taking the time to share.
Thank you very much for the compliment. I try to be as detailed as possible even though I rarely know if anyone else will actually use this information to make their lives easier in the future. I honestly just enjoy writing on occasion and this has been a great outlet for me to pursue that endeavor. Please feel free to ask for any elaborations on anything I have here, or any questions that you may have. That goes for anyone else out there in FORDTREMOR land. Glad to help in any way possible. 🍻
Great write-up. Love the results. I'll be adding these in the near future.
Thank you very much and feel free to reach out whenever that project time comes if you have any questions or concerns. Good luck! 🍻
I’ve said it a few times around this site, but never on here. I fall into the upper echelon of the age demographic where typically I would have a large online presence and would be very computer literate. Well I’m not that guy. I basically skew towards an older demographic who possess more skills with tools and my hands getting dirty or calloused, as opposed to a desk and a keyboard. I fully respect and appreciate people who understand computers and programming, but that’s really not my cup of tea. I also recognize that just because a person is fluent in technology doesn’t mean that they aren’t afraid to get their hands dirty or have a “desk job.” But I digress…
This forum is the only place anywhere on the interweb where you will find me. Not Facebook or Insta or Snap anything. Just here with my Tremor family. Not hating on anyone else, but that’s just how I roll.
That being said, because of my time spent on this site, I realized two things very quickly.
1) Forscan is a pretty sweet program and it opens up/unlocks a whole bunch of information and abilities that honestly should come standard from the factory. (But that’s a whole other argument for another place)
2) I don’t have the knowledge about any of that stuff and I don’t have any past experiences in anything similar that would help me “fudge” my way through it.
Well that’s where this site and one member in particular came through yet again. One of the many great aspects about being an active member of this site is that you end up conversing with people from your general area who just so happen to already share a common interest with you.
Putting all politics, and general divisive issues aside, we can all appreciate the fact that we definitely have common ground in one place and we can always build from there. Sorry off on a small tangent there, but seriously, we all have far far more in common with each other than we do differences and we would all be better off focusing on them more often.
Anyway, I noticed from his presence here, that he was relatively local to me and also understood Forscan, so I reached out to @Himni via PM a few days ago and asked if he would be willing to meet up at some point and he could disable that stupid double honk as well as a few other things. Well he responded right away and said he had some free time this weekend and would be glad to help me out.
So next thing I know it’s this morning and I’m headed South to meet up with a straight up great dude who not only ran through basically every possible Forscan change with me one at a time so I could choose yes or no on each, but also picked up a properly sized flash drive for me ahead of time so I could have with my original factory settings on in case something goes wrong in the future. (Yes I did pay him back for it. 😁) I must say he went above and beyond to help out a fellow member and I could not be happier with this results of his work.
I’ll finish this by saying that I personally did absolutely nothing today to add to my build, but because of this site and the good will of another person, I was able to get my truck one step closer to being “perfect” for me.
HUGE shout out to @modified for hosting this site so that computer imbeciles like myself (or mechanical if that suits you better personally) and others can meet other like minded strangers who are just crazy enough to meet some random dude in a parking lot to tweak some settings or provide some mechanical insight, and talk Super Duty Tremors in the meantime! 🍻🥃😎
Much appreciation for taking the time to put this into words - many here are in total agreement!
Thumbs up to @Himni and @modified 👍👍👍👍👍
Hey @Sludgemonkey44, thanks to you man. You have a great view and I wish more people in the world would understand we all start off as human. and not take all day pointing out differences. If you need any help please ask me or "the family" keep it moving foreword!
Fished lake Erie fun times. And after I gave the fish my breakfast for that day
Oh man I’ve totally been there. Sick as a dog, “chumming” the fish with breakfast and still grinding it out!
Lake Erie is the most shallow of the Great Lakes. One would usually think that would mean calmer water and smaller waves, but actually the opposite is true. The other lakes are considerably deeper and the transition from deep to shallow is much closer to the shore. On Erie, the depth change is far more gradual so the waves have the potential to build larger before they get closer to shore and in the realm of the walleye and perch fishermen.
I’ve fished 6-8 footers on both Erie and Ontario, and I’ll take the deeper lake all day every day! 😎
A fellow TREMOR owner not far away has generously offered to do the same for me! A link made on this site, I just need to find the time to do it.. Very cool!
We all live and work and play on common ground.... Important to remember.
👊 BOOM!
Yeah. I will always have memory of that day. One of the lasts Me and my dad had together. had a stroke shortly thereafter, and passed a few years after that. He enjoyed his Marlboro's but it cost him. But hey what isn't dangerous these days?
