I finally found a few spare minutes yesterday so I decided to check another mod off the list. A few months ago I was reading threads on this site and I came across one where members were complaining about the little rubber fuel cap tether getting in the way of the fuel door closing. I hadn’t personally had any trouble with mine, but it got me thinking that the law of averages would most likely catch up with me, and I’d be unhappy with the setup at some point in the future.
Well that time came and I started searching back through threads until I found the one with the solution I needed. $20 and a few days wait and I had a perfectly 3-D printed fuel cap holder show up to my house thanks to one of our awesome members here
@kmtweb
It took me a little while to finally gather up the remaining stuff and but I put it in last night (it took maybe 10 minutes) and so far I couldn’t be happier. I used gorilla tape to affix it to my door. My only suggestion is to make sure that you pre place the holder on the door and test it for clearance of the fuel cap and the DEF cap if you have the diesel. I used a little painters tape to hold it in place to line everything up beforehand. I made sure to clean everything with rubbing alcohol and then away I went. Super simple.
The last thing I did was pull the plug holding the tether to the fuel door with a pair of pliers, and then I saw that the side of the tether that goes to the cap had a t shaped end and the ring had a gap so some simple reasoning and a little bit of tugging, pushing, and pulling, and next thing you know, I got that side off without having to cut anything. Done!
